Question about Bissell 1425 Little Green ProHeat Handheld Steam Vacuum
Lost manual I need to know the basics of use for this, it is my fiances and there isn't a manual for it anywhere... Basically what end to put the water in so I can use the darn thing!!!
  • Anonymous Jul 27, 2008
    I need to know how to operate the Bissell Little Green Proheat
    Scholar:
  • 57 Answers
If you have adobe "which you can download for free at adobe.com" you want adobe reader you can print out this free manual. http://www.bissell.com/images/UserGuides/1400_206.pdf
Posted on Sep 14, 2007
  • R J
    R J Sep 14, 2007
    I also have it in file for use here in Fixya manuals.
    :0)
SOURCE:
HENRY VACUUM CLEANER HI LO SWITCH BROKEN CAN I DISABLE IT TO STAY IN HI MODE?
It can be disabled to stay in high mode, but you need to know what you are doing. It basically involves removing the small PCB and connecting the motor wires directly to the on/off switch. The hi/lo switch can be left in place (although not connected) or removed and a blanking plate put in it's place. You can leave a hole as this is a potential hazard and against government regulations.
Feb 28, 2015 | Numatic Henry Bagged Canister Vacuum
How to change coupling machine end
Hi There, Alec from VacuumSpot here. If by coupling machine end you mean Kirby Hose End Piece <---- (This is a link so you can see the part), then it is really easy. Basically submerge the end of the hose and the coupling in hot water and once the plastic is warmed up you twist the coupling off the end of the hose. PLEASE NOTE - do not use boiling water you will cause the hose to melt - just hot.
Dec 06, 2012 | Kirby G4 Bagged Upright Vacuum
How to clean a washable electrolux filter
Hi There,
Ok so i am going to assume you are talking about an Electrolux filter that is basically a rectangle shape with a hard plastic outer and folded corrugated filter material in the middle. The link I put to Electrolux filter would be a good example. Basically I would caution you against washing it. I know the packaging says that it is washable but what I have found is that the pores of the filter material are too fine for water to pass through. What will happen is that the vacuums suction will wedge tiny bits of dirt and dust in the pores and water will not necessarily flush it out. What is far more likely to happen is that it will wash out a fair amount but leave a portion in the filter to set and therefore continue to block suction.
You are better to use an air compressor or simply tap the filter out on a piece of newspaper and change it every year or so.
Of course if your filter is more like a Electrolux UltraActive filter which is basically foam then you simply rinse it out like a kitchen sponge and make sure it is bone dry before putting back in the machine.
Jun 26, 2012 | Electrolux Ultrasilencer Green Canister...
I have a Bissel Pro Heat Plus and I used it once, one year ago. I may be using it wrong, as my carpets were wet and there was no return (dirty water). If I remember correctly, going forward wets and...
It has only one tank that serves two purposes. It holds the clean water and collects the dirty water, so you only have to empty/fill one tank. If you check reviews of this machine you will see that they basically stop working correctly after a very short time, if I was you I would just contact their customer service at this number 1-800-237-7691
May 16, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
Lost my manual to "Animal". Need to know how to
The manual is located on the below link.
http://dl.owneriq.net/6/6b31ee20-0d21-3fc4-6d61-0e7daeb1dd56.pdf
Place wand in upright position.
Press release catch and slide wand to end of hose.
Slide wand cap back and place wanted tool on handle.
This information can be found on page 10 of the manual.
Mar 01, 2011 | Dyson DC07 Animal Bagless Upright Cyclonic...
Lost operating instructions - need basic instructions
If you go to www.Hoover.com, , on the lower left you will find a link to download manuals. Put in your model as instructed.
Feb 26, 2011 | Hoover SteamVac Carpet/Upholstery Deep...
Have lost Manual to DC05 and I am unsure how many filters there are that need to be cleaned as I feel it has lost some suction.
Hi there VacuumGuru here. There are 2 filters for your machine, one is below the dirt chamber and the other is underneath the handle. If you have lost your suction it is most likely the washable filter that is to blame. There is a manual available for free download here as well to help you out.
Basically when ou remove the spongey blue insert from your washable filter you should be able to hold up the other bit (white with a coloured plastic collar) to the sun and see light through it. If you can see no light then it will need to be thrown out and replaced.
Hope this helps!
Sep 23, 2010 | Dyson DC05 Bagless Canister Cyclonic...
Hiyah i need to know how to get the pipe out so i can clean the stairs
Hi there smartalec from NelsonVacuums.com.au here. Basically there is a colour coded (yellow if your vacuum is the one pictured) big button on the front of the machine where the pole joins the rest of the body just above the yellow part that is on top of the clear bin. Push this in and lift the handle up. Keep sliding the handle up until it make a click sound then press the little button at the end of the flexible hose which will now be at the bottom of the rod. The rod will now come completely off. You can put the cleaning tools in the end of the flexible hose and be cleaning in no time.
Happy vacuuming! :)
Aug 26, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
No manual - how to replace belt?
I have the Kenmore 34723 Grab-N-Go Upright Vacuum. It has two screws on the superior surface of the flat part of the bottom section. They say something like Quick Belt Check Lock/Unlock. When you turn both of the screws using a flathead screwdriver to the unlock position the screws become a bit loose but nothing happens. I flipped it upside down trying to figure out how to remove the bottom spent a half hour doing that and then an hour on the net trying to find a manual or explanation. When I went away a couple of hours and then came back I realized that I was making it too hard. the screws were present on the top part of the piece because it was the top part that will pop off. Basically I used my fingernail to pry the blue fiberglass piece away from the black plastic piece on the front, and Walaa! The blue fiberglass popped off. At that point you are able to see that the belt wraps around the brush and passes backwards to hook onto a metal rod that sticks out on the right. Mine had actually just slipped off and so I reset it. You need to slide the brush up out of the groove it is in in order to do this. When you put it back into the groove make sure it is the same way you got it out.
Then just press the blue fiberglass back on and tighten the screws. I think after figuring out how to take the top off the hardest part of the procedure is figuring out how to put the screws back the way they were. Note the screws don't come out all the way, just partially, so don't force it. The problem arises because the screws only go in one way and will spin around and not catch if you do it wrong.
Mar 02, 2008 | Vacuums
Bissell 1425 Little Green ProHeat Handheld Steam Vacuum Logo
183 people viewed this question
Top Bissell Vacuums Experts
CJ C
CJ C
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
