Question about Dell Studio 1737 Laptop
I was replacing the keyboard on my Dell Studio 1737 laptop. I guess I was a little heavy handed and popped the connector for the keyboard from the motherboard. I then proceeded to superglue the piec
I have acetone to try to swab the glue off the motherboard area. When powered up the computer the mouse works, it has power but does not recognize the keyboard.
    Master:
  • 380 Answers
I wluld guess that the wire tthat you glued does not make a good contact ...
Posted on Dec 14, 2014
Musheer
  • 19 Answers
SOURCE: dell studio 1737 mousepad not working
You can try the steps below and this definately should fix the issue.
Download and install the latest touchpad driver:
Uninstall the touchpad driver:
1. Click the Start button, point to Settings, and then click Control Panel.
2. When the Control Panel window appears, double-click the Add or Remove Programs icon.
3. Locate the software for your keyboard or mouse in the list below.
• Microsoft IntelliPoint software
• Logitech software
• DellTouch software
• Synaptics software
• Alps software
• Set Point software
4. Click to highlight the device name and then click the Remove button.
5. Follow the prompts to uninstall the input device driver/software.
Download and Install the Latest Touchpad Driver Available:
Please follow the link below to install the latest touchpad driver.
http://tinyurl.com/5k9tth
1. Locate “Input device drivers” and click on (+) sign next to it.
2. Select “Touchpad”, click Download Now. You may receive a warning and an option to run or save the file.
3. Click Save.
4. When the Save As window appears, designate a folder (desktop) to save the file that is being downloaded, and then click Save.
5. When the download is complete, go to desktop and locate the same file.
6. Right click on it and run as administrator.
7. Click on allow and follow the simple instructions to update the touchpad driver.
Please do not forget to rate the solution.
Regards,
Musheer.
Posted on Jun 12, 2009
T I M B O
  • 29 Answers
SOURCE: Dell studio 1737 speakers crackle and pop.
My best guess is, if they crackle with the speakers but not the headfones,  then replace the speakers. Must be a lose wire or something of that nature.
Posted on Jul 27, 2009
SOURCE: My Dell Studio 17 (1737) will not power on. I
You can use the Dell mediaplayer button above F5 button to switch on the system.
Posted on Nov 16, 2009
boysisiw22
  • 11 Answers
SOURCE: I have a dell studio 1737 motherboard f238n with
what is the color of the LED ight on the power button? if it is a steady amber it might be a NO POST situation. if the LED lights up normally without the fan spinning and no display on the monitor, then it is a NO VIDEO issue. you can try to power it up and at the same time initiating diagnostics by holding down the <Fn> key while powering on the system. It should show up after a few seconds with the PSA (Pre-Boot System Assessment running.
another way of testing for video integrity will be the LCD BIST. it is done by holding down the <D> button on the keyboard while powering the system on. It should show color bars during the test. you can also try to drain the flea power by removing battery and the adapter then depressing the power button several times.
if those fail, then a motherboard replacement will be the best resolution.
Posted on Feb 26, 2010
SOURCE: dell studio 1737 laptoplost BIOS password called
BIOS password is NOT able to be Cleared by taking battery out, is stored in NVR. Is impossible to hack, crack, unless get special DELL code. Must contact DELL. provide proof of ownership, a receipt etc, then they will send you special code to enter. OR look for pay For site on internet.
Posted on Apr 04, 2010
Why does dell studio 1558 backlit keyboard not work
If the keyboard has been replaced recently it may not be connected correctly. If not, either it does need to be replaced or you may have a bad driver. For a bad driver you can go to www.dell.com, go to Support By Product and search your service tag and find the driver for your keyboard and download/install it.
Jun 14, 2014 | Dell Studio 1737 Laptop
Dell Studio 1737 with Back lit keyboard but Cap Lock Doesn't Light, replaced Keyboard less than 3 months ago, light worked then and went out just recently.
I'd try a different keyboard and see if the caps light works on that - so you can confirm whether it's the keyboard, or computer.
Oct 19, 2012 | Dell Studio 1737 Laptop
Dear Janice,
The light under the Caps key must have burned out. Take your laptop to a Dell service center and get it repaired.
Oct 19, 2012 | Dell Studio 1737 (Studio 1737-RubyR) PC...
I have a Dell Studio 1737 - I replaced the motherboard and now there's no power. Just a Quick white flash of light
Are you sure you reconnected the main power connectors from the internal power supply to the mainboard, or motherboard? It sounds as if you haven't reconnected it completely, and some of the pins are not inserted into the block connector all the way.
-a.
Jun 24, 2012 | Dell Studio 1737 Laptop
Keyboard on my dell studio 1737 doesn't work, mousepad works, keyboard does not
It could be one of two things, the ribbon cable that connects the keyboard to the motherboard is disconnected.
Or it's a defective keyboard.
Keyboards for laptops are relatively inexpensive, anywhere between 20-40 dollars on ebay.
Buying a new keyboard and having a computer technician install it, which takes ten minutes, should be a good investment, rather than getting a new computer or sending it back to dell.
Hope this helped.
Apr 18, 2011 | Dell Studio 1737 Laptop
The keyboard on my studio 1737 dell laptop will not allow me to enter any characters. no button on the keyboard works.
Try using a live CD of some other operating system, preferrably Linux to check if it is a hardware problem or not. If it is a hardware problem then you better contact a Dell Service Centre. If it is a software problem, use the Windows CD to repair the operating system.
Apr 15, 2011 | Dell Studio 1737 Laptop
I spilled tea on my laptop. A day later the keys are tyoing the wrong letters.
When this happens, you should fully disassemble the laptop & thoroughly inspect its inside. Look for any traces of liquid on the circuit boards & on other components. On circuit boards, liquid damage appears in the form of whitish traces. These needs to be wiped off. This can be done using a tooth brush moistened with few drops of hand sanitizer liquid.
Check all internal connectors & make sure that no liquid seeped into them. Dry them if needed.
When you are done, re-assemble back the laptop.
If the liquid fell on the keyboard & you found out that the keyboard is no longer working, then you will have to replace the keyboard.
Oct 26, 2010 | Dell Studio 1737 Laptop
How to remove the keyboard on a dell studio 1737
You can get the service manual for you Dell Studio Laptop from the following website (http://support.dell.com/support/edocs/systems/studio1737/en/index.htm)
If you find the solution please do not forget to rate the solution
Jul 14, 2010 | Dell Studio 1737 Laptop
Keyboard button gives me ;k
keyboard has gone bad, you need to have it replaced - you can do it, try ebay for a replacement keyboard
Dec 08, 2009 | Dell Studio 1737 Laptop
Jul 27, 2009 | Dell Studio 1737 Laptop
Dell Studio 1737 Laptop Logo
202 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
