My packard bell model pew91 turns on but only a white screen and black lines come up it wont do anything else
Not able to go any further than turning it on to a white screen with black lines
priyabrat
  • 123 Answers
SOURCE: Monitor not coming on - Packard Bell Easynote R4650
It's a dreadful way to start a day - you press the power button on your computer and nothing happens. Do not fear because all may not be lost! Follow these simple steps to determine why your computer won't turn on.
Note: It is very important to troubleshoot any issue beginning with the most likely and easily testable problem so be sure to follow these steps in order.
Difficulty: Average
Time Required: Anywhere from 10 minutes to a few hours or more depending on why the computer won't turn on
Here's How:
As silly as it may sound, the number one reason why a computer won't turn on is because it wasn't turned on! Before starting a sometimes time consuming troubleshooting process, make sure you've turned on every power switch and power button associated with your computer:
Power button/switch on the front of the computer's case.
Power button/switch on the front and/or back of the monitor.
Power switch on the power supply on the back of the computer.
Power switch on the power strip or surge protector (if you have one).
Verify that the power supply voltage switch is correctly set. If the input voltage for the power supply does not match the correct setting for your country, your computer may not power on.
Check for loose computer and monitor power cable connections. A loose or unplugged power cable is one of the top reasons why a computer doesn't turn on.
Perform a "lamp test" to verify power is being provided. Your computer isn't going to turn on if it's not getting power so you need to make sure that the power source is working properly.
A damaged power supply could be preventing the computer from being properly powered.
Do a quick test of the power supply by holding your hand behind the power supply fan located at the rear of the case. If the power supply is working, you should feel air from within the case blowing against your hand. If not, you may need to replace the power supply.
Tip: Is the power light on the front of the computer's case on? If you've turned the power switch on but the light is off, this is another good indication that the power supply is the cause of this issue.
Over time, internal components and the cables that connect them can wiggle loose which can often times result in a computer unable to power on. Try reseating the following and then try to power on the computer again:
Reseat the internal cables
Reseat the memory modules
Reseat the video card
Reseat other expansion cards
Reseating the CPU may also be necessary but should only be attempted if the reseating of all other components is not successful. This is due to the fact that this process is a little more involved and can run a small risk of damage to the CPU. This isn't a big concern if you're careful, so don't worry!
Check for causes of electrical shorts in the computer case. This is often the cause of the problem when the computer powers on for a second or two but then powers off completely.
Most monitors have a small light next to the power button that can change between various colors. If the screen is blank, this light is your main source of information about the monitor.
If this light is not on at all, double-check the power switch and connections (Steps 1, 2 and 3) and also make sure the monitor cable is securely plugged in to the video card port on the back of the computer case. If the light is still off, replace the monitor. If it comes back on, try starting your computer again - a loose or unplugged monitor cable may have been the issue all along.
An amber or yellow power light simply means that the monitor is not receiving any information from the computer. In and of itself, this doesn't tell us much.
On the other hand, if the light is amber or yellow, the computer power light is on, and the hard drive is active (making familiar sounds and the hard drive activity light on the computer case is blinking), the computer is probably starting normally but the video card is not sending information to the monitor. Replace the video card.
Beep codes (see Step 11) usually sound when a video card has malfunctioned but this is not always the case.
Is your computer making a beeping sound? Sometimes a computer will turn on just enough to play a series of beeps from the speakers.
These beep codes play in particular sequences and represent a specific problem that your computer is having. Troubleshoot the beep code to figure out what it's saying and then service the computer as necessary.
Tips:
Still can't get your computer to turn on? Let a community of computer support enthusiasts help out! Post the details of your problem in the Focus on PC Support Forums.
Posted on Jan 26, 2008
sergio_bonjo
  • 33 Answers
SOURCE: black screen when i turn on the computer
post comment in my yahoomail so thAT i can kep in touch with you!!sergio_bonjovi@yahoo.com
when you turn on the computer does the computer beeps?how many times does it beeps? when your computer beeps 3 times faster..try to check you video card!!!! but when the computer continues to beep and beep try to check the modules or the memory try to replace it with a new memory!!! but when you turn on your pc and no beep at all your motherboard will be the problem?so did i answer your questions?
Posted on Jul 23, 2009
tennison
  • 13 Answers
SOURCE: My packard bell pc just stopped working
I think This is BIOS problem so
open CPU box and clear bios settings...
oterwise change tha mother board
TENNISON J
Posted on Aug 29, 2009
pappapumpdaf
  • 635 Answers
SOURCE: i tried reset my laptop packard bell easynote r4
Sounds like the hard drive ies and you lost your restore partition. You will probably need a new drive and hopefully you already have a restore cd.
Posted on Mar 09, 2010
  • 383 Answers
SOURCE: my packard bell ixtreme 5830 wont turn on. the
if it beeps there is a memory problem inside if not turn it on so its orange turn it a round and flip the the red switch on the back of the power suppy, multiple times and then start turning off the computer, ive got that to work it could just something dumb with the power supply
Posted on Jun 12, 2010
Network adapter
Mih. re post your question, with the complete question,make and model #'s.
Feb 23, 2016 | Packard Bell PEW91 keyboard - PEW91 laptop...
Packard bell pew91
No . Notebook graphics are buiilt into the main card (motherboard).
Aug 03, 2014 | Computers & Internet
Laptop won't turn on, no signs of life apart from red light.
Hi!
In that case you have to consult into a technician.
It might be a little configuration into BIOS.
Jan 25, 2014 | Packard Bell PEW91 keyboard - PEW91 laptop...
Easynote pew91 wont power up
need more specifics. Is the battery faulty? have you checked the power supply? is bios in order?
Apr 10, 2013 | Packard Bell Computers & Internet
Have it blu ray?
As a follow up to this, what's the easiest way to convert that .mkv file to a more size friendly file? Which program will keep the best quality and what would you suggest as size?
Computer Support ' Dell Support
Feb 03, 2013 | Packard Bell PEW91 keyboard - PEW91 laptop...
Packard Bell monitor showing colors
Replace the monitor, is dead.
Aug 04, 2012 | Computers & Internet
I have packard bell pew91 . and i format my laptop . and i have no driver cd so pls can u send me all driver file on my id pls
The Packard Bell Easynote TK87? (PEW91)
http://www.packardbell.co.uk/pb/en/GB/content/download
1) Click on Notebook under the Select Product Family heading
2) Click on Easynote under the Select Product Line
3) Under the Select Product Model heading scroll down, click on TK87.
Regards,
joecoolvette
Jul 02, 2011 | Computers & Internet
Easynote laptop packard bell
Try Safe mode, disable display adapter and restart. See if this helped.
Nov 04, 2008 | Packard Bell Computers & Internet
Computers & Internet Logo
110 people viewed this question
David Payne
David Payne
