Question about Quinny Buzz Baby Gear
Wobbley frame my frame i wobbley
  • Quinny Master
  • 1,629 Answers
Hi
If you are in the UK and it is under 2 years old please contact your retailer with proof of purchase for them to send in for inspection & repair under warranty terms and conditions.
If you are in the UK and it is over 2 years old or you no longer have proof of purchase please contact the customer care team on 01284 413 141 Mon-Thur 8.30-6.30 / Fri 8.30-4.30 (Excluding Bank Holidays) to book in for chargeable inspection & repair work required.
If you are not in the UK please visit www.quinny.com and select the country you're in, then use the "Contact Us" tab on the right hand side for your enquiry to be sent to the customer care team for your country who will be able to provide further assistance.
Posted on Feb 03, 2013
My 2008 dodge caravan bottom pully is wobbley
probably from a failed rubber in the balancer section
replace the harmonic balancer to fix the problem
Dec 17, 2016 | Dodge Caravan Cars & Trucks
How to tell the water pump is bad on a 02 buick rendezvous
noisy grinding or marbles banging together =wobbley or seized pulley--leaking or leaking at weep hole the following link explains same
3 Symptoms of Bad Radiator Water Pump
Sep 25, 2015 | Buick Cars & Trucks
Has a bad squeaking noise. Replaced alternator, belt and pully. Still squeaking
bad crank pully, check to see if the lower main pulley is wobbley or the belt tensioner
Oct 11, 2012 | Chevrolet Silverado Cars & Trucks
The frame has become wobbley is there anywhere for it to be repaired?
Hello siana... go to the hardware store and get a tube of 5 minute clear epoxy. Use a tooth pick or other small tool to get the epoxy into the joints where the frame is loose. This will set up in 5 minutes so work quickly. J.
Jul 13, 2011 | Toys
How to sight in a z6 swarovski scope 10x42
the easy way is bore sight it,,,,,first clamp the rifle in a stand and look down the barrel at some thing like a post top at say 100 yds when you see the post top in the bore dont move the rifle any more till you have tweeked your scope so the cross is on the top of the post top,,,the rifle is then bore sighted,,,now clamp the rifle down and test fire it,,,it will likley shoot low,,,so tweek it till it shoots right,,,,you should get it spot on in less than 5 rounds,,,dont try to hand hold your rifle when zeroing,,,you need to get rid of as many wobbley bits as you can,,,gees whats the bigest wobbley bit?,,,,yep we are? so clamp it down till it shoots right! also dont fire more than 5 shots or you will get your barrel hot and this changes the point of aim,,,in a sporting rifle???
Nov 27, 2010 | Swarovski Optiks Z6 Riflescope
When bumping up stairs handle bar extends, and feels loose (handle bar is very wobbley)
The Bugaboo is not the ideal stroller for bumping up and down stairs, The reason being it's core design. Most stroller handles have two or more mounting points to the frame but most strollers have baby facing forward and facing the big bad world and not Mummy. The Bugaboo is very clever, the handle can be locked ether way and the seat face either way but the handle has only one point where it attaches to the frame and that point has to rotate and lock. To give you an idea of the forces involved a crow bar the length of the Bugaboo handle can pull six inch nails out of hard wood!
Unfortunately Bugaboo have not used the best material solutions in this critical handle lock. They use a plastic disk to move aluminum locking pins and they fail if you bump down to many stairs. This happened to our Bugaboo in New Zealand. I repaired ours and now I help others by making or sourcing the better quality parts to repair them. I use aluminum for the disk and stainless steel for the pins.
If you are lucky another to have a Bugaboo less then two years old and still have proof of purchase documents Bugaboo will replace the frame for you. If it's older you can buy a new frame for around $400 but this will also increase you resale value by around $200 when you sell it. Lastly you can repair it for around $100 a side depending on parts required, Click on my name and you'll find many posts on how to repair both the Handle lock and the Handle extension lever or wing-nut. macnutz_23.jpg
Nov 26, 2010 | Bugaboo Cameleon Jogger
Is the pulley designed to remain wobbley after installation?
Pulley should not move if tightened properly.
Nov 18, 2010 | GE WCVH6260FWW
How to remove the knobs and replace gas valve on DCS 36" gas cook top - looks like wobbley stem.
The knobs should just pull straight off. Don't tilt or bend them around, just pull them straight. off.
Nov 23, 2009 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
Starter replace ,how to for a 4x4 1985 Toyota Pickup
disconnect the positive side cable on the battery. then unbolt the positive battery cable on the starter. then unblug the ignition wire from the starter. then get a 14mm wobbley socket and pull off the starter.
Sep 25, 2009 | 1985 Toyota Pickup
My phone is bit wobbley can you fix it please? This is the binatone and came out in Leyland
Sure, just pay the trip charge and transportation and I'm on the way.
Try looking at the feet on the phone. One is probably missing.
Carl
Sep 03, 2008 | Lands Phones
Baby Gear Logo
41 people viewed this question
Top Quinny Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Michael Vincent Cruz
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
