Question about Kenmore Elite HE5t Washer
Machine well not turn on it has f 70 - Kenmore Elite HE5t Washer
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
NOTE: I do not recommend checking voltages unless you have experience and feel safe and confident in doing so, otherwise I recommend calling a service technician to diagnose and repair your washer.
QUICK TEST
  1. Lock the control by pressing and holding the cycle signal button.
  2. Press the Power button.
  3. If the lock light flashes when you press the power button it indicates the center interface was able to take the input and the Right hand User Interface received the DCV signal from the Center User Interface but since the display did not light. This indicates an issue with the Right hand user Interface.
NOTE: This is a quick test you can try to get to a quick resolution, but remember if the Lock Light does not blink once the power button is pressed you will need to follow the standard checks below.
  1. First try to put the washer into the Diagnostic Test Mode per the Tech Sheet by pressing any key except Stop/Cancel and the Control Lock for 2-5 seconds on and 2-5 seconds off 5 times as outlined on the tech sheet; at this point the Right Hand Interface should light up.
  2. IF the Right Hand Interface did not light up in Step 1 check for 5 VDC on the UIP3 wire connector coming off of the control board to the Right Hand Interface from (Pin 1 to Pin 2) and from (Pin 1 to Pin 3). If you do not have the 5 VDC then replace the Machine Control Board.
  3. IF the Right Hand Interface did light up then remove the J003 connector. This is the 9 pin connector that goes between the Right Hand Interface and Center Interface.
  4. Short across (Pin 7 to Pin 8) on the Right Hand Interface.
  5. IF the Right Hand Interface did light up then replace the Center Interface due to a failed "Power" key.
  6. IF the Right Hand Interface did not light up then check from (Pin 1 to Pin 7) and (Pin 1 to Pin 8) on the right hand interface at the J003 connector you should have between 1.2vdc to 1.5vdc.
  7. Also check for DC voltage on the J004 (10 Pin connector) on the Right Hand Interface from (Pin 1 to Pin 2) and from (Pin 1 to Pin 10. You should have between 1.5vdc to 5.5vdc.
  8. IF you do not have the DC voltage at either of the checks above replace the Right Hand Interface.
NOTE 1: The #1 Pin on both the J003 and the J004 is identified by the white wire. NOTE 2: The picture below is the J004 connector that goes from the Center Interface to the Right Hand Interface and the red arrows are pointing to the check points for the 4 to 5 VDC and the J003 connector.
Image 1 Image 2
Post back your findings and your model number.
Posted on Nov 03, 2012
Mx2300 write code f2-70 after replacing the black cartridge
F2-70 is indicating an improper toner cartridge K.
If you have just changed the black toner cartridge & the error appeared then the new toner is at fault.
Replace the toner cartridge with another cartridge, turn the machine off & back on & the machine should reset.
Hope this helps.
Dave.
Jan 09, 2017 | Sharp Mx-2300n Copier Color Mx2300n...
70 series top loading washer
probably no parts for a machine that old
consider getting a new unit that is more power and water efficient
Jun 25, 2017 | Kenmore 24032\24036 Top Load Washer
HOW CAN I CLEAR ERROR CODE 70 .Brother DCP -195C
Brother Printer is one of the best printing machine and comes with bundles of excellent features. Brother Printing machine is known for its high quality printing feature and its customer value. But sometimes user encounter various kind of problem while working with printing machine like Driver installtion and upgrade issue, Printer Set up/Configure issue, Paper Jam issue, Spooler error, Machine unable to print , Error code and so on. And being as a novice user you don't know how to fix them all issue then its recommended to get in touch with Brother Printer Support Experts for on the time assistance.
Here in this post we have mentioned about Brother unable to print 70 error message and how to fix it.
Require Sequential Steps to Fix Brother Printer Error Code 70
1. First you need to turn off the machine for few minutes then turn it ON again. If problem not gone due to turn ON/OFF process then you have to open the back cover.
2. Now carefully pull the green tab at the left and the right sides then fold down the fuser.
3. Always remember one thing there is no paper stuck inside the roller.
Note: If user doesn't find any kind of paper inside the roller then close the cover carefully. But if paper stuck inside the roller then gently remove it or close the cover.
4. Finally Turn ON the printing Device, if it shows ready it means unable to print 70 error has been fixed.
Above listed steps definitely resolve your printer error. If stil you are troubling with same error then its recommended to get in touch with Brother printer support experts at yahooemailsupport or pick a phone and make a call on toll-free Brother Printer Support Number 1-833-327-1999.
Brother Printer Customer Support Toll Free Number USA
Mar 29, 2013 | Brother DCP-195C A4 Colour Inkjet...
Help with Kenmore washer 70 Series
I called a repair man. The machine, it turns out is gear driven, and all the gears were shot.
May 27, 2009 | Kenmore Washing Machines
Slow cold water only fill kenmore heavy duty 70 902202
remove fill hoses and inspected for debris or cloggs ,,,,
Dec 30, 2008 | Kenmore 22422 Top Load Washer
Kenmore 70 series won't turn on
Sounds like the fuse may be gone. If your front panel comes off it may be in there.
Jun 01, 2008 | Kenmore 22422 Top Load Washer
Looking for Parts for Solis SL 70
I also called 888 437 8340 and they sent the switch right out. Very helpful phone rep. The company is called Empire Fulfillment.
May 23, 2008 | Solis Crema SL-70 Espresso Machine
Copier problem - service code F1-70
F1-70 is communication trouble between the machine and the sorter finisher. Check the cables connecting the copier and the finisher and power off and on machine. Should clear the code. If problem persists, may need a new board.
I would also check the ground between the copier and finisher.
Don't forget to rate your answers, please!
May 17, 2008 | Sharp AR-C160 Color Copier
IBM Wheelwriter 70 memory
You can hook up a standard computer monitor to the typewriter, but it won't recognize color, and sometimes on eBay you can find IBM POS (point of sale) monitors that will work on the typewriter. Do you still have the typewriter?
Feb 12, 2008 | Lexmark Wheelwriter 1000 Typewriter
Kenmore Elite HE5t Washer Logo
41 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
