Question about Pool & Spa
Manual for rp25t pool chlorinator - Pool & Spa
  • 297 Answers
SOURCE: i have a 18ft x 52 intex pool with salt water chlorinator.green
although you may or may not have enough chlorine in your pool you must also realize that a pool need turned over at least 3 times a day.
an example is if you have 7000gl of water and a 2000gph pump you need to filter at least 10 hours or so.
More important than chlorine is the actual circulation of the water you can have all the chlorine in the world but if you do not have the circulation the water will become cloudy or green this also happens when you have no swimmers for days at a time
the filtration time is over and above the chlorine generating time your 4 hours a night for generating chlorine sound like you are guessing sometimes it may be 4 and sometimes 2 or 6
it depends on # of swimmers a day sun and what was in the pool to start
It is important to have a test kit for ph and chlorine and keep chlorine at 1.0to 1.5 now set your ph
ph will rise and fall with your chlorine level one you have them set good at the first time then ph should stay safe enough and re level as chlorine is kept right
also remeber that the wrong ph causes more problems than wrong chlorine levels
Also make sure your salt is no more than 3000ppm and no higher like some people recommend and no lower than 2500 test kits are available for 10 dollars
all of this can be found on intex.com either in a video or pdf files for water capacity and approximate time for generating chlorine.
to be sure always use test kits
Posted on Jul 12, 2009
  • 128 Answers
SOURCE: heavy smell at filter basket but reads no chlorine in pool.
Check the stabilizer level in the water
Posted on Sep 05, 2009
  • 8404 Answers
SOURCE: what chlorine should i use for my pool?
You should use granulated CL in this pool. Maintain CL at 5 ppm - check daily.
Posted on Jul 24, 2010
briones93
  • 119 Answers
SOURCE: We have a Krystal Clear
You should always follow the instructions on the manual .. I have a 18X33X4 oval and had to start with over 350 lbs of salt and ran the pump without the chlorinator for 24 hours to properly disolve the salt. Then, I started with 12 hrs pump cycle with 10 hrs of chlorination in between the 12 hrs. Keep checking the chlorine level and adjust time from there. Currently at temperatures of 85 to 100, I run the system at 10 hrs pump with 8 hrs chrlorinator and water is Crystal Clear... In the 2 years with the intex system, I have not added any chemicals to my pool. I once had an issue when the water level went low while I was on vacation, when I came back, the chrolinator had turned off due to low flow and my pool water was green.. As soon as I re-started the cycle, a few days later, Crystal Clear again... NO CHEMICALS OR SHOCK added.... Hope this helps....
Posted on Jul 15, 2011
woobie dog
  • 1273 Answers
SOURCE: pool chlorinator
Hi Chris, W/D here.
Here's a few things that you may or may not have checked:
1. You didn't state the age of the cell, or type. The generally last 2-3 years. I don't know how the power to the cell was checked, but clean the cell thoroughly before moving on. I use 1 gallon of muratic acid, and soak for about 5 minutes, then flipping the cell and soaking for 5 more minutes. Wear neoprene/chemical resistant gloves, and rinse thoroughly. Save the solution, as you can get several cleanings out of it.
2. Look for a fuse on your panel. The control boards are divided into areas of function. You'll need your wiring diagram, if the areas aren't clearly defined.
Hope this helps, --W/D--
Posted on Nov 10, 2011
Why is my saltwater pool turning green?
balance the water with chlorine super shock it once in balance your chlorinator should maintain a chlorine reading if you have a heavy bather load you must shock manually
Jul 29, 2014 | Intex Krystal Clear Saltwater System Pool...
Tip
Solving Salt Water Pool Problems
The big problems with salt water pools is actually the salt in the pool water itself. Salt water chlorination has many benefits over standard pool chlorination methods, but with a salt in the pool system there are significant drawbacks, hidden expenses, problems, and potential dangers. The best way to enjoy salt chlorination is to get the salt out of the pool. The Chlorine Genie Pool Water Management System does just that. In fact the system can produce and take care of up to 5 important pool chemicals for you. If you are fed up with salt water pool problems and ready for the cutting edge in pool water sanitation, check out the new advantages of Chlorine Genie's Chlorine Generator Technology.
Chlorine Genie Inc Martinez 94553 The Ultimate Pool Chlorinator
Check out the Pool System Videos on YouTube at: Chlorine Genie
Get Social and Join the Pool Party at: https://about.me/chlorinegenie Chlorine Genie on about me
on Nov 08, 2016 | Pool & Spa
Vx salt chlorinator has suddenly stopped working fully, when on manually it just stays in sanitising mode. Every thing is fine chemical wise and pool level but output of chlorine is not happening
look for corroded valving or white powdery residue thatgs got the piping/hardware plugged up..may need replaced if you cant brush it off..
Jan 06, 2014 | Pool & Spa
In a 52" x 22' Ultraside Intex pool with a saltwater ionizer and a sand pump can I use pool shock to kill algae without damageing the saltwater ionizer system and the sand pump?
There seem to be different versions of algae killer - look for one that specifies that it's safe with saltwater systems (sorry, not familiar specifically with Pool Shock)
Aug 01, 2013 | Intex Automatic Salt Water System for ...
My husband converted our 27 x 52 round above ground pool over to saltwater two weeks ago and we have yet to be able to get in it to swim. We drained all 18,700 gallons, scrubbed the liner and refilled the...
Wrinkles in your pool liner wall is a slight problem and can be a place for algae to grow, BUT can be treated and cleaned.. Algae will appear if your not providing the correct amount chlorine, regardless of wrinkles or not.. Let me tell you how I take care of my 14,500 gallon 18' X 33' X 48" pool using only the 8110 Intex model and hope you can apply some of my techniques to your pool and system...
In the 2 years I've own my system, I have not added any chlorine, even for those times my system failed and water turned green.. Yes.. I could have bought SHOCK and CHLORINE and added to my pool to kill the algae, but chose to vacuum, brush and set my chlorinator to max and did it without buying any of these expensive chemicals.. It took over 3 days to finally see results after running my system at at 12 to 14 hrs pump and 10 to 12 hrs chlorination.. After my pool cleared and chlorine level was at optimal, I lowered my chlorination to around 6 to 8 hrs.. Right now that the temperature is around 95 degrees, I run the pump for 12 hrs and chlorinate for 10.. My chlorine level is slight low and today I plan to raise my chlorination to 11 hours.. My pool water right now is crystal clear and clean. I vacuum my pool daily and check the electrolytic cell weekly for optimal results..
Now...you have a huge above ground pool, almost 19,000 gallons!!! To start.. you should have added almost 500 lbs of salt!!! and ran the pump only for over 24 hrs to properly dissolve the salt..
Next, you should test the water salt concentration level and should have been between 2000 and 3000 ppm. After the proper level and because your pool is so big, run your pump at 12 hrs or longer and possible 10 to 12 hrs chlorination...
You said the manual vacuum sucks up the liner??? They sell a nifty device that hooks up at the end of the hose and attaches at the skimmer inlet that has a relief spring activated door that prevents sucking up the liner and also, you may to look for a different vacuum head???
Bottom line... NO, the only way to clean the algae is NOT with vacuum and brush only..It could be done with SHOCK and CHLORINE.. I chose not to add shock and chlorine to mine.. But you will need to vacuum the dead algae and clean you filter several times..One more thing... I hope your chlorinator is big enough for your size pool.. The max gallons the manual shows is for a 14500 gallons, like mine... Good luck and hope this info helps...
Aug 14, 2011 | Intex Automatic Salt Water System for ...
We have a Krystal Clear Saltwater System Model CS8110. We are first time pool buyers. We set up the pool last week and despite several "boosts" the chlorine level is very low. The pool store...
Jul 15, 2011 | Intex Automatic Salt Water System for ...
We have an Intex above ground pool that takes salt and converts to chlorine. We filled it about a month ago and all was fine for a few weeks, then in the past week the water began turning green. We have...
Intex chlorine generators are very low output generators that fail very often. There is a reason they are so cheap. They do not work well. When using a chlorine generator, it is important to test manually for salts and free available chlorine on a daily basis. Just adding salt because you have a generator will not make your pool manage itself. In order to get the most basic chemistry under control, you need to test for alkalinity, calcium, pH, and free available chlorine.
If you do not have the ability to test these things, spend $10 on a 7 in one test strip that will give you this information.
Note: Chlorine generators have more negative aspects to them than positive. There is not a cost savings as advertised with these units. It actually costs more money, and takes more time to care for. The salt is very corrosive to the pump and filter system as well as the pool itself. The long-time cost would be cheaper to run a chlorine or bromine pool.
May 02, 2011 | Intex Automatic Salt Water System for ...
Intex salt water chlorinator I added a higher flow pump and chlorine levels seem low no matter how many hours I run the chlorinator
your pump has nothing to do with chlorine generation.
You need to get a salt test kit that reads in #'s not colors.
Now get your salt to 3000ppm or as close to it as you can.
The amount of salt reccomended in the manual is just a starting point
any lower than 2800 and you will not produce enough sanitizer and over 3600 and your pool can go cloudy, taste bad, and rust metal parts
Jun 28, 2010 | Intex Automatic Salt Water System for ...
Cant figure out where to put chlorine/chemicals
add chlorine to the water in the pool you might try a pool supply store for information reguardind ph of your pool and how to mix chemicals
Jun 21, 2009 | Intex Krystal Clear Model 635 Pool Filter...
I opened my pool a couple of weeks ago and filled my Hayward CL200 chlorinator with 3'' tablets. I usually set the dial on 2 with good results. After over a week, the chlorine level was nill in the pool....
A CL200 Involves direct injection of chlorine into the pool. Water passes through the chlorinator and goes to the pool with chlorinated. WIth the 200 (Not the 220) I've only seen a handful with problems over the years with chlorine not dissolving. If the chlorinator is not leaking, and the control valve is moving freely here's what I'd recommend.
1. Are you using a new type of tablet?
If so remove the tablets and place into a floating chlorinator.*** WARNING Wear Rubber Gloves, while handling wet tabs****
Dial it all the way open. If the tablets don't break down at this point with in a day or two, They were over compressed at the factory, potentially have to much filler (most slow tablets should be 95-99% cholroine) or the water is too cold ( below 70 deg. This should not be an issue in July) If this is the case switch brands.
If the chlorine is dissolving in the floater but not the chlorinator it could be one of the following.
1. Make sure the direction on the chlorinator is correct inlet (from Filter) to outlet (to pool)
2.. In some of the newer 200 chlorinators there is a built in check valve you can see it in the bottom of the chlorinator You will notice a threaded piece in the bottom that contains a white plastic ball the size of a pea. If this ball does not move freely to the touch, odds are the filler in your chlorine has clogged it from moving, thus preventing the flow of water from dissolving the chlorine.
You can check this by removing the chlorinator from the pool, removing the lid and pouring water directly into the top. If you do not see water passing through to the "Outlet" side of the chlorinator a clog is most likey your problem.
I've seen clogs cleared with wire coat hangers and hot water. Be forewarned that hot water being poured into a chlorinator will cause the any residual chlorine to gas off, make sure you do not have you face over the chlorinator when you add the hot water and you do so in a very well ventilated area. A straightened wire coat hanger can be used to dislodge any obstruction in the check valve and "get the ball rolling again"
Hope it helps.
Jun 10, 2009 | Hayward In Line Chlorinator 9 Lb. Capacity...
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
