I want to connect my heating system with my generator. It's a forced hot air system natural gas by York.
  • 38 Answers
Yes, you need to have at least 120volts and make sure your generater can power at least 3000 watts min not peak.
if you have an extension cord and must find the supply to the furnace
then splice the cord to the supply
then plug it in and there you go.
Posted on Nov 03, 2012
5 Suggested Answers
  • 182 Answers
SOURCE: WeatherKing Acclaim II
not only the jets but you need to change the spring in the gas valve and cut the pressure WAY back to prolly 3.5"wc
Posted on Nov 23, 2008
luker711
  • 91 Answers
SOURCE: no air flow from duct on forced air unit
If there is no air coming through all of ducts, there are several things to consider. If you turn your thermostat to fan on, does air come out? If so you may have a switching|thermostat problem. May need to change out, not really hard you just have to turn off electric mark wires as you remove and turn back on. If nothing changed, make sure the circuit breaker has tripped, sometimes its hard to tell so flip it all the way off then back on. Now try to turn on again. If it comes on you need to find out why it's tripping the breaker, merely resetting it can pose a danger for the future. Professionally servicing the unit is important to the longevity of the unit. Now if you find out that unit is coming on but no air is coming out, it could well be that a duct has blown free and is spilling into attic or crawl space. Sometimes the unit forms an ice block in the evaporative area of the unit. In this case it would need quite some time off to thaw. Also the fan motor may be burned out. In that case you would hear part of the unit working with no output. These are a few of the most common problems with this condition.Most of which needs to be addressed by a Tech
Posted on Jul 15, 2009
  • 3074 Answers
SOURCE: I have a Rudd natural
check for power at unit, as it may be the disconnect fuse/breaker. The only other thing is the main board, but it sounds like there is no power to the unit. I hope this helps Tim
Posted on Sep 23, 2010
qasolution
  • 107 Answers
SOURCE: York Air Conditioner unit doesn't turn on
jumper red to yellow on thermostat if it kicks on problem is in the thermostat.
Posted on Apr 22, 2012
York gas furnace pilot lights and begins heat cycle but burner quickly goes out and system continues to run blowing cold air
There is a flame sensor that holds the gas valve open when there is a flame present. Heat generates about 10 to 15 milivolts to do this. Make sure the side of the flame is touching the sensor. If it looks ok Tighten the fitting that holds the sensor to the gas valve. If it still won't stay lit after all that then replace the sensor. They do fail with time.
Mar 29, 2015 | Heating & Cooling
When a generator is heating after a few minutes what could be the cause
not enough information to answer. gas or propane?. if new,generator by it's very nature generates energy,and thereby heat. even coiled wires can get warm. what part is hot?
if you've owned it a while, and it is inordinately hot as compared to prior uses, is it lubricated ? running normal otherwise?
Jan 21, 2015 | Electrical Supplies
Wires don't match the new thermostat posts. The wires from the furnace are Red,Blue black and white The posts in new thermostat are B O G Y not used R and Rc Can't figure which to put
The wire colors are for the following functions ......red - 24 volts white - heat yellow - AC green/blue - blower (fan) red is connected to the R with a jumper between R and Rc What type of furnace/heat do you have ???? Electric. oil, gas .Forced hot air, baseboard, steam, heat pump, or ?????? Different systems use different connections and need a specific thermostat for that application !!!
Dec 13, 2014 | Heating & Cooling
My laar hot shot natural gas pool heater pilot says lit but wont fire any more replaced pilot generator pilot that whole unit nice pilot but wont fire
problem isnt with the pilot generator. you have either an open safety withing circuit, lose wiring connection, or tstat issue
Aug 17, 2013 | Teledyne Laars Laars Lite 2 Pool Heater...
The pilot is on and it looks good. I turn the thermostat up but nothing more happens.
Despite the simplicity of a Millivolt system,troubleshooting them is often not as simple, if you go by the book using a Volt/Ohm meter to test the generator and gas valve. The Pilot Generators are less tricky as they all put out 750 mv or 3/4 of a volt out of the system, in the system is where each result will be specific according to what gas valve is used, not all gas valves have the same ohm's values, and many newer gas valves cannot be ohmed due to the design!
They will read open every one of them.
The way to make it simple and assure you never get any call backs
is to take a AA battery and attach a wire to each end of the battery,
Radio shack sells battery boxes with leads built in for several dollars.
Remove the 2 leads from the gas valve coming from the pilot generator and replace them with the AA battery leads If the gas valve operates normally via battery, it is a good gas valve, if not it is bad.
If you apply voltage to the gas valve and get zero amp draw,the gas valve is bad. Do not leave the battery in place and operate the unit in this manner unless you are able to be diligently watching it, never sleep or leave etc, it is strictly for emergency use or testing.
Old time units had no pilot safety, the pilot valve was manually operated just like a garden hose, if the wind blew it out it still kept coming, however as natural gas is lighter than air it will vent if it is allowed to via the flue, propane units must have 100% safety for the pilots operation as propane is heavier than air and will not vent, it settles in the lowest spot making propane more dangerous in that respect than natural gas is.
750 mv is 3/4 of 1 volt, not much power, the thermopile makes this power by having 2 dissimilar metals co joined in the end of the thermopiles that impinges the pilot flame.
A temperature differential must be maintained across the thermopiles end, if the entire end of the thermopile is hot the power will drop off or stop all together, thus extinguishing the pilot.
Many homeowners make the mistake of setting the thermopile too far into the flame, heating the entire end, not just the top 1/3 portion thinking this will bake it into submission, or force it to make power when in reality it does the opposite.
Mar 08, 2013 | Napoleon 36" Zero Clearance Top/Rear Vent...
Kohler Generator won't start
If you have a drip leg near generator open that up for a sec and then try it again.
Nov 16, 2012 | Kohler Electrical Supplies
My Eternal Hybrid natural-gas hot water heater, Model Number GU195 stopped working, and gives a E02 error code. When the heater automatically attempts to burn, the natural gas doesn't, until the...
I'm having a similar problem. My water heater is Eternal GU195S. It will heat up the water it's in the tank so I will get hot water for a few minutes. Then whenever the system tried to heat up on-demand, it will not heat up and gave E02 error. If I stopped drawing water, the E02 error will go away and the temp setting I had will come back on. What could be the problem? I currently took it out of service and set it up outside my work shop for testing. Thanks.
Sep 08, 2011 | Heating & Cooling
No hot water
Aquastar 1600H NG Natural Gas Tankless Water Heater Bosch AquaStar Model 1600H NG Natural Gas Whole house tankless gas water heater, 117,000 Btu input, natural draft with hydro-generated ignition. Provides endless hot water for one major application at a time . Can replace 40-gallon storage tank water heater. Optional Accessory: Model AQ1- Power vent with built-in... More freeze protection when venting horizontally. Capacity: 1 to 2 Bathrooms Dimensions: 8.75D x 18.25 W x 29.75H Weight: 40 Max GPM @ 45F Rise: 4.2 Energy Factor: NG .80 LP .84 Minimum Input: 28,000 Maximum Input: 117,000 Vent Size: 5 Gas Connection: 3/4 Water Connections: 1/2 Warranty: 12-year warranty on heat exchanger, 2-year on parts Features: Endless hot water Can save up to 50% off utility costs annually Perfect for one major application at a time No standing pilot, hydro generated
Mar 01, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Trouble with waterheater
DO NOT USE THIS HEATER UNTIL IT HAS BEEN CHECKED OUT BY A PROFESSIONAL!
Most all gas appliances can use propane or natural gas, but they ship from the factory with orifices for one or the other.
Propane is rated at 11 iwg, natural gas at 7 iwg (where iwg=inches water gauge. 27 iwg=1 psig) (it takes a different regulator spring to handle this small difference in pressure.
A propane orifice will be smaller than a natural gas orifice.
The store that you bought the water heater should know what they sold you, and know if they have a kit to convert the regulator and orifices.
Jan 15, 2009 | Reddy Heater RLP100 Portable Forced Air...
Black Soot coming from heating vents Powered by Gas
Danger..........You guys both have a problem with incomplete combustion and or a possible heat exchanger breech..carbon monoxide is a very great possibility...don't mess around with it call the fire department and force the landlord to repair it.
Nov 18, 2008 | Empire DV-215 Direct Vent Natural Gas...
Heating & Cooling Logo
74 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
