Question about Canon PIXMA® MP530 All-In-One Printer
Printer error 5200 on a Canon MP530 - Canon PIXMA® MP530 All-In-One Printer
  • 159 Answers
SOURCE: Canon MP530 U052 Error
The dreaded U052 error means that the 'chip' fitted to the Cartridge is not responding .. Canon (like all printer mfgs) makes all it's profit from selling Ink .. so they fit these chips to try to prevent you refilling or using a 'compatible' replacement cartridge
You have to move the chip from the Canon cartridge to the 'compatible' and (it seems) the chips are particularly sensitive to static / damage .. many people end up blowing the chips during the swap over .. or even when fitting the original genuine cartridges to a brand new unit for the first time ...
If the unit is brand new, take it back and demand a replacement ... if you have just swapped over the chip onto a compatible cartridge, you can try buying a genuine Canon cartridge (which will have a new chip) = hopefully that will do the trick
NB. I have seen some suggestions that canon's have a 'Service Mode' that allows you to disable the cartridge chip checking and allow you to print no matter what .. however I've never found any details ... perhaps some-one else has the details ??
Posted on Mar 22, 2008
SOURCE: canon mp530 getting error message 6a00
HI Guys 6A00 error usually cant't be fixed according to the service centre, I was lucky and actually bought an extended warranty, the service centre said that the MP530 are a good printer and worth fixing as they don't see many at all compared to other models and other brands. There was a broken piece of hardware that something to do with the print carriage. cheers vailey
Posted on Apr 18, 2008
uxair shah
  • 812 Answers
SOURCE: canon MP530
Hey welcome to fixya. Hope u 'll be fine
The 6500 error code is a logic board error code. The PCI Bus error is detected by the ASCI. Sounds like it needs new logic board. Solution is first of all you can try to reset your printer -
  • Turn the printer off with the Power button (if available).
  • Disconnect the data cable from the printer.
  • Unplug the printer's power cord for approximately 10 minutes, and then plug it back in.
  • Turn the printer back on. If this works you're done,
If it not works then try following
  • After confirming that the printer is powered on, open the paper output tray.
  • Open the top cover and wait until the print head moves to the center.
  • Open the inner cover and check that ink tanks are properly seated.
  • Properly seated
  • Press down on each ink tank until a click is heard.
  • Close the inner cover and top cover
if reset method not works for you then you go for the new logic board replacement
Best of luck
Kindly keep thumbs up in Rating if it is helpful,
THANKS & Keep using Fixya
Posted on Apr 06, 2010
alpug
  • 1961 Answers
SOURCE: Canon Printer MX328 displaying message "Printer
Please reset the printer
1. Turn off your printer
2. Press and hold the STOP/RESET button
3. Press and hold Power ON button
4. While holding the Power ON button, release the STOP/RESET button
5. While holding still the Power ON button, press twice the STOP/RESET button
6. Release the Power ON button
7. Wait until it display an "idle" message. It will take about a minute.
8. When "idle" appear, open the top cover to expose the cartridges.
9. Lift up the cover for cartridge holder and take out both the black and color cartridges
10. Return the cover of cartridge holder and turn off the printer
11. Return the top cover and turn on the printer again
12. After the printer initialize, return the cartridges.
1. Press and Hold the STOP/RESET button and wait until it self restart.
2. Release the STOP/RESET button the the printer is restarting.
3. Wait for a few seconds
Posted on Nov 16, 2010
dhorsefield
  • 286 Answers
SOURCE: how to fix error code 5200 on canon printer MP258?
Here's the procedure. This code is normally encountered after refilling an ink cartridge and replacing the cartridge. Turn off printer. Hold down Stop/Reset button with one hand and turn printer on with other hand. After green light comes on for the ON button, press the Stop/Reset button two times and you should see the green light blink off and the orange alarm light blink "on" with the first press and then the green light comes back on for the power button and the orange light goes off with the second press (if you did it correctly). Now, you need to hold down the ON button about five seconds, then let go to shut OFF the printer. When you turn it back on, the printer should be back to the factory original condition. Make sure you set all your printer properties the way you want them again from your printer properties dialog boxes because some of the settings may have been stored in the printer's EEPROM, which you just reset to get rid of the offending alarm code.
Posted on Feb 10, 2011
Error code 5200
I own this printer and after looking all over the internet for solutions and trying all of them I finally, as a last ditch attempt replaced all the ink cartridges. I also wiped down the inside of the printer carriage (making a point to wipe both where the ink comes out and where the metal contacts are) and voila.
Nov 19, 2013 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA MP530 All-In-One InkJet Printer Canon mp530 error 6a00
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.
Clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like
Dec 15, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Hello
Unfortunitly this is not an easy fix. IF you still have under warranty you can contact Canon and they will fix it. If its not under warranty they can refer you to the nearest Canon Service center.
The 6A00 error is an internal error which can be caused by one of the following things.
- Sheet feed unit - Logic board - Purge unit
Good Luck
Error 6502 canon MP530
Hello
Try it for a canon
Error Code 6502 appears generally after chaging a cartridge.
Solution:
  1. Unplug the printer.
  2. Remove the faulty Cartridge
  3. Plug in the printer and press and hold power button
  4. Keep it held down. Press Resume twice, and this should reset the fault.
All Best: Pineworks
Jun 07, 2009 | Canon PIXMA MP530 All-In-One InkJet...
What does error code 5200 means
ok and error 5200 ushally means it has something to do with the printhead but we are going to try this just because it is the easyest and known fix for this error.
First off unplug the printer from the computer
secound turn the printer off
third unplug the printer from the wall
wait a minute
plug the printer into the computer then into the wall then turn the printer on
do a test print
This should have solved your problem but if it didnt please let me know and I will see what other things we can try to help you fix this issue.
Oct 01, 2008 | Canon PIXMA MP530 All-In-One InkJet...
MP530
The alarm light is blinking. It says Error 5200? What is that?
Email me at : eunice@idig.net
Sep 09, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon mp530 getting error message 6a00
Jan 30, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon MP530 - "scanner error" mesage
I've some problem whit the printer and my firs check printer make only bips
Sep 17, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA® MP530 All-In-One Printer Logo
281 people viewed this question
old marine
old marine
