Question about Maytag Atlantis MDG7400AW Gas Dryer
Maytag Atlantis MDG7400AW Gas Dryer not drying clothes
Gas dryer is not heating up when there are wet clothes in it. But if you put dry clothes inside it they heat up on a normaly and the same if there are no clothes in it. Whats the proublum?
  • 5 more comments
  • Anonymous Feb 12, 2009
    gas dryer is not heating up
  • glide58 Feb 21, 2009
    When empty/ or dry clothes hetas up works great put in wet sock it doesn't heat up!!!
  • Daryl Bear Mar 02, 2009
    Our gas dryer does not heat up in any of the three cycle areas.
    This was tested with wet clothes inside.
    The burner will go on occasionally for a few seconds but turns off within 10 seconds or so and does not come back on.
    Something is turning it off - all other functions of the dryer are working ok. The vent system has been totally cleaned out.
  • Anonymous Mar 12, 2014
    Sometimes no heat is generated clothes still wet & cold. Other times mild heat still not drying clothers.
  • Anonymous Mar 24, 2014
    My dryer wont heat up and dry clothes
    there is black stuff in the drum and on the clothes when we dry them
  • Anonymous Apr 01, 2014
    Gas comes on but clothes do not dry
    Problem Solver:
  • 11 Answers
This problem doesn't sound right, but you could have a bad moisture sensor.
Posted on May 20, 2007
My maytag gas dryer work on dry cloth and stays hot but as soon as i put wet cloths in it they wont dry ?
My dryers timer wouldn't work correctly and the clothes were taking forever to dry. I decided to check the vent. My advice....Always check your dryer vent before spending any money on unnecessary parts or service calls. This Nest was pulled out of my vent with my shop vac sucking out and my house vac blowing out from inside. It finally broke free and now my dryer works like new.
Sep 24, 2011 | Maytag Atlantis MDG7400AW Gas Dryer
The Atlantis Gas Dryer comes on, heats the clothes, but will not tumble the clothes so that only the outside of the clothes are dry.
hello,
I believe the the problem with your dryer is a broken belt this youtube i have attached will show you how to replace it
http://youtu.be/6ufArteqWXk
Jul 23, 2011 | Maytag Atlantis MDG7400AW Gas Dryer
My dryer will not heat.....the drum spins and air appears to be blowing but not heating up to dry clothes
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 02, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
Our dryer takes a long time to dry clothes. If the airvent that goes outside of the ouse is clogged...would that affect the dryer? Stupid question i know, but we have like 5 feet of snow outside, so it's...
Yes this would affect try time as your dryer is not able to move the moist air out of the dryer. That is probably your problem. The other issue would be gas coils if it heats at the beginning of the cycle and stops heating towards the end.
Hope this helps _MJ_
Feb 07, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag atlantis gas dry is not heating up its about 6 years old
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Mar 28, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
White clothes have black streaks after drying.
You will have to have the dryer drum felts replaced. It requires removing the drum from the dryer so you may want to have a technician do this because removing the belt can be tricky.
Jan 24, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag Atlantis MDG8400AWW Dryer Runs Cool
I had a similar problem years back. It was the ignitor. The ignitor is a ceramic like piece that heats up (glows red) that ignites the gas. Typically when that goes, you will see some white residue build up where it cracked, thus breaking the electrical connection. This thing works like a heating element on an electric stove, but rougher looking.
The part was about $30 at my local parts store. I bought an extra one just in case so I have it on hand. I installed it with common tools.
You can check it to see if you lost connection by using a volt meter.
Good luck.
Dec 29, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Mytag Dryer ModelLdg4000Aw
I have a Maytag Atlantis Gas Dryer that will turn on, rotate, but will not get hot and dry the clothes. A load of clothes in the afternoon, didn’t dry, tried again but didn’t dry – went to bed after putting on auto dry - next morning the dryer was still rotating and didn’t turn off. No hot air – only cold air.
Jul 13, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag Atlantis MDG7400AW Gas Dryer Logo
975 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
