My front loading door does not activate the door lock to start the cycle LG washer
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 03, 2012
  • 5 Answers
SOURCE: GE Energy Star WCVH6260F Front Load Washer: door locking problem
http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
Had the same problem, this fixed it!
Posted on Oct 31, 2008
mgprice
  • 744 Answers
SOURCE: He5t Kenmore ELITE front load washer flashing f35 code
Hi, Both of these fault codes point to a pressure switch issue. If you remove the top panel, three screws in the back, you will have access to the pressure switch. With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions. If the fault codes return after diong this, you will likely need to replace the pressure switch. If you have any further questions or concerns please feel free to comment again, Good luck.
Posted on Jul 07, 2009
  • 4090 Answers
SOURCE: Kenmore Elite HE3 front load washer door locking mechanism issue
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Posted on Aug 01, 2009
SOURCE: My Affinity Front load washer, Model #ATF7000ES1
I am having this same exact issue, have you figured out what the was?
Posted on Sep 11, 2010
SOURCE: amana front load washer door locked with door open
To get the front off. (All screws look to be #2 Phillips Screws)
1. You have to unscrew (2) phillips screws from the back that holds the top on.
2. Slide the top off. (slide towards the back)
3. Then where the control panel is there is about 4-6 screws holding that plastic piece on, take those out this will allow you to pull the control panel up and out of the way.
4. At this point you can unscrew the 4-6 screws in the door area that holds the front of the washer on, once you unscrew those screws there is a tab that you have to lift the front over to pull the front off. This will allow you access to the locking mechanism.
5. There are only 2 screws holding te locking mechanism on.
Posted on Nov 18, 2010
De error message on wash machine
For LG washers, the DE error indicates a problem with the door lock. If you just started the cycle and the error occurred, then the door couldn't lock properly. (The machine turns off and indicates the error so that the water won't flood your laundry area.) First check if there are any clothes between the door and the frame. If needed unplug the washer for 5 minutes. Then restart the machine try to open the door. If you pressed Pause, wait a minute or two. If the error occurs at the end of the cycle, it may not be unlocking properly.
The latch mechanism may have failed or the PTC sensor in the latch has failed. The entire latch would need to be replaced. Here's one: http://www.appliancepartspros.com/lg-door-lock-switch-6601er1004c-ap4441836.html . If the door locked failed with the door closed or the washer is under warranty, contact LG or a repair professional for service.
I hope this helps.
May 18, 2015 | LG WM2688H Front Load Washer
Lg wm1832cw de error occurs when starting the washing. after multiple tries, it might start
It is a door lock error caused by bad door lock switch or if your door is very hard to swing closed because the hinge is corroded, then the hinge could be causing the door lock to error.
Jan 04, 2014 | LG WM-2277HW Front Load Washer
2487 LG front load washer
sounds like a door lock issue , i would replace the door lock if you are not getting any error codes.
door lock error would be a DL
Feb 17, 2013 | LG WM2455 Front Load Washer
How to test door lock on lg wm2277h washer
see pics u can alsoi bypass it if u like but not recommended
Nov 21, 2012 | LG WM-2277HW Front Load Washer
Whirlpool duet washer, door locked light on door open no other lights on unable to set control
The control can be locked to keep the buttons from activating during external cleaning or to help from small children starting the machine.
To activate or deactivate press and hold the "end of cycle signal" button for 3 seconds.
Jun 21, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Everything works but it does not spin
There is an auxiliary switch in the door lock and switch assembly that is activated at the end of the wash cycle for the machine to advance to the spin cycle. This is a safety feature to prevent the door from opening during the spin cycle and the machine will not spin unless the switch is activated. The machine works except advancing to the spin cycle and this signifies that the auxiliary switch cannot be activated and the door lock and switch assembly is faulty. Replaced the door lock and switch assembly (part #131763202) to address the issue. Click on the link below for the complete and detailed procedure.
Replacing the Door Lock and Switch Assembly on Frigidaire Affinity and Gallery Front-Load Washing Machine
Dec 29, 2010 | Frigidaire Affinity ATF7000E Front Load...
My lg door will not unlock
this kind of door lock is called PTC door lock.It is designed for protecing you from opening the dooe during the washing and spining cycles which may hurt you.So, if you want to open the dooe during cycles,pls press "stop",then ,wait 2 mins,you will be able to open it by then.the other situation is that,the power is cut off during working cycles,solution is:re-start the washer and directly open the door.Pls note that this kind of lock has to work under power
Mar 14, 2010 | LG WD-12126RD Front Load Washer / Dryer
Mar 12, 2008 | GE Energy Star WCVH6260F Front Load Washer
LG WM1814CW Front load washer PF continues to come on and stops cycle
Seen This before Main control board fixed it It would go through most of the wash cycle and just quit no errors but PF
Jan 29, 2008 | LG WM1814CW Front Load Washer
Washing Machines Logo
11 people viewed this question
Top Washing Machines Experts
