Question about Sony FD Trinitron WEGA KV-34HS420 34" TV
Trinitron tv won't come on. says please wait
Tv wont' come all the way on. Onscreen message says, "please wait". When playing DVD, it works OK. Just won't work with cable. Cable is OK with different TV.
    Top Expert:
  • Sony Master
  • 14,553 Answers
There may be a issue with the tuner on the set but there is a way around that.
With a cable box with audio/video out jacks connect to the same kind on the rear of the set---go to that input on the set and should see picture and sound---leave set on that input and change/select channels with the box.
Posted on Nov 03, 2012
5 Suggested Answers
  • 308 Answers
SOURCE: double images on my Sony FD Trinitron WEGA KV-27FS100
You may want to try disconnecting the power for about 30 seconds and rechecking the TV. Otherwise, it may not be worthwhile repairing.
Posted on May 29, 2007
  • 20 Answers
SOURCE: Sony Trinitron Tv
Dear sammy5,
Stop by any TV repair shop in your area, and ask to borrow a used original Sony remote, they may require a small deposit; access the menu, perform your set up, then return it. Or you could buy a universal Sony remote from Walmart that should work just fine, for about. $7.00.
Hope this helps.
Richard
Posted on Nov 08, 2007
welcomejee
  • 10594 Answers
SOURCE: Green symbol AV2 won't go away! Sony Trinitron KD-28DL11U
You need to have original Sony TV remote and press Display button on it, on-screen display will disappear.
Posted on Nov 25, 2008
  • 86 Answers
SOURCE: Can't figure out how to turn on cable on Sony Trinitron TV
Setting Up the TV
After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
(Make sure CABLE is connected on coaxial and you are not using any other connections such as cable box, hdtv or satellite antenna)
1 Press to turn on the TV. The Initial Setup screen appears.
2 Press on the remote control or on the TV front panel to start Auto Program, or press
to exit.
To perform Auto Program again
Press .
2 Press g to highlight Channel Menu.
3 Press f to highlight Cable. Press to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select.
5 Press f to highlight Auto Program. Press to search for channels.
6 After Auto Program finishes, press to exit.
To reset the TV to factory settings
Turn the TV on.
2 Hold down on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release .
✍ When you start Auto Program wait until it is finished; otherwise it will skip over channels that are
available. Perform Auto Program again to program receivable channels.
✍ The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
Initial Setup
Auto Program [CH+]
[CH–]
First please connect
cable/antenna
Exit
Posted on Jan 17, 2009
Why am i getting ''please wait try again later'' message
Test the remote control. Use the digital camera , point the r control viewing the camera, and with the camerA ON, you must see the LED I.R ON. see the picture. If NOT you must open the remote and clean the keypads from dirty+ and resolder the cold joint from the LED.
try again. However if the LED is o.k read your owner manual download for free go www. fitness.manualsonline.com
Feb 09, 2013 | Televison & Video
Won't boot up. Error message "
did you try pluging into charger, my galaxy 2 if i run battery all the way down it wont do anything after it shuts down. at times i have had to plug in and wait sometimes 15-20 min before it will even flicker. hope it helps
Dec 31, 2012 | Cell Phones
Can't get the words for the songs to show on the TV screen
Check whether the output taken from from the Vocopro is from video/audio out. By mistake, if you had connected the RCA cable to the 'input', you won't get any audio or video and also stand a chance to damage both the devices, as video in/out is a very sensitive line.
Aug 05, 2012 | Televison & Video
Hp4355 print catridge error
Each cartridge having printing life, as long as cartridge health condition is good it won't gives any trouble. Subjected series printer having mono & colour cartridges,1. Remove both cartridge from the printer 2. Switch on & wait till message appears for insert the cartridges..3. Insert mono(Black) cartridge, close the door & wait till message appears on screen. If message appears same as cartridge error mean that mono cartridge is faulty replace it, if message appears like insert another cartridge, it's confirmed that colour cartridge faulty.. Replace it..
Apr 28, 2012 | HP Officejet 4355 All-In-One InkJet...
Sony Trinitron TV's is making a fuzzy noise from the TV's speakers but when played via my amp everything is fine....
Hello
The audio output IC of your TV is faulty. It should be replaced with same type and number. If there is some loose sodering on the solder terminals of this IC, this type of fault can occur too. So check this first, before replacing the IC. Ok
Nov 22, 2011 | Televison & Video
There is the word "video
hi,
Press the Display button on the remote to switch off onscreen displays.
ok
Jun 21, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have " Sony FD Trinitron WEGA KV-36HS420 36" TV
U have a soldering iron,desoldering pump or a roll of desoldering braids,a roll of solders?Can u do basic soldering and uderstand basic electronic?FBT- the flyback transformer,the big black block of a plastic with a red wire with a cap hook to a CRT-tv picture tube.Near the big block of a plastic with a red wire with a cap hook to a CRT picture tube.Inside to the right of the FBT,there are 2 power supply ICS,those 2 ICS are dead.Replaced these 2 power supply ICS near the FBT,will solved this tv LED power light indication blinking and will have stable tv power again,and tv will work.
Nov 29, 2010 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Sony FD Trinitron WEGA KV-34HS420 34" TV Logo
52 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
