Question about Cameras
Have canon cooplex 4000. PictureProject 1.1 that came with it doesn't work with Windows7
Doesn't work with Windows7
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
You do mean Nikon Coolpix, don't you?
PictureProject was retired years ago. You can get the current versions of all (free) Nikon software from here.
You don't need any special software. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said earlier, you can use any photo cataloging program such as Nikon Transfer or Picasa.
Posted on Nov 02, 2012
My amp was blinking while it was working then it went off.Now it doesn't power up..Crown Xti 4000
Power supply likely failed. Electrolytics are the primary culprit.
It should have a switchmode power supply, so it is lmost likely the 5 volt section failed.
Sep 17, 2012 | Crown XTi 4000 Amplifier
How to run windows7 64-bit
Yeah. If your CPU doesn't support 64-bit processes it wont work to run Windows 7 64-bit on it.
Aug 19, 2012 | Dell Intel 82945G Express Chipset Family
Keyspan's drivers won't work on Win7 . . . Install MS's Virtual PC. Add usbd.sys to windows/system32/drivers (virtual box doesn't think it needs to load the virtual usb drivers, so i
1. instal server utility on Windows 7
2. right click icon choose properties
3. select compatibility tab choose vista sp2
now run it and presto......
regards, dean
Jul 06, 2012 | Keyspan USB Server US-4A (d47710) Print...
I was using vista before then changed to windows7. camera doesn't work...
You need to re download the your camera drivers for your windows7
Aug 30, 2011 | Computers & Internet
Need to download pictureproject bug don't have product code
PictureProject was retired years ago. You can download the current versions of all (free) Nikon software from
http://support.nikontech.com/app/answers/detail/a_id/61
Jun 24, 2011 | Nikon Coolpix L11 Digital Camera
When i plug my nikon coolpix into my computer, my computer doesn't think it's plugged in and nothing pops up for me to transfer photos.
Hi there, To get your camera to connect to your computer, follow these steps: 1) Enable USB mode - press menu, go up, and select setup. Select USB and press OK. Select Mass storage and press OK. Save the changes. 2) Make sure the PictureProject software is installed from the CD that came with the camera. 3) Launch PictureProject 4) Connect the camera to the computer 5) Turn on the camera and press the "transfer" button. Alex
Jun 04, 2011 | Nikon Coolpix S4000 Digital Camera
CODE EROR E 216- 0000
try to clear error.
press *28* (2 and 8 press together) - Copier - ERR - CLR - OK - switch Off - (wait 5 second) - switch On.
if it doesn't changed. you must replace a new the scan lamp or motor scaner .
May 21, 2011 | Canon CLC 4000 Copier
I have a performance teknique ICBM power 4000 watt 1 ohm when I put the load to 1 ohm it goes to protect **** at a 4 ohm load it slaps dosnt clip are anyting is it a power problem
check that load with an ohm meter. a 1 ohm load is very low and just the wires would increase the load. also as speakers age they can go lower on the actual ohm being used so even if the circuit would seem to add up to one ohm it may be even lower. If the amp is going to protect mode the load is just to great and it doesn't want to burn itself up. a good meter will tell you the real ohm load at the amp. make sure you get a good connection between the meter and the load. don't overload the amp it is not safe. also some speakers are "power hungry" or less effective at using the amps watts of power
Apr 21, 2011 | Car Audio & Video
Cameras Logo
46 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
