Question about Ricoh Aficio AP3800C Laser Printer
A5 paper jam every time
Hello - I am trying to print A5 duplex from tray 2, but it jams on exit from the tray giving a misfed paper internal path A error. Tried single side printing instead of duplex, but jammed just the same. Then tried the same with A4 and it worked perfectly.
So, to summarize, I can print A4 from Tray 2, but A5 jams every time - any ideas?
  • 12 more comments
  • chrispeen Jan 04, 2009
    Thanks for fast response!
    Paper guides inside tray two are set to A5 and locked in place, and the paper stack is about 25% of max allowed. Still jamming - more ideas appreciated, thanks.
    Thanks - just tried A4 again. It will only print when inserted in tray 2 orientated as landscape, if I turn the paper to portrait in the tray it jams exactly as A5.
    I have completely removed tray 2 and checked inside with a torch - no sign of even a small piece of paper jammed, nor any sign of damage or sticky bits on the rollers. Also opened right cover and checked for stuck paper, but nothing there either.
    AP3800 prints A5 from Bypass and Tray 2.
    Hard reset made no difference. Absolutely certain there is nothing jammed or stuck.
    That link would have been OK if I had an HP printer. Also for the umpteenth time, I have VERY CAREFULLY examined the area inside and out of tray 2 for even the smallest of jammed paper or other debris. Honestly, there is nothing!
    Get the feeling that there is more than a tad of autoresponse going on here!
    The A5 paper that jams is identical to the A4 paper that prints - I cut it myself from the same stock (yes, it really is A5 size, cut on a professional guillotine).
    Any more ideas? A big thank you to all who have provided ideas so far!
    I have been using printers since 1983. I have worked out the difference between portrait and landscape, and A4 and A5 sizes, thanks anyway.
    Nice European papers, pity they don't sell in the UK, thanks for trying.
    Tray 2 only accepts A5 in portrait.
    Why is someone telling me about A4 papers?
    How do I get a refund?
  • chrispeen Jan 05, 2009
    So how do I correct the default to paper jam?
    Thanks - I have all the manuals, and I can load the tray correctly. I have also searched the Ricoh knowledge base, so there is no need to keep pointing me there.
    I just wondered if someone had already come across this strange problem and had found a solution.
    To summarize again, Tray 2 prints A4 in landscape, but jams in portrait. It ALWAYS jams when set for A5. I am familiar with the normal driver and printer settings. I know the different paper sizes. I am aware of paper quality. I have all the manuals. I have searched Ricoh knowledge base. I have been using printers for 25 years.
    It looks like this is a mechanical problem which needs an on-site engineer.
    Thanks everbody.
    If the paper in Tray 2 ALWAYS jammed I would agree that cleaning might help, but, it does print with A4 in landscape (which presents to the rollers exactly as A5 portrait does).
    The machine has printed 353,757 colour and 342,342 B&W sheets. The rollers appear sound and were judged to be OK by a pre-sale engineer, but I do not know when they were last replaced.
    Hope to hear from you again Bubbabear64!
    The A5 paper that jams is identical in every resect to the A4 that prints.
    All driver and printer settings are correct.
    Sounds the most promising idea - thank you
  • 365 Answers
This may be due to deformation in the size of the output side of the printer,which may be due to some force or weight applied on it.try to check it .thank you
Posted on Jan 05, 2009
    Scholar:
  • 80 Answers
I would like to suggest to check the paper size in the printer properties and in printer it self. please set the paper size to A5 in printing & preferences and set A5 for tray 2 in printer and than try to get the print. And also check for the thickness of A5 size paper is it harder than A4 or What ? If A5 is thicker than A4 Than kindly replace the A5. and ask for the paper a5 with same thickness as of a4.
  • Ricoh Master
  • 2,794 Answers
I'm a Ricoh tech. How many cycles do you have on the machine?
  • Tim Babcock
    Tim Babcock Jan 05, 2009
    Another thing that usually is the culprit of this printer are two things:
    1) Paper that could have moisture in it.
    2) The back stop could be not secured. If it isn't it could lose tension when grabbing the paper causing it to slip. They do break from time to time.
    If these solutions don't work and you have a lot of miles on it, it might be a good idea just to replace the paper clutch for that particular paper tray.
    Scholar:
  • 91 Answers
Just open the lid up and spray that spray air into it and use a cue tip and rub rubbing alcohol on the rollers on the side so its not so dirty..
Thanks,
Steven
  • 404 Answers
Hello! this may seem saft but I had a similar problem that was caused by **** paper feed? When I took the sheets from the **** I just shoved them into tray/feed and they really need some Tlc, give em a twist n turn possibly shake/ruffle before popping them in feed. If 2 or more sheets are offered due to sticking the machine defaults to paper jam!
Hope this FixYa's Prob!
Paul 'W'
Posted on Jan 04, 2009
    Genius:
  • 1,239 Answers
Your printer is capable of accepting a5, load the paper on a different direction, with the leading edge 5.83" feed first, then properly aligned the side guides to match your paper this will surely work this time, then slect a5 on your printing properties on your pc
  • ABHISHEK.C
    ABHISHEK.C Jan 04, 2009
    OR You can use the following media with this feature:
    Matte Paper - Heavyweight: A4, Letter
    Premium Glossy Photo Paper:A4, Letter, 5 x 7", 10 x 15 cm/4 x 6", 8 x 10"
    Photo Paper:A4
    Premium Semigloss Photo Paper:A4, Letter, 10 x 15 cm/4 x 6"
    Glossy Photo Paper:Letter, 10 x 15 cm/4 x 6"
    As you can see A5 is not in the list, therefor you will not be able to print A5 borderless via the normal means.
    Genius:
  • 1,011 Answers
Sir,
Click this link for more information
Thanks
Good Luck
  • Asfiya Ahamed
    Asfiya Ahamed Jan 05, 2009
    Sir,
    To reduce the frequency of paper and transparency jams,
    Use only the recommended sizes and weights of paper in the
    trays;
    After removing a paper jam, be sure to remove any paper scraps.
    Occasionally clean the feed rollers. Wipe off paper dust with a
    dry, clean cloth
    Click this link to download the pdf and refer the page nos from 11 to 12
    Scholar:
  • 100 Answers
Unlock the A5 plastic track and allign it just to fit the A5 paper then lock again, and make sure on the settings you choose A5 paper for tray 2 specifying it as landscape or protrait orientation. if all that didnt work, then make sure to buy good quality A5 paper, since some manufacurers might make the paper dimensions out of specifications ( alittle longer, shorter, wider...etc)
if that didnt work, then you need to open up the printer and make sure there's no dust or grease is on the inner sides of the wheel that takes in the papers, since A5 is smaller than A4.
    Genius:
  • 1,550 Answers
First try hard reset .
Unplug the unit from power chord for 30 minutes and plug back the power chord to the unit .
This will reset your unit .
If reset doesnot work then try the following
  • Remove paper trays and check for damaged paper.
  • Open the doors that give access to the printer's paper path and to the toner or ink cartridge and check for any bit of paper .
  • Close the doors you opened and turn the printer back on.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
On a Ricoh Aficio AP3800C Laser printer, isn't A5 meant to be fed on the Bypass Tray?
Good luck and Thank you for using FixYa.
    Sergeant:
    Champion:
  • 239 Answers
There is some riped paper inside that got stuck ,you have to clean it out
    Guru:
  • 731 Answers
Hi Chris
Try to print A4 from tray 2, so that we can diagnose whether its an Tray problem or not..
  • Ricoh Master
  • 19,396 Answers
Ensure that you are setting (manually ) the plastic guides that hold paper at the sides inside tray in the proper way.
Try also loading a bigger number of paper sheets inside the tray.
WHAT IS 007-243 code error
This fault code isn't specific to one location/function on your machine, however, I believe it is directly related to your paper trays. Other fault codes begining with 007-??? state a tray sensor error, misfed media in a tray etc...
If you're trying to print to a specific tray and it won't print giving this error, you may want to try printing using a different tray. It is entirely possible you have some jammed up paper in the paper path and this will stop all trays from printing.
Potential solution:
Ensure you don't have any paper jams related to your paper path and trays, herre is a link that provides you all iinstructions to clear any paper jam on your device http://www.support.xerox.com/support/workcentre-7328-7335-7345-7346/support/enus.html?associatedProduct=workcentre-7328-35-45-46-built-in-controller
NOTE: The above link is a support knowledgebase and you can search on any problem you may have with your product by typing the natural language query in the search field, paper jam, can't print, scan fails transferiing etc...
Once you have determined there isn't a paper jam or if so gently remove any misfed paper.Reboot the device PO/PO power off/power on.
If the print jobs fail again, check your job status and see if there is any info listed for your print job, could be a media mismatch.
Try printing to another paper tray, if your job is calling for paper from tray 3 try using tray 4 or tray 5 etc..
I have provided a generic response to this question and kind of throwing ideas out there, if you could provide additional information I may be able to give a better solution.
Check the details of your job in the job status list?
A lot of times the machine will provide good direction on potential issues with a print job.
Are you trying to print on a custom paper size?
If you tell the print driver to print to tray 3 and you have 8.5X11 loaded in tray 3 and your print job from ypour PC is actually 8.5X14 then the job will not print simply put the media has to match the job.
I hope this helps.
Mar 10, 2015 | Xerox Workcentre 7345 Printer, Copier,...
We had a paper jam in the print engine area. Once the paper path has been cleared we are still receiving clear misfed paper in print engine. I have fed paper through the path and cannot find any paper jam.
If your Xerox WC 4150 is displaying "Clear the Jam in the Print Area" you should check and possibly replace the fuser exit actuator (part# 120N00534). Iteminc.com has this part in stock and ships same day. Here is a video the shows you how to check and replace the fuser exit actuator. Good luck, and thanks for using FixYa!
Jun 17, 2011 | Xerox WorkCentre 4150 Black and White...
Sir my printer problem is on printer menu write a clearing paper path what is this massage and give me solution.
Thank you contacting FixYa for your printer inquiry.
This error is associated with either a sheet of paper blocking the paper path or a partial piece of paper that blocks path or trips a sensor. The printer will usually throw up a error code 13.XX on the display and the XX is a number that will indicate where in the paper path this error most probably occurred. Just follow the steps for your error on the below chart.
This link will take you to the user guide which will be helpfull identifying components and providing guidelines for most of the helpful hints and things you will need to know about this printer.
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00218691/c00218691.pdf
Locate your error on the matrix below and follow the steps. Comment back if you need more help. Thank you again for contacting FixYa.
TF
HP Laserjet Error Codes 0 - 19 Message on printer Display Panel What it means. What to do. 13.XX PAPER JAM [LOCATION] Media is jammed at the specified location (and possibly at other locations). If the message persists after all jams have been cleared, a sensor or sensor lever might be stuck or broken. For all jam messages, do the following: 1. Remove jammed print media from the specified location. Check the entire paper path for other pieces of media in the path. 2. Open and close the top cover to clear the message. 3. Check sensors and flags in the paper path for proper operation. 3.0 PAPER JAM [LOCATION] A non-specific paper jam occurred. 1. Remove jammed media from the specified location. 2. Verify the paper tray is fully closed. 3. Inspect and/or replace the feed and separation rollers. 4. Ensure there is no obstruction in the path, such as a torn piece of paper. 5. Open and close the top cover to clear the message. 6. Check sensors and flags for proper operation. 13.1 PAPER JAM OPEN INPUT TRAYS Paper-delay jam at paperfeed area. 1. Ensure that paper trays are loaded and adjusted properly so media can feed from the tray. It might be necessary to reduce the stack height of media in the tray. 2. Check the input area for obstructions such as media in the path. Also check to see if the registration assembly damaged or unseated. 3. Replace any defective sensors or flags. 4. Verify the media meets the specifications. 5. Check the pickup feed and separation rollers for unusual wear. Replace as needed. 6. Rotate the media in the input tray by 180° and/or turn it over On NX engines this is most likely the fuser flag or the ACPM. The ACPM has a photosensor hard-wired to the back of it. 13.10 PAPER JAM CHECK DUPLEXER Jam at duplexer. 1. Check the duplexer and the rear area of the printer for obstructions or damage. 2. Check the duplexer for proper operation. Replace the duplexer if a sensor is defective. On a 5si, 8000, or 8100 series laserjet a Duplex Jam can be caused by a tray 2 and 3 feed assembly failure. 13.14 For Laserjet 5si. This error is caused by a defective paper control PCA Replace paper control PCA. 13.2 PAPER JAM OPEN INPUT TRAYS Paper-stopped jam at paper-feed area. 1. Check the input area for obstructions such as paper in the path. Also check to see if the registration assembly is damaged or if the transfer roller is out of place. 2. Replace any defective sensors or flags. 3. Ensure the media does not exceed the maximum length. 4. If multiple sheets are feeding, it might be necessary to fan the media and reduce the stack height. Also, replace separation pad. 5. Verify that the fuser is properly installed. On NX engines this is an input jam. 13.20 PAPER JAM CHECK REAR DOOR Media stopped in the paper path during power on or when the top door was closed. 1. Remove all media in the paper path, and then open and close the top cover. 2. If the message persists after all media is removed: Check if media is jammed in the prefeed area. Replace any defective sensors or flags 13.21 DOOR OPEN JAM The top cover was open while printing. 1. Clear the jam and close the top door. 2. If the message persists, check the top door switch for proper operation. 13.5 PAPER JAM CHECK REAR DOOR Paper-delay jam at fuser. 1. Check the transfer roller and small media belt to ensure they are operating and can feed print media. 2. Check the paper path for obstructions at the transfer roller, toner cartridge, paper feed assembly, and fuser. 3. Replace any defective sensors or flags. 4. Turn the media stack over and/ or rotate it by 180° in the input tray. If still persists - replace fuser, then DC controller. 13.6 PAPER JAM CHECK REAR DOOR Paper-stopped jam at fuser. 1. Check the paper path for obstructions at the fuser and output/delivery area. 3. Replace any defective sensors or flags. 13.99 PAPER JAM [LOCATION] A non-specific paper jam occurred. 1. Remove jammed media from the specified location. 2. Verify the paper tray is fully closed. 3. Inspect and/or replace the feed and separation rollers. 4. Ensure there is no obstruction in the path, such as a torn piece of paper. 5. Open and close the top cover to clear the message. 6. Check sensors and flags for proper operation
Jun 09, 2011 | HP LaserJet 4350 Printer
Fix for 13.12 error
Hi
You are getting Error 13.12 due to paper jam at Paper feed 1. It can also happen when the Paper doesn't reach PS2(paper sensor 2).
Please check the picture for more details---
Try printing from Tray 2 or Tray 3, if it fails printing from tray 2 or 3 then Paper sensor 2 (PS2) is bad. To check the movement of flag insert the paper manually in the sensor path.
Remove any paper present in printer and then perform a paper path test using a duplexer. If issue is still not resolved then please remove the duplexer unit and re seat it. After re seating the duplexer your issue will be resolved.
Daniel Scott
Jun 28, 2010 | HP LaserJet 8100dn Printer
How do I fix a paper jam? I've got paper jam around the exit roller and I can't get it out?
There should be a way to unlock one of the sides. Try taking out the toner cartridge and going in that way. If you can see the paper, get a pair of needle nose pliers and SLOWLY see if you can pull the paper out.
Sep 21, 2009 | Samsung CLP-510 Laser Printer
XEROX 6110 coloer printers
Xerox 6110 Code Description A1-1 to A1-32 All indicate a paper path problem, etc. in the ADF A2 ADF exit problems A3 Irregular size documents A5 ADF interlock A6 ADF single sheet document reset A7 Platen interlock A8 ADF exit interlock C1 Tray 1 jam C2 Tray 2 jam C3 Tray 3 jam C6-1, C6-2 Jams related to duplex C6-3 Registration sensor, re tray 1 C7-1, C7-2 HCF feed problems C7-3 Tray 1 feed problem C8 Paper stays in tray or duplex or HCF C9 Bypass feed problem E1-10 to E1-25 Internal jam E1-6 Paper on registration sensor E2 Reset signal happened. Might read E-2 something else E3-30 to E4-14 Exit jam E3-6 Exit jam E4-10 to E4-14 Inverter sensor not actuated E4-15 Inverter sensor E4-40 to E4-45 Duplex entry sensor E4-6 Inverter sensor E5 Front door interlock E6-1 Tray 1 interlock E6-2 2 tray or duplex interlock E6-3 HCF interlock E7-2, E7-3 Duplex interlock E8-6 to E8-15 Duplex entry sensor F1-1 Sorter entry sensor F1-6 Sorter exit sensor F3 Paper size not available for sort/stack F5 Sorter interlock J1 Add toner J3 Replace copy cartridge J7 Replace copy cartridge J8-1 Wrong copy cartridge installed J8-2 Copy cartridge EEPROM L6 Auditron or other counter problem L8 Platen glass temperature is too high L9 Communication problem between interimage erase/edge lamps and main board U1-1 Main motor drive problem U2-1 to U2-4 Scan home sensor U3-1 Lens sensor U4-1 Open fuser thermistor U4-2 Fuser did not warm up properly U4-3 Fuser temperature too high U4-4 Fuser problem. Staying on too long U4-6 High fuser temperature U5-1 Sorter bin home switch not activated U5-2 Sorter bin home switch stayed actuated U5-3, U5-4 Sorter bin home switch U6-1 ROM problem U6-2 RAM problem U6-3 Low battery U6-4 Incorrect value in NVM. Reinitialize main board with code 20-96 U8-1 to U8-6 Problem with exposure lamp, lamp sensor, lamp board
Jan 03, 2009 | Office Equipment & Supplies
Oki C9300 - paper keeps jamming in the 2 same places, reads either 383 paper jam or non paper sense error. All drums and tonners are new, paper is loaded.
your getting a 383 paper jam, find paper in two different places.
See if it's a duplex related problem. print single sided documents, if that works, try printing two sided documents (it'll be the duplexer) if it only fails while printing duplex.
Also, check the back door. Make sure the back exit tray is closed all the way.
You can also have a paper jam in the duplex unit (open the front door), the duplex unit slides out the front. You can easily remove the duplex unit and run the printer without it.
Oct 20, 2008 | Office Equipment & Supplies
Ricoh Aficio AP3800C Laser Printer Logo
107 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
