Neptune MAH8700AWW won't enter dervice mode
  • 5 more comments
  • Philip Devole
    Philip Devole Nov 03, 2012
    I try entering the service mode by holding the delicates button and heavy soiled buttons for 3 seconds to put machine in service mode, but it doesn't activate service mode.
  • Richard Roth
    Richard Roth Nov 03, 2012
    You will need to replace the control board then if it does not respond. Here is the part to order. http://click.linksynergy.com/fs-bin/clic...
  • Philip Devole
    Machine not worth putting that amount of money into. Has a total of about $400 in parts needed.
  • Richard Roth
    I agree with you. I always buy a used appliance. If you buy one with the electronic controls, be sure you have a surge suppressor on it. A power surge causes 90% of my service calls. Let me know if I could help you in the future.
  • Richard Roth
    Thanks for using FixYa!
  • Philip Devole
    Philip Devole Nov 04, 2012
    RICHARD I WAS USING THE WRONG KEY CODE TO ENTER SERVICE MODE PRESSING CHIME AND EXTRA RINSE KEY ENABLED ACCESS TO SERVICE MODE THANKS FOR YOUR HELP.
  • Richard Roth
    Richard Roth Nov 04, 2012
    I'm glad it worked.
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
Could you please describe the problem you are having a little better?
Posted on Nov 03, 2012
  • Philip Devole
    I try enetering the service mode by holding the delicates button and heavy soiled button for 3 seconds to put machine in service mode, but it doesn't activate service mode
  • 186 Answers
SOURCE: I have a Maytag Neptune MAH8700AWW that give an E3
Hello. This link will take you to a web page with a discussion concearning your problem. It's 2 pages long and gets a little technical but does come to a conclusion.
http://applianceguru.com/forum2/6484.html
builderdale
Posted on Jan 20, 2010
Krazytech
  • 725 Answers
SOURCE: Maytage Neptune E3 code - Model MAH8700AWW - machine won't finish cycle
“E3” code – Machine control is attempting to drive the motor but is not seeing any tach response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Possible causes of ‘E3’ codes: 1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause. 2. Hall Sensor fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case, or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Hall Sensor – PCB that is located on the back of the motor that senses motor rpm. It is not a separate part, but rather an integral part of the motor.
Posted on Sep 23, 2009
  • 109 Answers
SOURCE: matage neptune mah8700aww purchased five years
4 screws takes the front off the washer to find the leak, dryer probably needs drum rollers. If you didnt know maytag went bankrupt for a reason
Posted on Jul 28, 2010
ZJLimited
  • 17970 Answers
SOURCE: I have a Maytag Neptune MAH8700AWW with error code
"te" error code is caused by a faulty thermistor; likey cause is:
a. Loose wiring at the control panel (directly behind the cycle selector knob)
b. Broken wire at the thermistor (located at the bottom/front of the tub)
To access the wire plug connectors at the control pannel, remove the top cover of the washer. Stand in front of the washer and look for the plug connectors behind the control panel. Pull apart the plugs and re-install.
Test the washer. If the "te" error still occurs it will be neccesary to remove the front panel as well (two sets of special plier-type tools are needed).
Inspect the thermistor closely, with good lighting. If there's a break in the wire it will be at or near the black sheathing / heat shrink material.
Just like a reference guide, this service manual could helpful: MAH9700AW
Hope this helps.
Posted on Oct 07, 2011
kevin_getz
  • 1031 Answers
SOURCE: What's your problem?my maytag neptune washer is not draining
You might have a bad timer or drain pump.
Posted on May 27, 2012
My Maytag Neptune MAH8700AWW washer when in the spin dry mode shuts down with a suds error?
Check your drain hose for kinks or blockages, check filter and pump for blockages, check wire harness connections to pump, pressure switch and CCU.
I machine will start- If too much detergent was used, run the unit through a Rinse/ Spin cycle then a Normal cycle without adding any detergent. This should clear the unit of the excess detergent.
Dec 29, 2012 | Maytag Washing Machines
My maytag neptune washer front loader -the water will not go into washer when it is turned on the serial # is S1101 5853GR and the model 3is MAH8700AWW
First thing I'd check is connections at machine where hoses attach. Shut off water and remove and inspect little screen like filter to trap dirt at machine, to make sure they are not plugged up. Is it happening on both cold and hot?
Jan 26, 2012 | Washing Machines
Neptune mah8700aww has a e3 code
The Neptune can sometimes be reset. God knows the repairman for Maytag really needs to get back to work, yet to reset the cpu on your washer/dryer just unplug the unit for 60 seconds. I hope this helps you out.
Oct 05, 2011 | Maytag Neptune MAH5500B Front Load Washer
Matage neptune mah8700aww purchased five years
Jul 28, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have a Maytag Neptune MAH8700AWW that give an E3 error code. Is there anything I can trouble shoot thru the Service Mode?
builderdale
Jan 19, 2010 | Maytag Neptune Washer
How do I replace the door switch button?
unscew & raise the top panel to gain access to the switch
easy fix!
Jul 21, 2009 | Washing Machines
May 28, 2009 | Maytag MAH6500 Neptune Front Loading...
My maytag neptune washer #mah8700aww,display "lo" what is?
maytag neptune washer model # mah8700aww. there is no power on the display. checked power to outlet,
Apr 29, 2008 | Maytag Washing Machines
Washing Machines Logo
144 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
