Question about Panasonic DVD-S29 DVD Player
When playing a DVD on my Panasonic DVD player there is a humming noise which changes pitch each time the scene changes, very anoying, any ideas what to do to stop hum?
    Genius:
  • Panasonic Master
  • 2,432 Answers
Tried with other cable connectors that you have been hooked up in the input of the tv. by the way have you been already tried to play with other dvd disc?.
Posted on Nov 03, 2012
  • 3 Answers
SOURCE: DMR-EH75V DVD Recorder
ekimt,
Yes, it would not recognize any type of disc. The disc icon was always present on the display even though no disc was inserted. Also, mine went out while recording from HDD to DVD. Panasonic had mine repaired in two business days and it' s working great.
mjs8
Posted on Aug 04, 2008
  • 15 Answers
SOURCE: Panasonic DVD player stuck on Reading
I had a similar problem with my Yamaha DVD player which just kept displaying "reading, reading and reading"- eject-no disc or disc error. I took it into be repaired and was told it needed a new optical lense-cost $120.00 plus fitting.I was told not viable to fix. Not convinced I had a look on the internet and a suggestion given was to buy a can of Air Spray from **** Smith,$14.00 later and blowing the proverbial out of the inside of the unit-Bingo it works for about an hour and then, away we go again-reading reading reading - eject-no disc. Back to the internet and i found a DVD technician who advised the more often than not the problem is a dirty optical lense, and he has saved 100's from the grave by the following method. The most effective way to clean it is with a cotton wool bud soaked in Isopropyl Alcohol and give it a good rub without damaging it. I got the Isopropyl alcohol for $12.00 a 250 ml bottle from the local chemist and did what was suggested. IT WORKED and is still going- not sure for how long but the bonus is I can use the remainder for rubbing down my tired old body, as after shave or a refresher, in addition to fixing DVD's so not all is lost. It's worth a try considering I was going to throw the Yamaha away. Thanks to the internet and the good people who share their knowledge I am happy again.
Hopefully it will work for you. If not, don't forget the other uses for the alcohol.
Posted on Mar 10, 2009
SOURCE: Panasonic DVD Player only plays in black and white
have you tried swapping the scart lead socket on the back of the dvd vcr i had this problem and i found out i was using the wrong scart socket make sure you are using the t v scart and not the
decoder one
cheers
Posted on Dec 14, 2008
SOURCE: DVD-S35 Panasonic - bandwidth information OSD
I have upgraded the firmware on my player and the problem disappeared. There is a "bitrate display" option in the Settings menu, but it didn't change anything when I tried it (before the upgrade). Now it isn't necessary.
Posted on Jul 18, 2009
fieldy14
  • 456 Answers
SOURCE: Panasonic DVD player RV62 H07 message - disc
You can try to clean the laser by opening the unit and wiping gently with a cue tip or cotton swab, but if you are getting a H07 errorit may be somethng more serious and require a replacementof the dvd drive.I hope this helps. Good luck.
Posted on Sep 03, 2010
Humming sound when Sony DVD player is turned on. The player is attached to a TV. The sound continues when a DVD movie is played.. The intensity of the humming changes with changes in the Video.
Is the humming just from the power on or is it when the DVD is spinning some media will spin with a loud humming noise something to do with the balance similar to an unbalanced car wheel, just a lot quiter. Burn the DVD using ImageBurn create an ISO and reburn.
If it hums without the DVD spinning it is probably the transformer on the PSU on it way out this can happen at any time it is caused by the voltage step down coil becoming damaged in some way and the lower voltage provided causes the noise.
If this is the case I suggest a new PSU or at least a new Transformer.
Jan 07, 2010 | Televison & Video
I have a humming noise coming from my new 50in panasonic plasma tv. Is this a common problem and if so what could I do about it? Thank you for your time. Pat
The humming noise should be verry low . It is caused by the powersupply and switching fets on the boards. A plasma screen always produce some sort of humming noise when listen carefully to the device but it shouln't be anoying when enyoing a movie. So it is a natural thing but again it should not be noticable, enyoing a movie at apr. 3 meters or so...
Jul 09, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
High pitched noise regardless of power on/off
Hello... I would say that your power supply is going bad. But it does sound like the little muffin fan in the unit is.
May 10, 2009 | Panasonic DMR-E85H DVD Recorder
Humming noise when Dvd plays
the motor that's spinning the dvd is bad. sorry you have to buy a new one if you don't want to hear the noise. hope this help
Dec 17, 2008 | Coby DVD-937 5.1 Channel DVD...
Whenever I play a dvd a second time, it starts from where it left off ast time, and I have to rewind the dvd manually each time? How can it always start at the beginning of the dvd, each time I go to view...
What you are describing is 'Last Scene Memory' function which is a feature of most DVD players. The player will not memorise the last scene if you switch of the player before playing the disc. This should Fixya!
Please remember to rate this solution.
Nov 05, 2008 | GoVideo Televison & Video
Samsung HT-X70 DVD player
i have this system set up to a sony bravia kdl40v2500 tv and sometimes when playing a dvd the screen will go blank and in the corner 1080i will show. I do not know how to change the resolution and does this need to be done on dvd player or tv. Can you help me.
Thanks
Tom
Feb 20, 2008 | Cell Phones
Panasonic mini dvd-r playback problems
I hate panasonic mini-dvds. I can' import any think from panasonic.So do not use panasonic
Feb 03, 2008 | Televison & Video
Picture freeze
have you tried to plat back on another player.?Could be either at fault,seeing as is playing back ok on cam would suspect your player.try playing on another player to see which at fault.
May 13, 2007 | Panasonic VDR-D250 DVD Camcorder
Rumbling drive
The dvd motor needs to be service or change take it to a tech to look at it.
Apr 03, 2007 | Panasonic DVD-CV51 Multi-disc DVD Player
Panasonic DVD-S29 DVD Player Logo
89 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
