Question about Polk Audio PSW10 Subwoofer
Polk Audio PSW10 not working
My PSW10 will not work. It has been idle for a few months and there is now no power. I have tried another outlet with no positive results.
I just read this same problemin a psw10. It was recomended to remove back panel and there should be a fuse behind there. Check it out.
Posted on Feb 13, 2009
Can I add Polk Audio PSW10 10" Powered Subwoofer, 35Hz-200Hz, 50W Continuous Power, Single with my Yamaha ATS-1050 Sound bar?
Yes. Connect a standard rca cable from the audio out jack of your yamaha to the input of the Polk sub.
Aug 18, 2016 | Yamaha Audio Players & Recorders
Where is the fuse in Polk psw 10 subwoofer?
You will have to remove the plate amp and look on the pcb, it is generally located near where the main power lines come in.
If you still can' find it contact Polk tech support, Ive owned several Polk products and always found there tech support very helpful; very helpful;
Tech/Product Support
9AM-5:30PM EST Mon-Fri
1-800-377-POLK (7655) Option 1
FAX: (410) 764-5470
polkcs@polkaudio.com
International: +1-410-358-3600
Nov 23, 2014 | Polk Audio PSW Series PSW10 Black 10-inch...
My receiver has one pre-out will a psw10 work
yes but a sub woofer out is better. You may have to crank up the sub response. If it has a level on the sub with a crossover set the cross over to around 120hz. And set the bass on your receiver as you feel appropriet.
Nov 09, 2013 | Polk Audio PSW10 Subwoofer
I purchased a SUPRA 32 LED TV FULL HD Model No SLED32OT9001R from UAE 3 months back and from the last few days TV is not working even the power led at the front pannel doesnt shows power.
Be sure the power cord is plugged in to the a/c outlet fully. Take a table lamp and plug in the same outlet to verify power is good. If no power, check for circuit breaker tripped in main breaker box.
If problem seems to stay with tv, I would contact seller. You should have at least nine months of warranty left.
May 17, 2011 | Televison & Video
Polk Audio PSW10 electrical board smoking
I should just replace the parts that were burning, it will cost a lot less.
Jan 15, 2010 | Polk Audio PSW10 Subwoofer
Solution to Vibration
you might try to turn it down and maybe move it somewhere else in the room i have the same problem its just my neighbors are in another house across the yard i just have way to much power god forbid some one family or what ever be in my house.
Nov 15, 2009 | Polk Audio PSW10 Subwoofer
Hp deskjet 6540 power adapter turns on but printer doesn't
This printer have a problem on HP circuit board. Usually its grounded due to ink waste, or not using it like what you said it took about three months. Here is a tip if your printer HP is still under warranty then you can send or contact to HP Center or the one you buy from it. To be sure that your printer is working back normally.
Sep 13, 2009 | HP DeskJet 6540 InkJet Printer
Polk Audio PSW10 Subwoofer Logo
1,155 people viewed this question
Top Polk Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
kdigby
kdigby
Level 1 Expert
Are you a Polk Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
