Question about Dryers
Door keeps opening on white knight CL 741 condenser dryer
Close the door and it opens again!!!!
    Top Expert:
  • Dryers Master
  • 9,472 Answers
You will need to replace the lock assembly.
Posted on Nov 03, 2012
SOURCE: White Knight condenser dryer trips the electirc
Hi i bought my dryer 4 years ago and within three months i had a technician to it3 three times, it had the same problem as yours all my fuses were tripping in the fuse box. eventually after 4 visits, the technician said there was a tiny hole in the back of the dryer which was letting condensation through and was dripping onto the motor. he put a small piece of rubber in the hole to make a stopper and it hasn't done it since. seems like a common problem but unfortunately only very few technicians seem to know how to solve the problem, thankfully it was still under guarantee at the time so got repaired, hope this helps and good look!!
Andrea
Posted on Apr 26, 2009
  • 24 Answers
SOURCE: I NEED A USER MANUAL FOR THE WHITE KNIGHT
Crosslee plc is an appliances company formed from the tumble dryer division of Philips. Its best known products are White Knight brand tumble dryers. The company is based in Halifax, West Yorkshire, England.
here is ther main webpage:
http://www.crosslee.co.uk/english/index.html
Try contacting them thru e-mail about getting manual most company's will give a copy/or post one on their website for free.
good luck
Posted on Aug 04, 2009
apart4u
  • 213 Answers
SOURCE: my white knight condenser dryer doesn't heat up
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat is this video does not help go to our video section and there are a few on other condenser dryers
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
Posted on May 10, 2010
apart4u
  • 213 Answers
SOURCE: Just replaced the heating element
SOURCE: white knight tumble dryer (condensing)
I have a whikpool condenser dryer that seems to work but has all the lights come on and a buzzing noise,any ideas to what it could be please? I have clearned all the filters etc
Posted on Dec 02, 2010
Timer switch faultynonnwhite knight 44 aw . Will work for a couple of months then not, then start working again for a while then not?
Motor in timer is stopping heats up stops needs new timer
also check even heat board or cycling stats if these stats do not open timer will not move also check for vent restrictions if dryer over heats can also be a issue send me exact model number or picture of Tag will be bedder
Feb 19, 2015 | Abbaka White Knight 44AW Electric Dryer
My white knight turns on but dosnt spin but belt is ok can u help plz tried reset button but nothing happens
This will likely be the capacitor to the motor. A cheap & common fault to fix. With the door open and the timer set spin the drum by hand and close the door the cycle shouldvstart and your drum will then turn. Sure sign your capacitors blown.
Nov 01, 2014 | Dryers
My white knight condenser tumble dryer keeps
is it just shutting off or is it tripping ur breaker?
Dryer runs then shuts down wont start up for an hour:
Bad motor windings
Oct 13, 2014 | Dryers
My white knight condenser tumble dryer keeps tripping everything. Then if I leave it a white it works again what could it be?
sounds like the water is getting into element you will have to check all filters and check that your pump is working properly
My white knight tumble dryer wont start
Nothing works or drum fails to turn (tumble dryers)
Ensure that the power supply to the dryer is switched on, the timer is set to the desired drying time and the door is correctly closed. If you have a condenser model, also check that the bottle is empty and is fully pushed into the machine.
http://www.whiteknightrange.co.uk/whiteknight/faq.html
The first thing to establish when troubleshooting the clothes dryer is whether the dryer will start or not. If it won't, start by checking the outlet and the circuit breaker. Is the dryer plugged in or has it tripped the circuit breaker? If the breaker has been tripped, flip it back on and try the dryer again. The drum should turn without a problem.
If both plug and breaker are fine, you'll need to inspect the door switch as you continue to troubleshoot the tumble dryer. When you close the door on the dryer, a plastic peg should click and operate the switch which allows the dryer to work. The peg might be bent or broken, in which case it won't connect with the switch. You can try to straighten the peg, but if it's broken, you'll need to replace it. If the peg is fine, the switch has probably failed and will need to be replaced.
http://www.doityourself.com/stry/troubleshooting-a-clothes-dryer-drum-doesnt-tumble#b#ixzz3FOOQgtAT
Oct 06, 2014 | White Knight Press Genuine Tumble Dryer...
I need a user manual for my White Knight Washer Drier
Try this PDF this seems to be for the 77AW by White Knight!
Jun 24, 2012 | Washing Machines
White knight tumble dryer CL432WV wiring diagram please
This has lots of diagrams on white knight http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
Apr 19, 2010 | Dryers
I have a new capacitor for my white knight
capacitor change and how to fit see our full list of Free Video Repairs
Mar 03, 2010 | Dryers
I NEED A USER MANUAL FOR THE WHITE KNIGHT CONDENSER DRYER CL 767
good luck
Aug 04, 2009 | Dryers
Dryers Logo
61 people viewed this question
Top Dryers Experts
