Question about Pentax K1000 35mm SLR Camera
Can't open battery compartment.
I was give a pentax k1000 camera from my mother and i can not get the battery out to replace it. every time i try to turn the compartment with a quarter like the manual says it begins to strip. i think the battery is corroded in it.
  • ashe1977 Jan 04, 2009
    the first one worked like a charm Thanks
    Scholar:
  • 185 Answers
Ashe 1977
there are two ways to fix this.
1- remove the bottom cover, take the rubber seal off from the battery compartment, remove the battery then soak the bottom cover in vinegar overnite. this will remove all corrosion. remove the battery cap and clean the threads. completely dry the cap and bottom cover, apply WD40 to battery cover threads. clean battery contact with pencil eraser ( carefully ). reinstall the rubber seal, replace bottom cover.------ best fix.
2- this may not work but it's worth a try. just apply ( carefully ) WD40 around battery cap and let it set for about an hour, re-apply and wait another half hour. If this doesn't work refer to # 1
Posted on Jan 04, 2009
    Scholar:
  • 58 Answers
OK Ashe pinched my standard reply! But an extra tip, is to rub some graphite into the threads. (A soft pencil is perfect.) This will help prevent sticking in future.
Posted on Jan 23, 2009
The light meter on my pentax k1000 is not working, despite new battery
Many possible causes. First is that the battery is in upside down. Next you should remove the bottom cover 3 screws and the bottom cover. You can then remove the battery compartment and check for battery leakage corrosion on the wire on the bottom. If the corrosion is too bad it will wick up the wire to the top circuit board. You would have to remove the front and top covers to replace the wire.
the least likely cause would be the failure of the photocell that turns on the meter.
finally, if the camera has been impacted the meter may be broken. Without a battery the needle should rest In the middle of the scale (half way between top and bottom, in the cut out). If, when you put in the battery and the needle goes either to the top or bottom and stays there, and stays there no matter what setting, it is a sign the meter is broken.
Sep 27, 2014 | Pentax K1000 35mm SLR Camera
Film cartage broke missing parts
To repair this camera will be well over $100; my opinion not worth it. You would be better served purchasing another camera of the same type from ebay. An alternative terrific camera is the Pentax K1000, better yet K1000 SE. The SE has a split viewfinder, easy to focus. The K1000 have microprism that are more difficult to focus with especially in lower light; need good eyes. Then there is the Pentax K2, that at the time was their top of the line camera. All three cameras can be purchased for about $100-ish. Most will come with the Pentax 50mm f/2.0 lens.
Feb 06, 2014 | Minolta Photography
The light meter is not working on my Pentax K1000
there are three different possibilities. remove three screws, take off bottom cover. remove three screws of battery holder, lift to see if the battery wire has corroded or broken off. solve by extending wire and resoldering. the next involves removing the top cover to see if the meter coil is dead,if this is the case it needs to be replaced, or there is a broken lead somewhere. usually it is cause no. 1.
Dec 09, 2013 | Pentax K1000 35mm SLR Camera
I have a Pentax k1000, and was given a few vivitar and olypus lenses. They do not fit the camera. What can I do?????
Vivitar makes lenses with a variety of mounts. Lenses with the Pentax K-mount can be used on the K1000, lenses with other mounts can not.
Olympus lenses will not mount onto a Pentax camera.
You can sell the lenses, give them to someone with the appropriate camera(s), or use them as paperweights.
Nov 21, 2012 | Pentax K1000 35mm SLR Camera
How do I find out the year my Pentax k1000 was made using the serial number? The number is 8410441.
www.pentaxforums.com/forums/pentax-slr-lense-discussion/117545-lense-serial-number-database.html,this is one of the most comprehensive pentax serial number databases around,just click the link i have provided ,once you get there find the k1000 section and find your serial number and that should tell you what year it was made,good luck,if this helps you out please give me 4 thumbs up,it helps my rating,thanks
Feb 10, 2011 | Pentax K1000 35mm SLR Camera
Missing battery cap
I lost the battery cap of my K1000 on vacation...I replaced the battery and taped it snugly in place with a bandaid. It hasn't budged in a year! Just find a good strong tape and tape over the battery.
Aug 26, 2009 | Pentax K1000 35mm SLR Camera
Exposure needle not working
clean the battery cover and contact with a pencil eraser making sure the cap threads are also clean.
this is a fairly expensive repair if the meter or circuit board needs replacing ( no new parts are available ).
if the meter still does not work, and the K1000 is in good working order buy a inexpensive hand held light meter.
Jun 11, 2009 | Pentax K1000 35mm SLR Camera
Will no longer recognize 4gb sd cards
F4shsk1
are you sure the camera is a Pentax K1000.
the K1000 is a manual 35mm film camera, the only electronics in it are for the light meter. plus a circuit for the flash connections.
Apr 14, 2009 | Pentax K1000 35mm SLR Camera
Pentax K1000 back door change
I don't have the solution, but it may be in the Pentax K1000 Service Manual that you can get here : http://www.robertstech.com/manuals.htm
Mar 21, 2009 | Pentax K1000 35mm SLR Camera
What kind of battery does the pentax k1000 35mm SLR camera take?
Yes the K100 uses LR44 or G13. I would recommend the G13
Nov 12, 2008 | Pentax K1000 35mm SLR Camera
Pentax K1000 35mm SLR Camera Logo
282 people viewed this question
Top Pentax Photography Experts
pontelemon
pontelemon
Bill Eager
Are you a Pentax Photography Expert? Answer questions, earn points and help others
