Question about Foxconn G41MXE Motherboard
How to check a G41MXE motherboard
Power supply is good, but pc will not startup.
  • joecoolvette
    joecoolvette Nov 03, 2012
    1) What are the volt ratings of the 3 main voltage power rails, of the Power Supply? 2) Did you clean the ram memory module/s, gold plated contact pins, and reinstall ram memory module/s? 3) Computer dirty inside?
  • Foxconn Master
  • 3,606 Answers
Hello the mainboard home page is here:
http://www.foxconnchannel.com/ProductDetail.aspx?T=motherboard&U=en-us0000483
Try to download a manual and check the mainboard up
for any loose connections i mean the front panel wire
so the mainboard can start.
The power switch cable or ON/OFF must be placed correctly.
If no luck the board is dead.
The front panel connector look like this:
Good luck
Posted on Nov 04, 2012
I need to download bios updated FOXCONN G41MXE-K
hope this helps
Download Foxconn G41MXE G41MXE-K P10 motherboard BIOS ...
https://www.wimsbios.com > BIOS Updates > Foxconn
Download and update your Foxconn G41MXE G41MXE-K P10 motherboard BIOS - Foxconn_G41MXE to the latest version.
Apr 02, 2017 | Foxconn Computers & Internet
No Display
If you are testing the motherboard by removing items plugged into it, remember to leave the CPU Heatsink on if the CPU is still in the socket otherwise the CPU will overheat in seconds or minutes and could be damaged.
If you power on the system, do the fans spin? such as the CPU heatsink fan? If no fans are spinning that are connected to the motherboard, see if the fan is spinning inside the power supply using a flashlight if needed. If not, try a known good power outlet or different plug on your surge bar or a new surge bar.
Even if the power supply fan is spinning, the power supply could be faulty. Borrow or buy one that matches the current wattage written on the side (ie: "output 350W")
Post back here with more info or if anything of this sounds like the issue you are having.
Apr 13, 2014 | Foxconn G41MXE Motherboard
No display & blink power led
This sounds like a power supply issue. Are the fans in the system plugged into the board? If so, are they kicking on and off at the same time at the power light? Make sure you have a good working PSU and tried that in place of the one you are using.
If that doesn't work, start removing parts until you have just the motherboard and the case speaker plugged in (plus your power button of course). Once you have removed the faulty device, you should start getting a beep code from the motherboard. If you put a known good part back in and it does it again, then the slot on the board that the part seats into is bad (IE: RAM slot if RAM replaced, etc) and you need a new motherboard.
Nov 18, 2013 | Foxconn G41MXE Motherboard
Motherboard turnon but few second after failure
A motherboard automatically turning itself off could be a few problems.
1: Your RAM might not be compatible with each other. If you have more than one stick of RAM, make sure the brands are the same, or are compatible with each other in the least. Also make sure that the type of RAM (DDR3) is the type of RAM you have inserted.
2: Cords. Inside the computer, some of the cord connections might not be properly connected. Check primarily on your HDD, as well as any other main drives you have (CD Drive, Hard Disk Drive, and a Floppy Disk drive if you have it.) Check to make sure all the necessary cords start somewhere in the board, and end somewhere in a place if there is a place for them to end.
3: Power Supply. On most computers that I've used, near the power supply is a tiny little level/switch thing that controls how much power the computer gets. It could be this. If a motherboard is getting more power than it needs, then it automatically will shut off because it has no place to put the extra energy.
Sep 20, 2012 | Foxconn G41MXE Core 2 Quad Intel G41 DDR3...
Max memory for g41mxe
http://www.foxconnchannel.com/product/motherboards/detail_spec.aspx?ID=en-us0000505
Sep 15, 2011 | Foxconn G41MXE Core 2 Quad Intel G41 DDR3...
Hi there its a foxconn g41mxe board... The power is connected, everything installed... But seems to put out no vga signal on the vga port onboard the mobo. Please advise tnx
Test the PSU if the units fan is not working the power supply unit is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error If your computer came with a motherboard disc the drivers could be on it or you might have a dirty graphics card remove the graphics card and clean the socket
hope this helps
Jun 10, 2011 | Foxconn G41mxe Mb Mb Intel 775 Intel G41...
Foxconn G41MXE Motherboard Logo
740 people viewed this question
Top Foxconn Computers & Internet Experts
Rommel Balcita
David
David
Gareth Cockram
Gareth Cockram
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
