Question about Haier HL26B Television
Tv is dead
Cannot turn on tv. cable guy was here to determine comcast cable box is working ok.. he could not turn tv on......says it is "dead." my question is: is this a common complaint? ( set is 12 years old) What are common problems that might be the cause. what does a fix cost?
    Top Expert:
  • Haier Master
  • 14,553 Answers
Common issues are no power reaching set, fuse in set bad, power supply to the set (inside). But if set 12 years old parts may no longer be available.......maybe too old to be a good repair?
Posted on Nov 03, 2012
Cable box now not working
Sounds like it is on the same circuit trying moving cable box to new plug use extision cord
Sep 03, 2014 | Comcast XFINITY
The sound does not come on when first turned on. I have to turn the unit off-on several times before the sound works. I utilize compast for tv access.
Try using a different input. For example, if you are using an hdmi input, try using a component input instead (Its still HD) A sure way to test this is as such. Remove all cables from the Comcast box to the tv. Now, run your coax from comcast into the back of the comcast box. It will say something like "In from antenna" or "cable in." Now run a regular coax cable out of the box, into your tv. This will be labeled as "out to tv or vcr." Now put your tv on channel 4. If the sound is ok, then you know its a problem with your input on your tv. If you still have the issue, it is probably the Settop Box from Comcast. Please note, this is just to test the tv. This cable will not support HD television feeds. Hope this helps.
Jan 07, 2011 | Vizio Televison & Video
Cable jack is connected through the comcast box and then hdmi cables are connected from the comcast box to the tv. The cable jacks on the tv do not work. The picture was clear and then it cuts in and out...
The tv have a problems known as a convergence problems it dead.Tv have colors lines R,G,B mis alignments,have colors shadows or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board must be replaced to fix the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 05, 2011 | Toshiba 57H83 57" Rear Projection HDTV
No sound on channel 3
Maybe the cable signal is defective not your tv.the other channel is ok.if you tv has a defect all channel has affected.
Jul 02, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Comcast cable channel one off from Tivo channel
I've never, ever heard of this problem - having been a happy TiVo user for over 15 years. The very first thing I would do is call Comcast and tell them what is occurring. How long had everything worked OK before this happened? If things were OK for a long time before this, and if your TV carrier was, likewise, Comcast for a long time; and if you haven't gotten a new TV or cable box for a long time, then the problem must rest with Comcast. It must!
In our home, with the number of movies, shows/sporting events/etc. which we record, that would be totally unacceptable!
Try this: Unplug everything (with everything turned off). Make sure your TiVo remote is good (fully charged batteries and the code is right for your TV/cable box), Wait for 10 minutes and plug everything back in, starting with TiVo, then the TV, then any other accessories.
Plug back in and do a complete restart from scratch - like you did when you first set up TiVo.
Make SURE that your receiving channel (3 or 4) is the same on both. It could be that someone accidentally has changed it - are there kids in the house?
If none of this works, get Comcast in there. That's all I can tell you. . .
JB
Apr 11, 2017 | Tivo Televison & Video
My insignia lcd37 is hooking the comcast modem and works at times. Other times the sound is on, but the picture is blank. Is it worth fixing or just start over.
Okay you TV is hooked to a comcast modem? or do you mean My tv is hooked to the comcast converter box? A no picture but sound you want to first check you cables also try hooking up a dvd to the tv and see if that picture comes on if not and you got no pic and sound this would mean the backlight on this tv is dead or you got a bad inverter not converter, inverter inside the tv. Meaning it needs the repairshop but try and hook up a dvd to it and see if you got picture if so you cable box might be the issue call comcast!
Thanks and please leave valuable feeback and ratings today!
Dec 11, 2009 | Insignia 37" LCD Flat-Panel HDTV
Can't get my hannspree remote to work with comcast
10030 for the comcast dvr remote. Code is from NEC
Oct 02, 2009 | Hannspree HT09 28 in. LCD TV
Closed captions will not work thru my tv remote
I hope this was resolved but this is a dish page and I am unable to answer Comcast issues.
Feb 14, 2009 | DISH Network 811 HD DTV Receiver
Turn off closed caption on input(component) on Sharp Aquos 42"
Had this happen on a Comcast box (Motorola DCT 6416 III)
Here's how to fix it:
Turn the cable box off, leave fully connected. Press Menu on the remote
The cable box internal menu will display (Not the Comcast one the Motorola one-- i.e. Display ratios-16:9 etc It's in black and white)
Use the arrows to cursor to the Closed Captioning and toggle to "Disabled" Press Manu again to exit and Voila!
Power the box on an have at it
Apr 10, 2008 | JVC HD-61Z575 61" Rear Projection...
Televison & Video Logo
104 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
