Kenmore plus cant change cycle dial - Washing Machines
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 03, 2012
On a 417-44082400 washer how do I get the dial indicator out?
Try this site - very helpful and had parts I needed. No, I am not associtaed with them - just satisfied customer. Got help and parts for Kenmore washer and dryer.
Washing Machine Repair Help
Apr 26, 2014 | Kenmore HE2 Plus Front Load Washer
I have a kenmore 70 series heavy duty plus. my model number is 82372110. my washer will fill with water but when its time for it to start to agitate it drains the water then fills it and drains it the
Sounds like the main dial is gone on the top control panel. How a washer works, is the water level switch ( the dial that allows you to select the amount of water you want to wash your clothes in) sends a signal to the main dial, when the water level is full to turn on the agitate and the water to shut off. But it is emptying the water instead, so the main dial is skippiing the agitate cycle. If you take the back panel off the top control panel, you will see a mechanism behind the main dial. That is probably what needs to be changed. It costs anywhere from $120 to $180 for the part. You may want to invest in a new one instead but replacing this part should fix your problem as well. It is about a 2-3 out of 5 for someone without experience to fix. Not hard. Have you noticed any whining or abnormal mild grinding coming from the dial itself? This may be a clear indicator that the dial is on its way out.
Jul 18, 2012 | Kenmore 22422 Top Load Washer
Water won't quit filling and agitator does not engage into the cycle.
Did you solve this problem -have one doing the same-feed back -please!
Mar 22, 2012 | Kenmore 3.2 cu. ft. Plus Top Load Washer
My Kenmore 110-46462501 washing machine stopped mid-cycle
Can you hear the pump running? It might be plugged or not running
I’m happy to help further over the phone at https://www.6ya.com/expert/pat_7f6b46a4565f904d
Oct 20, 2017 | Kenmore HE2 Plus Front Load Washer
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
Cylce stops after 1st drain before spin out
I have kenmore washer front load H2 after 1st circle of wash it stop and start beeping with code F11. My email address is anarfi1212@ live.com
Jan 21, 2010 | Kenmore HE2 Plus Front Load Washer
Doesn't agitate and spin cycle work when reset
you have a worn motor coupler
you can order a new one at sears
and its a ver y easy repair
Oct 06, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
The washer stopped in the spin dry cycle. It will not do anything now no matter the dial setting.
Hello.
  • Check the drain control lever
  • Test the drain control coils
  • Check the cam bar
  • Test the timer control
  • Jun 26, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
    Washing Machines Logo
    11 people viewed this question
    Top Washing Machines Experts
