I have an old ASUS P4S8X-X rev 1.01. BIOS forgets settings.
Left it sit unplugged for months, went to run it and the bios keeps forgetting the settings and does not recognize a HD is hooked up, also the processing chip speed sometimes gets forgotten. takes repeated attempts resetting it all for it to remember it for a while, then forgets and I do it all again. I have put in a new battery. tried different HD's, but it still gets amnesia. What do I do? a new bios chip?
  • 1 more comment
  • Eric Jacques
    Eric Jacques Nov 03, 2012
    read above, **** "all again. I have put in a new battery. tried " ****
  • Michael Green Nov 04, 2012
    The biggest problem with a new BIOS chip is finding the corect one for your board. It would be easier to find a new CPU / board bundle than replace the chip. Your board is old and sometimes the circuits fail. For about 100 GBP you could get a faster processor with RAM and board, or even a new board for about 30GBP Both would be easier and quicker.
  • Eric Jacques
    Eric Jacques Nov 04, 2012
    Thank you, I have considered that, but I DID find a BIOS chip for 15, And most used boards may have their own problems, this MB I know. Though you do raise the point of it may be another circuit prob besides the BIOS chip and will not be able to tell until I buy and install the new chip. TY for your help, but I am hopeing someone has a definitive answer KNOWING that I can do this cheaply with the BIOS chip, or a reset/setting I have missed.
  • 3,799 Answers
Replace the CMOS battery or just leave it plugged in and switched on for a couple of hours. This should recharge the CMOS battery. If this doesn't work you will need to replace the battery. It is a small circular silver disc on the motherboard.
Posted on Nov 03, 2012
  • Eric Jacques
Nitrotrike
  • 589 Answers
SOURCE: Asus P5B bios up-date gone bad
What version BIOS was it previously, and what version were you trying to update it to?
If you were trying to do 1102 and up, and the previous version was 7.09.02 or below, this is the problem. Any of the versions 1102 or above do NOT support version rollback.
My best advice is to download 7.09.02, and see it at least gets you back up and running. If it works, then go for 1102, and then 1803.
Posted on Jan 08, 2008
map9966
  • 2351 Answers
SOURCE: P4S133 bios settings...
Check the jumper for the bios, it may be set for clear. (not an uncommon boo - boo). Move the jumper back to default pins.
Posted on Apr 09, 2008
SOURCE: HP Pavilion asus p4b266-la Flash gone wrong
try resetting the bios! there is a pin on the motherboard that you remove , then re-install . then restart computer. check the instructions on your new mother board, also could be a bad
keyboard, change out keyboard, try usb keyboard!>>>good luck!
Posted on Apr 22, 2008
  • 256 Answers
SOURCE: New ASUS A8V-MX motherboard will not boot to CD or HD with XP
The first thing is to make sure that your CD/DVD drive has the windows disk in it. Also check drive C which is where the windows will be installed. It may require that it is hard formated. Hard formatted means "format x /u" [format-space-drive to be formatted-space-right slash-u]. This will place the drive for "windows xp sp2", all of it, to one pass of zeroes. So, once we have a clean drive C and the installation disc is inserted into the CD/DVD drive, you may proceed to install. You will need to find "install" or "setup" and start it on he "RUN" mode. Any questions or help get back to me. CONSTANTIN (arzconst)
Posted on Jun 25, 2009
  • 111 Answers
SOURCE: soyo m/b model sy-p41 845pe.
Eugene, how are you? Not a problem, firstly have you replaced the motherboard CMOS battery? If you have the next step is to boot into the BIOS, most of the time it will mean pressing the delete key, or F8,F10, F12 and or ESC upon turning on your syst. It all depends on what kind of pc you have.
Once you are in the BIOS setup screens go through each one and just remember to save and reboot your syst. This should set you straight. ;)
Posted on Jul 14, 2009
Unlock my asus from bios
If you mean you have to enter a password to get into Bios then do the following....
Simply remove the CMOS battery. A computer will remember its settings and keep the time even when it is turned off and unplugged because these parts are powered by small battery inside the computer called a CMOS battery. If we pull out this battery, the computer will forget alot of its hardware settings, including its BIOS password. This should not be performed on Laptops if you are not experienced working with laptop hardware.
As far as I am aware, if you have a Windows password on your computer after startup, you can do nothing in Bios or CMOS to get rid of it. The best solution is to re-install Windows after formatting the Hard Disk. Of course you will lose all of your data then.
May 03, 2014 | Dell Computers & Internet
A bios nao reconhecer o son
Verificá-lo durante a inicialização do BIOS http://support.asus.com/technicaldocuments/technicaldocuments.aspx?no=270&SLanguage=en-us
BIOS mais recente Baixe para P4S8X-X de
http://www.roxysoft.com/drivers/ASUS-P4S8X-MX-Bios-v-0502-download-driver/
Siga as instruções e instalar:
http://www.asus.com/999/html/events/mb/ezflash.htm
During bootup check you bios http://support.asus.com/technicaldocuments/technicaldocuments.aspx?no=270&SLanguage=en-us
Download latest bios for P4S8x-X from
Follow instructions and install:
Sep 15, 2009 | ASUS P4S8X-MX Motherboard
Failed A8V-VM SE Bios update attempt.
ASUS has a marvelous BIOS upgrade utility that runs from Windows,Download the correct one from the ASUS web site
http://support.asus.com/download/download_item.aspx?product=1&model=A8V-VM
Dont forget to rate the advice.
http://www.aa1consulting.com
Aug 03, 2009 | ASUS A8V-VM Motherboard
Cpu clock in my bios read only from 1200 to 1600 mhz.
Please read carefully the chapter 2 (page 33 and 47) of User's Manualfound at:
http://support.asus.com/download/download_item.aspx?model=P4S8X-X&type=Manual&SLanguage=en-us
I suggest you select "Auto" on "CPU Speed" setting in the BIOS "Advanced" Menu or adjust 18x in "CPU Frecuency Multiple" if posible for reach optimal setting.
May 04, 2009 | ASUS P4S8X-X Motherboard
BIOS Password Problem
The only thing that a bios update would do would update the bio your password info should stay the same maybe your not typing it right try typing with or without cap lock
Mar 10, 2009 | ASUS F9S-B1 Intel Core 2 Duo T7500 2.20GHz...
ASUS P4S8X-X
Yes, this is a RAM incompatibility since the motherboard don't support PC3200, you can check this link for the complete specs of this motherboard http://reviews.cnet.com/motherboards/asus-p4s8x-x-mainboard/1807-3049_7-30158119.html
Hope that helps.....
Don't forget to rate the solution FIXYA thank you....
Oct 06, 2008 | ASUS P4S8X-X Motherboard
Video controller problem PLEASE HELP !!!
Hi bullterrier0,
The Asus P4S8X-MX uses an onboard video controller, (SiS Real 256E graphics card).
There is an order of sequences that must be followed when adding another video card on to the motherboard. If these are not followed your new card will not function correctly. Shut down the system. Unplug the power cord from the PC. Open your case.
Please remove any graphics cards you may have added into the system, (For now). Once removed leave your case open & plug the power cord back into the PC. Press the start button. Start pressing the Delete key every two seconds as the PC starts up.
The bios main menu will load. Instruction on how to move about within the bios is listed at the bottom of the menu. You will need the P4S8X-MX manual. (If you no longer have the manual you can download it from Asus by clicking on this link:
http://support.asus.com.tw/download/download.aspx?modelname=P4S8X-MX&SLanguage=en-us
Click the plus sign next to; Manual. Find the English manual.
Create a folder on you're desktop & name it Manual. Download the manual. Save the manual into the folder. The manual will need Adobe pdf reader to be viewed. If you do not have Adobe you can download it for free from this link:
http://www.adobe.com/products/reader/
Once into the bios go to the title Advanced, page 2-17 in your manual or page 59 in Adobe pdf viewer. Open Chipset sub-menu.
Than find, Primary Graphics Adapter page 2-21 in manual, pg 63 in Adobe.
If the TV turner card is an AGP set this to [AGP] & set AGP Fast Write Control to [Enabled].
If you are using a PCI TV tuner card set this to [PCI]. Save the bios & exit. The PC will auto restart. Press & hold the power on button until the PC shuts off. Unplug the power cord from the PC. Re-insert you're AGP TV video card. Double check all internal connectors for good connecting before closing the case. Plug in the PC's power cord & start the system. Once windows has finished loading install the TV video cards driver software.
If you installed software drivers for the P4S8X-MX other than driver software provided by Asus please uninstall that software through Add/Remove programs. (If at all possible).
Since you want to use a TV video card you can not use the onboard graphics card at the same time. This is why windows was restarting. Windows did not know which card to load. Once the onboard card has been disabled by telling the bios to load the AGP, (Assuming you're TV card is an AGP card) windows should run fine. There is always the possibility I interpreted your trouble incorrectly. If this is the case, please let me know & I'll adjust my answer to fit the issue.
Good luck bullterrier0!
Mike
Aug 12, 2008 | ASUS P4S8X-MX Motherboard
Asus m2n-e sli locks up at bios post splash screen
Sounds like a bios issue. Try resetting the bios, pg. 2-19 in user manual. After clearing the bios jumper, make sure you set it back to pins 1 & 2. If you still can not get into the bios main menu than head to Asus, click this link.
http://support.asus.com/download/download.aspx?modelname=M2N-E%20SLI&SLanguage=en-us
Since this is a new board & all Asus boards are warranted for three years I suggest you talk with an Asus tech. If you flash you're bios during the warranty period you may void the warranty. You can call Asus M-F, EST 8:00AM-5: PM.
1-812-282-2787. Not sure you have this number in you're manual. Chances are Asus will send you a new bios. Or you can buy a new bios for $5.00 not including S/H. From Asus online store. Click on this link. http://estore.asus.com/shop/
If I can be of more service, just post back & let me know how thing go.
Mike
Apr 27, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Computers & Internet Logo
132 people viewed this question
David Payne
David Payne
