Question about Dryers
Error code CL on Kenmore Dryer
Have cleanout lint filter, vacuum'd out lint filter housing, and cleaned the exhaust vent but can't get the blinking CL to stop. Can't select any settings to utilize the dryer. Anybody know how to reset the control or where else to perform dianosis?
    Top Expert:
  • Dryers Master
  • 9,472 Answers
The "Check lint screen" light is just a reminder to check the and clean the lint screen before or after each load. There is not a sensor that will detect if it's clean or dirty, it's just a reminder. The "Check lint screen" should turn off as soon as the dryer is started. If it never turns off then the control board would need to be replaced in order for the check lint screen reminder to turn off, however the check ling screen reminder light staying on will not effect the operation of the dryer.
Here is the control board to order.
The part comes with a 365 day, any part, any reason return.
Posted on Nov 03, 2012
SOURCE: Whirlpool Model LE7010XSNO. No Heat After Lint Cleaned Out
Those are likely possibilities. Also check the wiring for disconnected or burned terminals especially in areas that get hot. The element comes out easily to visually check it for breaks. If that's OK I'd look at the safety thermostat.
Posted on Jan 06, 2008
SOURCE: LG dlg5988W Gas Dryer - flashing "clean filter" light
i got the same problem and no repair man could help . i think i just got mine fixed 6-15-09 .what you do is go behind the dryer , remove the air duct and then remove the pipe that is inside the machine by removing one screw . this will give you access inside the machine .first clean as much as you can of the lint inside by vacuuming it . if you look to the left you will see 2 wires with a black button in the middle this is the ignitor ,clean it good because i think the dirt is not allowing it to light up . i did that and mine is working but the cooling light is still on .
Posted on Jun 16, 2009
tony2155
  • 64 Answers
SOURCE: Dryer runs fine but no heat
change the fuse in back of the dryer
Posted on Jun 23, 2009
jsrock516
  • 5911 Answers
SOURCE: Clean Dryer Lint Vent in Kenmore elite HE4
If you wish to clean the interior cabinet of the dryer follow these steps:
1. UNPLUG the dryer. Dangerous voltages are still present even with the dryer turned off.
2. Open the dryer door and remove the lint screen. IMPORTANT: You must remove the lint screen first in order to remove the blower fan housing.
3. Remove the lower toe panel directly below the dryer door by removing the screws under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off. NOTE: For better access, you can prop the front feet of the dryer up (a 2x4 works well).
4. Loosen the screws on the blower fan housing directly below the drum and remove. There's usually a small clip holding the cover in at the bottom that you may need to pull out to release. NOTE: You may also have to disconnect the auto dry sensor plug (yellow wires with white plug - use a small screwdriver to release the locking tabs) and/or ground wire to accommodate removal of the cover.
You should now have access to the dryer interior and the blower fan squirrel cage motor. Take the time to clean out the blower fan housing cover as well. A long bristle brush made for dryers works well at removing any lint inside the dryer in the hard to reach places, followed by vacuuming.
NOTE: After cleaning, you may experience a slight burning odor. This is normal as lint gets stirred up in the cleaning process and can settle on the heating components. The odor should dissipate after a short period of use.
If you have any questions, please let me know. I hope this helps you.
Posted on Sep 29, 2009
57 varieties
  • 1653 Answers
SOURCE: Samsung dryer DV448AEP/XAA - lint buildup
Yes this is rellatively normal as clothes are just not made the same way any more. You could turn down the drying temperature slightly and put in an anti static drying sheet but it won't make that much difference.
Posted on Oct 13, 2009
Testimonial: "I just had a repairman out because the dryer was no longer heating. The whole inside of the dryer was full of lint. It was awful. "
My kenmore dryer doesn't warm up
First check the lint screen. If it's caked up, clean it. Secondly, check the exhaust duct for any lint build up. The build up usually occurs where the duct exits the house. If it's blocked, clear the exhaust vent.
Sep 04, 2011 | Kenmore Dryers
Theres a problem with the drier as dof theres never any water in the tray anymore , and the drier is filling with fluff, takes ages too dry anything , what do you recommend plerase angela
Check your exhaust line and lint filter. Go outside and locate on the wall where the dryer exits the house. If you can, feel around the inside and clear the exhaust of any lint or debris. Next, check the lint filter. If it's packed, remove all lint from it and clean with mild soap and water. Put the filter back in it's place. Turn on dryer's normal setting that you most commmonly use and star dryer. Go back outside to where the dryer vent exits the house. Place your hand over the vent. You should feel hot air coming out at a pretty decent rate.
Jul 09, 2011 | Hotpoint Dryers
Kenmore elite model #110-67042601 is flashing a AF code
The AF error code for Kenmore Elite Oasis dryers with model numbers 11067032601, 11067042601, W10035200, 11067032600, and 11067042600 indicates that the dryer is experiencing an airflow problem. The Kenmore Elite Oasis owner's manual recommends four troubleshooting solutions to an airflow problem: clean the dryer's lint screen, ensure that the exterior exhaust hood connected to the dryer is unblocked, ensure that the vent connecting the dryer to the wall is clear and see that the vent is cleaned professionally.
Read more: Error Codes on Kenmore Dryers ' eHow.com http://www.ehow.com/list_7192588_error-codes-kenmore-dryers.html#ixzz1MuOgWsZC it is found also on this link above by clicking the link if you have any further questions please message me back and your dryer should be dlinted at least once per year to avoid dryer breakdown you can also see how to dlint your dryer by clicking this tip that I wrote http://www.fixya.com/support/r8732702-prolong_life_dryer I await your reply if you have any further questions Thanks Rick
May 20, 2011 | Kenmore 72982 Gas Dryer
This dryer does not appear to come apart in any way in order to clean out the lint. Can you tell me how to do this?
Good for you! Cleaning out the lint is the only way to keep your dryer from burning out the motor. And you're right, it won't come apart. I have had this dryer for years, thanks to cleaning out the vents.
First, UNPLUG YOUR DRYER.
I've found that my slightly-curved manicure scissors are the easiest tool to use for cleaning these vents. With the scissors closed, I use the pointy end to scrape up the lint, using a rocking motion-- don't scrape all along the vent, you'll only compress the lint into the mesh. Sort of how you would ice a cake: dab and lift. It's okay if you don't get absolutely all of it out, just do the best you can. If you can't find manicure scissors, a toothpick or a large, un-bent safety pin (be careful!) will do.
Apr 30, 2011 | Conair 1875 Watt Ionic Folding Handle...
Warning signal "linter filter" comes on and dryer
You don't have very much information here to give you a better diagnosis, like the model or the error code, but I'll take a shot at it. If you're thinking that the flashing list filter light is the error code you can relax. The lint filter light ALWAYS flashes at the end of a cycle or before you hit the start button to begin a cycle. This is just a reminder to check the filter.
If your dyer is displaying an E:01 code this indicates blockage in the venting system. Do the simple thing 1st. wash your lint filter with some dish soap and running water, lightly scrubbing it with your finger tips. After rinsing clean pat the filter dry and re install it in the dryer. While you have the filter out look down in the filter holder area and see if you have lint built up there. They make brushes for cleaning this area or you can use a vacuum cleaner attachment to reach in there and **** out the lint.
If you still have an E:01 error after doing all this you may need to have your house vent pipe cleaned. But before you do this check your vent hood where the dyer vent exhausts out of the house. If it's obstructed you found your problem
Nov 27, 2010 | Bosch Nexxt 500 Dryer
I have a Dryer model # 110.620.62103. It will not come on. All the buttons seem to be working properly and it has a new door switch. Help.
could have a bad thermal fuse located on the blower wheel housing part number 3392519,it's white.if the lint filter is on top it's in the back of the dryer if the filter is inside the thermal fuse is in the front of the dryer behind the duct that the lint filter slides into.check it with a meter,if that's not it it could be the computer board that's in the top console,it's around 100.00 bucks,hopefully it's the thermal fuse,if the fuse is bad you probably need a cleanout on the dryer,vac out the inside where the motor is,clean out the duct that the lint filter slides into and clean out the vent line,i use a leaf blower if the vent line is long.let me know what you find and next time all you have to do is push the door switch in and out,if it clicks it's good
Jul 20, 2010 | Kenmore 62062 Electric Dryer
I have a kenmore electric dryer model #110.63032102 and have to send our clothes through twice before they dry.
Hi and welcome to FixYa. I am Kelly
If your are sure the dryer is heating then there are a few things you muct check.
1. First of all remove the lint filter.
a. Inspect all of the air passages around the lint filter for lint build up.
CLEAN with a vacuum and crevice tool
b. Wash the lint filter with vinegar and water then soap and water. If you have been using dryer sheets in the dryer the material fromthe fabric softener sheets cakes onto the filter. The filter appears clean but will not allow good air flow through the dryer.
c. Remove the vent ducting from the back of the dryer. Clean out all of the ducting inside the dryer that you can reach. If you have to use a folded wire coat hanger to remove the lint in the dryer along witht he crevice tool.
d. Continue to clean the exit ducting on the house side of the ducting all the way to the wall exit. Go outside inspect and clean the vent flapper on the outside of the house.
e. After doing all of steps a - d above. While the vent is disconnected from the dryer start the dryer and check for a strong HOT air flow from the dryer vent exit hole. If there is not a strong HOT air flow there is still a problem with lint build up or the blower fan impeller is loose / broken on the motor output shaft.
Everything listed above assumes that the dryer is still heating. If the dryer is not heating then respond here and we can go from there.
Diagrams of your dryer can be found here:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.63032102+&=part+number&pathTaken=partSearch
Thanks for using FixYa.
Kelly
Apr 14, 2010 | Kenmore Dryers
Kenmore series 90 electric dryer: exhaust air is
that's normal,obviously you haven't cleaned out your dryer and vent line,nobody ever tells the customer when you buy your dryer that it should be cleaned out at least once a year so you don't have a fire more so if it's a gas dryer with an open flame inside the dryer,you gotta vac out the inside where the motor is,clean out the duct that the lint filter slides into and blow out the vent line,i use a leaf blower to clean out the vent line,take it off the back of the dryer,stick the leaf blower in the line if it's a long run if it runs through the wall and to the outside flapper and blow all the **** out of it,also if you have a shop vac put it on blow and blow off the motor,you won't believe how much lint comes off the motor even though it looks clean,so vac out the inside of dryer,clean out the lint filter duct and blow out the vent line
Dec 18, 2009 | Kenmore Dryers
My Miele T8322 Tumble dryer turns off before the clothes its fully dry even in Extra Dry mode. The vent pipe is clear. Is there any kind of adjustment or do I need to get a new sensor under warranty...
IS THE DRYER PUSHED UP AGAINST THE VENTING IN THE BACK OF THE DRYER? IT MAY BE CRIMPING THE EXHAUST MATERIAL CAUSING A RESTRICTION.
IF THAT IS O.K., DISCONNECT THE EXHAUST AND RUN A LOAD OF LAUNDRY THROUGH A NORMAL DRY CYCLE.
IF THE DRYER DRIES THAT LOAD O.K., THERE IS A RESTRICTION SOMEWHERE IN THE EXHAUST. ALSO, CHECK THE LINT TRAP. IF THERE IS A WHITE CLOUDY FILM ON THE LINT FILTER, TAKE A WIRE BRUSH AND CLEAN IT OFF. IT IS RESTRICTING THE AIR FLOW AT THE FILTER.
CHECK THE LINT FILTER HOUSING FOR A BUILD UP OF LINT. IF THERE IS, USE A CENTER CARDBOARD FROM WRAPPING PAPER ATTACHED TO THE END OF THE VACUUM HOSE. FLATTEN THE CARDBOARD TO FIT INTO THE FILTER SLOT AND CLEAN OUT THE LINT.
Apr 22, 2008 | Dryers
No air blowing in dryer
These dryers are not much different mechanically then Kenmore 4-wheel units. One common problem I've seen with this design is lint buildup in the lint filter housing. Along with cleaning the entire machine and vent system regularly you can use a vacuum with crevice tool to get most of it. To clean it throroughly remove the front panel and two screws holding the filter housing near the top.
Remove the wire from the sensor on the upper right and lift the housing up and off the clip below. Another possibility is a problem with the blower. reach in from the vent and make sure its intact
Dec 26, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Dryers Logo
769 people viewed this question
Top Dryers Experts
