Question about Motorola RAZR Cell Phones
Dropped my phone an the screen is turnng blue
I dropped my phone outside on the ground and I noticed that under the first screen, what looks like the second screen, had a small crack, about 20 mins later the screen started to not respond as fast as it should and small blue splotches were starting to appear also apps and websites ive recently been on keep burning onto the screen. the blue splotches have been getting bigger and bigger and now take up most of the screen. i dont know wether its something to do with the colour in the phone or something like that and i need to know if i need to get the screen repaired or not?
    New Friend:
  • 24 Answers
The screen is broken as a result of the drop and needs a replacement.
Posted on Apr 23, 2017
tvtek
  • 1284 Answers
SOURCE: lite blue cloud and blue spots
It might be just dust somewhere in the light path to the LCD panels or on them. The only other thing that comes to mind is the light engine itself and that is no easy task to replace. The part number for it is A-1084-666-A and can run close to 1000.00 for the part. Can you post a picture of the issue so I can look at it?
Posted on Mar 07, 2007
Guitarguy1
  • 4 Answers
SOURCE: white screen
I had this problem too. My razrs screen would just go white every 15 minutes maybe, and i would have to turn it off and back on.There was a white line at the bottom of the screen also, so i went to http://direct.motorola.com/hellomoto/motosupport/source/SoftwareUpdateSummary.asp?country=&language=&web_page_name=SUPPORT&strCarrierId=US%20Cellular&strPhone=V3c&strCable=Mini%20USB%20Data%20Cable and downloaded thee software update. after it was finished the white line went away the screen never went white and it fixed everything
Posted on Oct 08, 2007
JackHeath
  • 1049 Answers
SOURCE: Leaking Black Colour
REPLACE THE PRINTER AND SAVE YOURSELF A HUGE MESS
Understand when I suggest replacing the printer, it isn't that you can't fix it or that I'm not answering your question. But to do so will require cleaning every inch of the internal components. The ink will stain everything it touches and you'll need a smock, a work area, and probably gloves.
See what happens is that where the print head parks there is an ink absorber and below it is an ink well. The ink absorber is a sponge like arm that cleans off the cartridge and the well catches the loose ink. Inkjet printers are for the most part not designed to last past a few years, so few printers have a method for emptying these. When they become full the printer will start leaking ink in torrents but will continue to function normally for quite a while until it fills every nook and cranny of the printer. While all you notice is a sightly higher consumption of ink.
By the time you start visibly seeing the ink come out of the printer, the inside is a huge mess, and when I say huge I mean without cursing, words just can't express how nasty and ink smeared it is.
Posted on Aug 06, 2008
  • 78 Answers
SOURCE: screen keeps going bright
I am sorry but this means that the screen might be busted. the impact might have damaged the luminous controller inside the screen. You might need to find a replacement for the screen if that is happening.
I had a similar case where the screen was gng very bright but this was due to a cabling fault of the screen.
Posted on Mar 07, 2009
  • 4 Answers
SOURCE: LG envy phone with cracked screen
This is a frustrating protocol that companies need to maintain " no physical damage" it is due to idiots who abused the warranty and made us the ones who need it ,suffer . There is a way around it . It may charge a deductable and providing that your insurance covers lost or stolen producte. File the claim. I repair cell phones .a ez repair may cost 100 to 150
Posted on May 11, 2009
99 grand caravan- one brake light works, the other doesnt. checked fuses, checked bulb, both are fine.
Get a test light and check for power. If you got power check the ground, and the contacts, if not follow the hot wire back to the brake switch to locate the short.
Dec 25, 2017 | 1999 Dodge Grand Caravan
In my 1996 GMC sierra 2500, the heat cuts out.. i will put it on high it works for a second then turns off. i have also noticed that when it does cut out the lights on the PRND321 goes out as well. i...
The heat cut's out ? The heater blower motor stops working ? Testing the electrical circuit would be the proper way to diagnose . Looking at a wiring diagram an using a DMM - digital multi-meter , an doing amp draw test on the blower motor . The PRND321 an blower motor probably share a ground or power point . Looking at a wiring diagram for both circuit's would show that . Not a short , more likely a loose ground connection . Free wiring diagram's here http://www.bbbind.com/free_tsb.html Enter vehicle info. year , make , model and engine size . Under system click on HVAC then under subsystem click on HVAC controls . Then click the search button ,then the blue link . First blue link is blower motor control circuit . Voltage drop test the blower motor ground .Videos on youtube showing how to diagnose !
Blower Motor Resistor Replacement Wire Splice Splicing Amperage Draw Test
Blower Motor Resistor Function and Diagnostics
Mastering Voltage Drop Testing with Pete Meier and Jerry Truglia
Oct 30, 2017 | 1996 GMC Sierra
My lg voyager has lines comin up from the bottom
if the outside screen is not cracked and its just the internal lcd take it into a Verizon store and they should swap it out under warranty, otherwise if they will not do it send to LG and they will replace. Don't tell them you dropped it at the Verizon store tell them it was in your pocket and something must have pushed against it
Jul 11, 2010 | LG VOYAGER VX10000 Cellular Phone
My env2 was dropped. the outside screen works but
it's a good time to go get a new phone. that much damage would cost more in repair that it would to either replace or upgrade to a new phone.
Mar 23, 2010 | LG enV2 EnV-2 VX-9100 VX9100 Premium Pink...
The inside screen doesn't work
change the flat of lcd if it dose not work change the lcd
Nov 24, 2009 | Nokia 6085 Cellular Phone
Screen out
I have one that the screen is out, I dropped just like you guys and when i took it apart I noticed that the ribbon cable that is going up to the screen, some of them had torn and that is what caused my screen to go out. You might want to check that out.
Sep 16, 2008 | Samsung SYNC SGH-A707 Cellular Phone
Outside screen is blue
have the lcd replaced on both phones.
Mar 08, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Blue screen on outside display screen
you need to have the LCD replaced on the mobile.
Jun 28, 2007 | Motorola Mobility RAZR V3
Cell Phones Logo
Top Motorola Cell Phones Experts
270rexton
270rexton
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
