Question about Jenn-Air JUC2450ARS Compact Refrigerator
How do I tighten the door handle on my Jenn-Air/Maytag refrigerator (JUC2450ARS)?
The door handle is loose and there doesn't appear to be an obvious way to tighten it.
    Top Expert:
  • Jenn-Air Master
  • 9,472 Answers
  • Joe K. Nov 03, 2012
    Thank you for the diagram. I'm still trying to figure out how exactly to tighten the handle. I removed the inner door cover but it only displayed the "well" bolt holes that secure the inner door cover.
How do I do fix the handle of my Matag refrigerator #M1TXEMMW803. It is loose on the bottom.
Maytag Repair - YouTube
? 2:17
https://www.youtube.com/watch?v=KcPy_PWb_Iw
Aug 27, 2013 - Uploaded by hpaiz69
Maytag Side by Side Loose Door Handle Repair. ... RefrigeratorDiagnostic & Repair - Not cooling ...
LG Refrigerator Repair (Part #AED37133117) - YouTube
? 1:01
https://www.youtube.com/watch?v=BXupc6y_wgw
Jul 9, 2013 - Uploaded by RepairClinic.com
The most common reason for replacing the handle is when it . ...Fridge Freezer Door Handle Replacement ...
How to fix a loose Refrigerator Handle - YouTube
? 0:30
https://www.youtube.com/watch?v=4IO60zkMXpw
Dec 12, 2013 - Uploaded by Charles Joyner
How to fix a loose Refrigerator Handle .... Refrigerator Repair - Door & handle, Amana , Whirlpool, Maytag ...
Jan 05, 2016 | Cars & Trucks
Tighter door handle on freezer door maytag mf12568aeb?
Slide the handle up tightened the screws underneath and line up and slide the handle back on
Jan 03, 2016 | Maytag Refrigerators
Refrigerator side freezing
you could have a bad damper,this is located in the fridge section,all it is is a door that opens and closes to let cold air into fridge,sounds like yours is stuck open.remove the bottom kick panel and look for the tech sheet,it will tell you how to put it into diagnostics,the board will open and close,if it doesn't you know it's bad.go here and look at part number 13
http://www.searspartsdirect.com/partsdirect/part-model/JENN-AIR-Parts/Refrigerator-Parts/Model-JBR2086HES/1266/0161000/M0610191/00008?blt=06&prst=&shdMod=
Jul 12, 2012 | Jenn-Air JBR2086HES Stainless Steel Bottom...
The handle on the bottom freezer drawer is loose and i caqnnot tighten it by using an allen wrench in the 2 bottom holes - - is there a trick to this???
Sometimes the studs that the handle mounts to become loose themselves. If you remove the handle entirely and look at the studs, they will have either a phillips head or they will be hex-headed so you can tighten them. Carefully snug the studs down (do not over-tighten) and re-install the handle. This should solve your problem.
Let me know if you need more help
good luck
Aug 11, 2010 | Jenn-Air JBL2086HES Bottom Freezer...
Loose freezer door handle
There is a "set screw" on the underside of the posts that connect the handle to the mounting posts on the face of the door of my Jenn-Air bottom freezer. Use an Allen wrench to loosen the set crew, which is very small (my Jenn-Air requires a 3/32" Allen wrench), and then tighten the bolt on the mounting post on the face of the freezer door. Position the handle over the post, then tighten the set screws with the Allen wrench. Cynthia
Jul 21, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Handle on bottom freezer drawer is loose.
Take the handle and slide to the left as far as it could go to tighten handle. This worked for me.
Jun 26, 2009 | Maytag MFI2568AE Side by Side French Door...
Loose handle on door
The door handles mount on hex bolts sticking out of the door, the door handles have key hole inserts that match with the bolts. The door handles are then slid in one direction to lock the handles in place. Removal is the reverse. To tighten the door handle screw the bolt out enough that you can still put the handle over the bolt heads and slide the handle to lock the handle in place.
Apr 12, 2009 | GE Profile Stainless Bottom-Freezer...
GE Adora Side by Side Loose Handle
do the covers pop off to tighten screws on the handles
Oct 21, 2008 | GE Adora (DSF25KGTBG) Side by Side...
Freezer drawer handle loose...how do I tighten screws?
With a screwdriver?
Screws in plastic will wear with constant use , take the screw right out and wrap it with aluminium foil, then replace
Jan 24, 2008 | Jenn-Air JCB2059G Bottom Freezer...
Jenn-Air JUC2450ARS Compact Refrigerator Logo
432 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
