Question about Timex Ironman Triathlon 50 Lap Digital Watch
Need to shorten the band on a Timex Ironman Triathlon
I recently bought a Timex Ironman Triathlon, and the wrist strap is a tad too large for my wrist (it keeps sliding every time I move my arm). The links are metal and when a poke a pin into the hole that you would think would release the link, the pin refuses to move.
  • Anonymous Mar 19, 2014
    time zone seems to randomly change from t1 to t2
  • 2,334 Answers
These pins will definetely come out- poke a bit harder. You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 04, 2009
Where to find timex replacement strap for T5K212F5
Per the watch's manual (page 41 in W246_M811_NA_EN.pdf) which is downloadable from the timex site
"Should you need a replacement strap or band, call 1-800-328-2677."
May 05, 2012 | Timex Sports Ironman Triathlon 100-Lap...
Can't find the replacement wrist band on my t5f001, any idea where can it be found?
Try Timex customer service - custserv at timex.com. I have the same problem and just wrote them.
Jul 06, 2011 | Timex T5f001 Ironman Triathlon Heart Rate...
I recently bought a timex ironman with supposedly 50 lap memeory lost instructions dont know how remove laps and set timer to track laps also how do i set time?
You can get instructions from the Timex web site "timex.com".
At the bottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
Apr 07, 2011 | Timex 50-Lap Ironman Triathlon 59221 Wrist...
Strap broken on timex heart rate monitor watch 30 lap ironman triathlon need a replacement
Hi, Almost any large dealer like Wal-Mart, Sears, or Target will have Timex replacement straps and bands for most popular watches and monitors. Sometimes a local Authorized Dealer will have specialized products that the department stores don't even carry without ordering.
I have had good luck with Wal-Mart on watch accessories. I've also ordered straight from Timex in Little Rock, Arkansas, ph. 1-800-448-4639, but it usually takes more time for just parts.
Thanks, Bill
Sep 06, 2010 | Timex Ironman T59761 Midsize 30 Lap...
Need a new Rubber Wrist Band for my Timex 66801 Ironman Watch
Hi, Most Timex bands for this series can be found at this site:
http://www.watchbands.com/Category.aspx,,CategoryID,,4
They will cost you between 8 and 15 dollars.
If you need further help, call Timex in Little Rock, Arkansas, phone 1-800-448-4639.
I hope this helps you. Thanks, Bill
Sep 01, 2010 | Timex Sports Ironman Triathlon 100-Lap...
Replacement watch band web site?
mcdevito75 here, Timex.com should help. Also look for a small watch repair shop in your area for a replacement strap, and they may even have faster accesss to Timex.
Jun 27, 2010 | Timex Sports Ironman Triathlon 100-Lap...
Loop
Go to "www.timexindia.com/contactus.asp" where you will find a contact address.
Feb 21, 2010 | Timex Ironman 30 Lap 53952 Wrist Watch
How do I change the battery in my Timex Iron Man Triathlon? I removed the 4 screws in the back but cannot remove the cover because of the overlap of the wrist band.
You will need to remove the wrist first before the cover will come out.Else pull the wrist out and allow it to leave a gap and then you can move the cover out.
Dec 19, 2009 | Timex Sports Ironman Triathlon 100-Lap...
Help with battery problem on Timex Ironman Data Link Wrist Watch and after installing a new battery the alarm is silent.
Help with battery problem on Timex Ironman Triathlon after installing a new battery and reset, displays the message 846010 1.0 P1and the alarm is silent.
Jul 08, 2009 | Timex Ironman Triathlon 50 Lap Digital...
Ironman Triathlon Sleek Ladies watch Band problem.
try simple free or a citrus solution often found in household cleaners. js
May 24, 2008 | Watches
Timex Ironman Triathlon 50 Lap Digital Watch Logo
308 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Geoff
Carol
Level 1 Expert
Are you a Timex Watch Expert? Answer questions, earn points and help others
