Question about Chicco Cortina Baby Gear
Front wheels keep falling off
Whenever front is lifted up, wheels will come off
3 Suggested Answers
SOURCE: front swivel wheels fall off
I found your fee for 1 solution to be too high. I emailed the evenflo company and they helped me solve the problem.
Thanx for checking.
Posted on Aug 27, 2009
  • 274 Answers
SOURCE: Wheel keeps falling off my pram.
contact www.buggypitstop.co.uk they sell spare parts
Posted on Apr 15, 2010
Possible reason why 04 chevy tahoe 4wd works up in air on lift but not on ground
the residual force makes it look like its working on a lift ,
check your wheel sensors the speed sensor determines how fast each wheel is turning say in the snow , if the sensor fails it wont go into 4 wheel drive.
Feb 19, 2015 | Cars & Trucks
Got a 2004 Ford F-150 transfer case i gauges front drive shaft turns but front axle does not lock into 4 wheel drive what could be causing issue its a shift on the floor lights for low come on but not high...
Check your hubs lift front end if wheel does not turn when locked in 4x4 then hubs are not engaging turn wheel by hand or a pipe wrench on drive shaft do not try power unless all wheels are lifted
Jan 02, 2015 | 2004 Ford F150
Wheel bearing
If grinding noise is heard coming from front side, lift up both the front wheels and rotate the wheels one by one to listen to the sound, if any. If a noise is heard, replace the front wheel bearings as a set.
If the front wheels do not produce any abnormal noise when rotated, lift down the front vehicle. Lock the front wheels with blocks, release the hand brake. lift up the rear wheels and try to listen to the abnormal noise. If the noise is heard, replace the differential bearings and seals. Top up the differential oil to the mark.
Dec 12, 2013 | 1998 Toyota Tacoma
Rattling noise in left front end of truck near wheel well at slow speeds
Remove the front wheel and check the wheel bearing, sometimes you may have to may have to put a bar under the wheel and try to lift it up hard, this will give you an indication on where any movement is. THERE IS A PROBLEM and you need to find it
Nov 29, 2013 | 2006 Ford F-150
Where do I put the siccor jack to life the car so I can change the front wheel?
In the grove in the middle of your framenotch go's into notch in jack good luck to ya.
Mar 30, 2011 | 2002 Suzuki Vitara
THE LEFT SIDE OF THE HANDLE BAR SEEMS TO BE HEAVY THAN THE RIGHT HANDLE BAR.. SO I CAN FEEL THE INBALANCE WHENEVER I RUN THE CB IN THE HIGHWAY...
Lift the bike off the ground (front end), turn steering side to side, should be smooth all the way (not notchy), check your tyres both front and rear, uneven wear, warped rim, should spin freely and true (wheel bearings) than check for fluids on your fork legs, your front fork seals may be leaking or the oil may be due for a change!!
Feb 14, 2011 | Honda Cb 400 F Motorcycles
When i try and lift the front wheel it wont lift up
If you mean when you are riding you need to lean back over the back of the seat as you pull up to get the front wheel off the ground
Jun 06, 2010 | Groove Tubes 2009 GT Bump BMX Freestyle...
How to remove front tire on 2003 harley flhtcui
To remove the front tire, you'll need something to lift the bike with like a frame jack. Position the jack under the bike and lift it slighty but not completely off the ground. Make sure the bike is stable and will not fall.
Lift the bike until the weight is off the front wheel but the wheel is not off of the ground. Loosen and remove the axle nut and loosen the two bolts on the bottom of the fork slider on one side. Slide the axle out of the wheel.
Now, carefully continue to lift the bike until you can get the wheel out from under the front fender. Make sure that you mark or can remember where any spacers go and in what direction they face on the axle.
Feb 17, 2010 | 2003 Harley Davidson FLHTCUI Electra Glide...
Baby Gear Logo
Top Chicco Baby Gear Experts
Rommel Balcita
thegtw
Dorel UK
Dorel UK
Are you a Chicco Baby Gear Expert? Answer questions, earn points and help others
