Question about Kenmore Refrigerators
Bottom of kenmore frig bulging upward with water
970678426
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 03, 2012
  • 1 more comment
  • hollymclean5
    hollymclean5 Nov 03, 2012
    It is 970678426 kenmore
  • Richard Roth
    Richard Roth Nov 03, 2012
    That model number comes up as a dryer.
  • hollymclean5
    Oh, apparently it's a Sears number not the model number. We can't find any other number.
2 Suggested Answers
aasc
  • 1606 Answers
SOURCE: changed my water filter on my Kenmore
You have air in the line from the new filter . Run about 1-2 quarts of water thru the dispensor to remove the air in the line .
Posted on Jun 13, 2010
I saw your response to another Kenmore frig and I have a similar problem I want to ask you about. I have a Side-by-side Kenmore frig(model 106.9555722) that we've had for 16 years!! Other than r
I have seen this one other time in all my years of appliance repair and changing out the "water inlet valve" corrected the problem. I don't have an answer to why it did, but it did. Here is the valve for your unit.
After you change the valve be sure to purge the water line for a good 5 - 10 mins to get all the nasty water out. Keep me posted!
Nov 24, 2012 | Kenmore Side by Side Refrigerator
I have a water leakage coming out the bottom of my kenmore refrigerator model 52559100
check your defrost drain line. can be located in freezer section. also if you have a filter at the bottom make sure the housing is not cracked. If your frig is cooling then the coil is going to be doings its job
Jun 08, 2012 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water on the bottom of the frig under the crisper
some model's have a drain under criper's ck for drain and clean it . if no drain there its in the back just below the freezer .and can be seen from the back and if found clean it also . this water should be able to get to the pan under frig and not on the bottom of frig .. mm hope this helped .
Oct 21, 2010 | Kenmore Refrigerators
Side by side frig/freezer. Freezer auto defrost
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Jul 03, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Changed my water filter on my Kenmore refrigerator. Now the water dispenser keeps dripping? The water filter is located at the bottom of the frig.
Jun 13, 2010 | Kenmore 57029 Side by Side Refrigerator
Ice maker no making ice.water not filling tray
you have a bad water inlet valve located on the back bottom of frig behind the bottom panel-mike
Jan 26, 2010 | Kenmore Refrigerators
Remove faceplate surrounding the indoor ice/water dispenser
under the facial plate, if you get way down and look upward, you can see two slots to insert a flat screw driver. Pry it open and there ya go...good luck
Apr 24, 2009 | Kenmore 54662 / 54664 / 54669 Side by Side...
Remove faceplate in door of a kenmore frig.
If you look at the bottom of the facial plate, underneath. There are two slots to insert a flat screw driver. You should be able to access everything once you take that off. Good luck
Water on btm of glass shelves and water in bottom of frig
sounds like you have a gap in the door seal, which results in condensation forming inside unit. Use a blow dryer to heat the seal around the door and ensure that the fit is tight.
Jan 07, 2009 | Kenmore 72073 Top Freezer Refrigerator
Kenmore 25.8 side by side with water freezing in the bottom of th
It sounds like the freezer drain is plugged up. When the frig goes into the defrost stage it melts the frost biuldup on the evaporator and the melted frost goes down a drain that is behind the evaopator cover. When this dran is plugged the water has no place to go and over several defrost cyles will actually run into the bottom of the freezer section. When the defrost cycle is over and the frig starts cooling again, the water freezes in the bottom of the freezer.
Nov 11, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
