Question about Kenwood KDC-248U In-Dash CD, MP3, WMA Car Stereo Receiver w/ Front AUX
Why does stereo say protect - Kenwood KDC-248U In-Dash CD, MP3, WMA Car Stereo Receiver w/ Front AUX
    Master:
  • 444 Answers
Check if a speaker wire come off or some other wire, That will cuase it to go into the protect mode,Allso if you have a amp hooked up to it, End continully have the music cranked up the system will over heat ,That can cause it allso to go into protect mode, There is a reset button on the face plate but it is not marked,
Posted on Nov 03, 2012
My stereo sysytem is a mini stereo: serial number 10200055. It currently says "protect", what is this and how do we return our system to normal operations?
When the word PROTECT appears on this display, this means the unit has detected a critical fault which could potentially cause harm to your stereo system.
The most common cause is a short circuit somewhere - something even as simple as loose speaker wiring could cause a short, triggering the Protect message.
You will need to determine if there is a possible short somewhere, so I recommend you start by firstly turning power OFF, disconnecting all speaker wires, then turn unit back ON.
Operate the stereo (without speakers) and turn volume up:
  • If Protect message appears when turning volume up, then stereo unit itself has an internal fault
  • If no Protect message appears, then suspect the speakers may be causing the issue.
  • Reduce volume and turn unit OFF
Re-connect speakers (ensure the connections are secure), turn unit ON:
  • If turning volume up triggers the Protect message again, there is an issue with the speakers or connections
Hope this helps.....
Sep 04, 2011 | Kenwood Audio Players & Recorders
My JVC car stereo display " Protect " on display
FIRST PRESS THE RESET BUTTON BEHIND THE FACE IF DONT WORK CHECK ALL SPEAKER WIRES SOMETHING MIGHT BE TOUCHING
Jul 24, 2011 | JVC AM FM CD DET FACE CAR STEREO
Stereo
If your stereo is showing the protect display, it is an indication of a power shorting. This protection is to avoid serious circuit burnout and could be in the power output stages of the set. You will need to open and check for short in the output drives, the preoutput stages, the speakers or even the protection circuit amp.
It is important to address and check these sections with a votage check, elimination process too confirm the part. this may be a little tough and diffcult unles it shows easily on a continuity test. Helpful. Good day
May 31, 2010 | Kenwood Audio Players & Recorders
Protect error on model # CD BA200 Sharp Stereo
If you are a technician desolder the Audio amplifier IC,and check if the stereo turn on but with no sound.If the stereo turn on the audio amplifier IC is in short circuit and need to be replaced.
Good luck
Jun 05, 2009 | Sharp CD-BA200 CD Shelf System
Kenwood car stereo cd player reads protect mode how do i fix this
i have a kenwood kdc-241 car stereo and it has gone onto protect mode i have done everything it says in the manual and even taken it out of the car just in case it was damp i have tried putting it back in but still is in protect mode can anyone help me please
May 25, 2009 | Kenwood Car Audio & Video
My sharp Stereo is stuck in '' protect'' mode
Protect mode is not something that a reset will fix. Basically it indicates that there is a problem with the final output stage of the amplifier. Normally this indicates that the output transistors are defective. In most boomboxes, the amplifier is a single IC. If you can post the model number, I can provide you with the required part and cost.
Thanks,
Dan
Mar 25, 2009 | Sharp Audio Players & Recorders
My kenwood car stereo says protect how do i fix this
well that means you had a safety stereo in the beggining and you proly didnt put the safety code in so it went into secure mode it to prevent the device from working if stollen
Mar 08, 2009 | Car Audio & Video
PROTECT mode
I have a Sharp cd-c2900 home stereo and a "protect" word came up on the lcd?? The stereo is not working now and olnly shows a "protect" word?? Can you please tell me if there is a reset button some where?? Thanks , "Joel" My Email address>> Jovelopa22002@yahoo.com
Jul 17, 2008 | Sharp CD-C2900 Shelf System
Security Code for Protect mode
Turn on the car so the radio is flashing "Protect." Look on the front / removable face of the stereo. On it you will find a small round hole - that's a reset button. Find a small paper clip, unfold the clip and stick it gently into the hole. The "Protect" will stop flashing, and Kenwood will be displayed. Unfortunately all your settings/presets will be gone, but at least the stereo is working again!
Apr 30, 2008 | Kenwood KDC-W3534A CD Player
Protect mode
i try to turn the stereo on a message saying "protect" comes up and then it shuts off
Apr 28, 2008 | JVC HX-D7 DVD Compact Stereo Audio / Video...
Kenwood KDC-248U In-Dash CD, MP3, WMA Car Stereo Receiver w/ Front AUX Logo
166 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Eddie Dalton
Eddie Dalton
Henry  Thomas
Henry Thomas
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
