I have an inwall Friedrich Heating and a/c unit. The blower for the heat comes on but blows cold air. The a/c side blower does not work at all. Both happened about the same time. Related? Why not heat and no fan.
  • mtcowley3 Jan 04, 2009
    This is an electric unit.
    Genius:
  • 1,239 Answers
HI most boards have a small 3 or 5 amp fuse on the board it looks just like a car fuse. do not put in wrong size fuse it can allow damage to the board.
Posted on Jan 04, 2009
  • ABHISHEK.C
    ABHISHEK.C Jan 04, 2009
    the reversing valve has a separate coil. some energize on cool mode, some on heat mode. Has the thermostat been replaced? I find this a common mistake.
    Scholar:
  • 100 Answers
Usually a thermal temprature sensor (just like a metal rod) is responsable for doing that. those sensors usually are not the problem, but the transistors and resistors that connect with it are usually the problem. check the parts around that sensor (transistors, resistors, diodes, amplifyers) its output usually goes to either an amplifier or a transistor. check them or replace them with the right equivilant part number.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, I doubt if directly related but, it is possible the tap off points for the wiring are on the same connector hence the A/C blower was also affected. On the heater:
  • heating element (likely) - could be checked with a continuity tester/ohmmeter;
  • thermostat (least likely) - continuity check, should change when heated;
  • thermal cutoff (least likely) - fuse like action when specified temperature exceed;
  • relay switch (most likely) - this performs the actual switching on of the heater. In certain instances, it could be the relay contacts are corroded or burned off, however, more often faults are the lug connectors that are corroded/burned. In some designs, the A/C blower wiring is tapped from the same connector.
Good luck and Thank you for using FixYa.
  • 19,396 Answers
Unit not heating at all , and ac blower are normally two separate problems, that concern different parts.
If they happened at the same time, the more likely is that there had been a short on wirings, or there is a problem on control board or a faulty timer control.
Start checking the wirings to the timer control, and ensure the control is working. Try also starting functions on AC manually.
If you have still problems, even when setting AC directly, then the unit must be taken apart and tested, starting from fan , and heating system, if this two are working, then it is a faulty control board.
  • 163 Answers
Hi!!! is it gas or electric..
PTAC PDE12K3SB - No Heat
i think so may be the heating coils are not getting heat without power supply check out the plug in wire and whole supply.
Dec 18, 2007 | Friedrich Digital PTAC PDH12K35B Central...
Amana Wall unit blows cold air before heating
the unit works by chilling air and the byproduct is heat in the compressor, this is used for heating in the winter and then reversed in summer to blow cold air. It has to blow cold and warm up before it can blow heat.
Mar 17, 2017 | Amana Heating & Cooling
2010 dodge journey blows cold air on passenger side
Help with heating issues, blend actuator - Interior - Dodge ...
www.dodgejourneyforum.com/.../5304-help-with-heating-issues-blend-a...
Jan 13, 2014 - My 2009 Journey R/T is only blowing hot air out the driver side vents, while the other vents (passenger and rear) are blowing cold air ... Thanks Frogbox....keep in mind that the info is for the 2009 model and I guess it also applies to2010's. 2009 journy sxt heat/cool issue
Oct 16, 2014
Air Conditioning?
Dec 22, 2012
Rear heater A/C
Dec 22, 2012
More results from www.dodgejourneyforum.com
In a 2010 dodge journey why heat comes out just one side
Jan 10, 2016 | 2010 Dodge Journey SXT
Ac unit will not heat
You need to check your model # a CP06 is a straight cooling window unit you may have an EP08G10 this is a heat cool unit. Double check your thermostat is turned to higher setting. If so you may have an issue with the heating element or the heat limit on the element.
Dec 08, 2013 | Friedrich CP06C10 Wall/Window Air...
Just changed blower motor in friedrich vpak unit still wont blow heat
that would be a problem with switch, heating element or fusible link
Dec 07, 2013 | Friedrich VEA09K34 Packaged Units,electric...
I have two Friedrich PDE15KSB-C units. When trying to turn on the heat neither will kick into the heat mode. They both blow cold air only. When they are first turned on the air blows, and there is a...
Keep +10 degree from your room temp and also thermostat in "heat" . And then check. But in your case, I think RV not energized. If no proper voltage in RV in heat mode, check the wiring to RV. If voltage in means RV not working properly. You have to change RV. Thanks.
Dec 14, 2010 | Friedrich PDE15K3SB Portable Air...
Amana inwall electric heater blows cold air
Is the blower running? Sounds like unit is tripping out on high limit safety switch.
Jan 06, 2009 | Amana Comfort Zone 12M32PBEH Air...
Intertherm heating
My heating unit is blowing cool air. The thermostat will start the blower when the unit is turned on at the thermostat, but the air isn't hot. But,when I turn the unit on at the furnace/blower using the "Fan On" button, I can see the heating element heat up. After the blower starts the heating element does out. What could be the problem?
Oct 29, 2008 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
19 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
