Question about Samsung SWA-5000/XAA Rear Wireless Home Theater Receiver
Samsung wireless speakers quit working
The rear speakers had worked fine until about 2 months after the 1 year warranty ran out. Then they started intermittently cutting out and now they wont come on at all. I have tried leaving the Samsung Theater unit off and used the remote to punch 0 1 3 5 into the unit and then turning the unit on and holding the reset button on the back of the receiver for 5 seconds. Does not re-pair. Also tried doing everything the same EXCEPT powering on the unit still nothing... HELP
2 Suggested Answers
SOURCE: Samsung SWA-4000 Wireless connection problem - Not connecting with main unit
I have had the same problem with the wireless unit and thought the same, it didn't work. The way to fix this is simple. You need to do the 0, 1, 3, 5 on the remote and turn on the home theatre system on the main switch on the front panel (as I was doing this on the remote, and it was failing). The blue light should then stay illuminated. If not just switch the main on/off button again, and it shoud work.
Posted on Nov 09, 2008
Temp on screen rises & flash high temp.
Hallo
The compressor winding's could also be faulty.
regards
May 19, 2016 | Frigidaire Refrigerators
2004 GMC Sierra 2500HD with factory Bose stereo system but no on-star, put an aftermarket clarion CD/DVD player in it over 2 years ago i put in the adapter for making the Bose factory system work and
either your connectors need cleaning or maybe a break in the wiring. Is there on spot where both wires come together if so check there.If there is any plugs, pull them apart and clean them with contact cleaner
Dec 15, 2014 | 2004 GMC Sierra 2500HD
Samsung HT F5500W The system worked without a problem. I painted the room so I had to disconnect everything. After connecting back rear speakers does not work and the link light on wireless box is...
with the main unit off. Press and hold the link button on the back of the rear wireless amp until it starts blinking fast. The take the remote and while pointing at the main unit, press 0-1-3-5 enter. Wireless link ready should show on the display. Turn on the main unit, and it should find the rear amp.
Jul 17, 2014 | Audio Players & Recorders
SAMSUNG SWA5000 Wireless Receiver Module stopped working **help help**
HiI have the same problem, have you found the solution?
cheers,
Dec 29, 2011 | Samsung SWA5000 Wireless Receiver
MUST READ THIS I have a rca 61" hdtv purchased in 2004 with a 5 year extended warranty (thankfully) and have had nothing but problems with it. it is the worst thing i have ever bought.exactly 13 months...
All DLP TVS are lemons really.Most the Convergence ICS,they use on the board held the picture together will alway die about 1 year or 1 1/2 year all way need it replace.The bulb have life spans but never reaches alway dies before than.
Apr 01, 2010 | RCA HD61LPW42 61" Rear Projection HDTV
No Display on my Samsung 204B monitor
If you know how to open it up and get to the power supply you will find three capacitors 2-820uf and 1-330 @ 25vdc 105o.they will have puffed up tops replace them. FYI the monitor has a 3 year warranty.
Dec 12, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Carver Sound Problems
your going to need this place to download the remedy's for your system http://www.euras.com/repair_tips_1/CARVER/AV505/AV505_CARVER.htm
if it is not working then there is another serious problem , and it could be the amp IC or the volume IC but tests will need to be done to determine what is causing the failure , but it does sound like amp IC as a suspect since the rear were not even working , did the volume seem different when turning it up or down before the center quit or after the center quit?
Nov 02, 2008 | Audio Players & Recorders
Electrostatic touchpad won't work
Hey,
been through this one with you just the exact same.
I never dropped mine aswell. though what I descovered is that
samsung make their phones only to last for up to 6 months till they need 2 be repaired.
The thing that I think is up with your SGH-E900 is that you
must have over chagered it for to long and burned up the sensors
or you have been pressing the buttons too hard.
sorry that I couldn't be more of a help though if you still have
your phone under the 1 year warranty you can get it repaired, they might not accept it if you only have a couple of days left of your warranty because they won't get it back to you by the time your warranty has ran done.
Oct 29, 2007 | Samsung SGH-E900 Cellular Phone
Samsung SWA-5000/XAA Rear Wireless Home Theater Receiver Logo
60 people viewed this question
Top Samsung Audio Players & Recorders Experts
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
