I can't exit safe mode in windows xp
Computer stuck in safe mode no room on screen to use run for any information, not able to use system restore to.
Posted on Feb 26, 2013
  • 7,627 Answers
Click on Start button, choose option. Or remove power.
Posted on Nov 03, 2012
  • 2 more comments
  • vincent_s669
    vincent_s669 Nov 03, 2012
    I don
  • vincent_s669
    I don't have laptop, I have clicked on run, then typed mixconfig to change system config. to normal mode but the system sends message that only system admin can do, how do I get system admin status?
  • max carson
    max carson Nov 03, 2012
    You are not the Administrator?Is this your computer? Pull the plug and re boot.
  • max carson
    System Administrator is setup in user accounts by the owner.
pavansb
  • 27 Answers
SOURCE: Stuck in safe mode ?
when you switch on your computer, go to setup, then select normal mode and go ahead..!!!
Posted on Oct 29, 2008
  • 264 Answers
SOURCE: can't exit safe mode
Click Start>Run
Type MSCONFIG
Click Boot.ini
Uncheck SafeBoot
Apply- Ok
Restart the computer.
Please Rate the solution
Posted on Oct 25, 2008
leecom72
  • 4806 Answers
SOURCE: WHAT TO DO IF MY SONY VAIO WON'T START?
Hi there.
Choose "LAST KNOWN GOOD CONFIGURATION" if it still won't boot up try "SAFE MODE" and perform a system restore and take the computer back a week or so.
Good luck and thanks for using FixYa!!
Posted on May 13, 2009
sijudoniston
  • 134 Answers
SOURCE: XP won't boot up.screen shows safe mode
The operating system files got corrupted.You can try repair the windows using operating system cd.
Siju
Posted on Oct 30, 2009
bhagyavichar
  • 414 Answers
SOURCE: My laptop wont exit safe mode even when pressing
this is a case of os corruption somehow..!!..may b a virus/trojan or hardware or software is responsible..
all u need is the os boot cd anyway..
probably now u got two way out:
goto somecyber n download win xp pro sp2, using any bit-torrentclient(like utorrent) from torrent site (eg. mininova.org so on)..make aboot disk n try..
1) copy the file in windows repair mode or from any identical os n put it in place as stated above..
OR 2) reinstall os..
(to takedata backups u gotta connect the hdd to another pc/laptop, forsuch cases a hdd-case is available in the local spare market, it'llmake behave ur hdd to act as an external removable drive)..
thiscan also b a symptom of faulty/defective of RAM..pen clean/removecarbon& or oxide formed on the teeth with an eraser n resitit..[it'll b more prominent, that if itz cause by ram or not,..if duringnormal operation, a Blue Screen appears/Memory Dump]
though, sometimes itz also caused by the m/b..
there are also exceptions, where it is found that any hardware componenton the system is loose or incompatible (see addon cards, the ram(s),the hdd (if itz making any 'ticking' noise like 'kirr kirr' or 'tuc tuc'), all data cables n power cords, may b dusty, cpu overheating,see filter/power/south bridge/crystal clock generator section of m/besp mosfets and capacitors..etc)..
if once u can login, do the following:
hv a licensed and UPDATED antivirus installed (i prefer avg/kaspersky, , without updation a full version antivirus is useless)..
download, install n run microsoft kb890830..http://www.microsoft.com/downloads/details.aspx?FamilyId=AD724AE0-E72D-4F54-9AB3-75B8EB148356&displaylang=en..
download n run Startup Control Panel..http://download.cnet.com/Startup-Control-Panel/3000-2094_4-10039330.html..'remove all the unnecessarystartup items from here..(if u can't find what to remove,post me/us inur comment with all the items listed in each n every tabs herein)..
remove all unnecessary software from add/remove programs..
download, install n run 'Advanced System Care Pro'..http://download.cnet.com/Advanced-SystemCare-Pro/3000-2086_4-10399324.html..
disablethe following: a) 'Automatically Restart' right click on mycomputer->properties->advanced->startup n recovery->(uncheckon the) Automatically Restart; b)'Error Reporting 'right click on mycomputer->properties->advanced->error reporting->disableerror reporting->(uncheck on the) 'but notify me when critical erroroccur'..
Increase the size of Virtual Memory, Initial: 1440; Maximum: 2880
always better to seek professional advice of ur system admin/vendor....
Posted on Nov 12, 2009
Reboot acer aspire 4752g laptop to exit safe mode. network diagnostics cannot be run in safe mode
If you download Hirens (Google it) boot disc or USB (150mb file) you will need to USB key installer from the same site and select USB or cd to start first in bios.the boot disc loads a small version of windows Xp on you memory ram.this is as good as safe mode.when the page fully loads you can gain internet access that way .there are hundreds of tools on this programme to fix all kinds of problems and get your laptop up and running.
Dec 10, 2014 | Acer Computers & Internet
Tip
How to Bypass Windows XP Password in Safe Mode?
As a special diagnostic operating mode of Windows, safe mode which starts Windows with a limited set of files and drivers helps you to diagnose and troubleshoot various computer problems. Whenever your computer crashes or a spyware or virus affects your PC, you can enter safe mode to fix these problems. So when you want to <a href="http://www.anypasswordrecovery.com/bypass-windows-xp-password.html" style="font-weight: bold;">bypass Windows XP password</a>.<br /><br />There are 3 safe mode options, here only shows you detailed instructions on <a href="http://www.anypasswordrecovery.com/bypass-windows-xp-password.html" style="font-weight: bold;">how to bypass windows XP password</a> by safe mode with command prompt, which will starts Windows in safe mode with a command prompt window instead of the usual Windows interface. Before proceeding the following steps, please make sure that you never set a password for the built-in administrator account on your Windows XP machine or you can remember password of a Windows account with administrative privileges.<br /><br />Step 1. Turn on your computer.<br /><br />Step 2. Repeatedly tap F8 key as the computer is booting. It will bring up the "Windows Advanced Options Menu" as shown below.<br /><br /><img src="yaoch.png" /><br /><br />Step 3. Use your arrow keys to select "Safe Mode with Command Prompt" and press Enter.<br /><br />Step 4. Windows will load files until you see a logon screen similar screen with all your account user names displayed. Enter password for your administrator account to get in safe mode.<br /><br />Step 5. You'll see Windows command prompt after entering safe mode.<br /><br />Step 6. Enter "net user" on the command prompt, and press Enter. It will list all the user names of your Windows accounts. Here we assume that there is a user name of "Jack" in the list and you want to bypass the "Jack" account password.<br /><br />Step 7. Enter "net user Jack 123456" on command prompt and press Enter. This command line means that you want to reset the lost "Jack" account password to "123456". When it takes effect, you'll be able to logon the Jack account with the new password of "123456".<br /><br /><img src="yaoch_0.png" /><br /><br />Step 8. Now all the operations compete and you can exit safe mode by restarting computer.<br /><br />Please note this method will not work for you if you cannot enter safe mode with an administrator account. Under this circumstance, what should you do next? Well, don't feel impressed. Windows password recovery solutions aren't limited to this. <a href="http://www.anypasswordrecovery.com/" style="font-weight: bold;">Rekeysoft Windows Password Recovery</a> is another good choice. It only takes you 4 steps to bypass Windows XP password in less than 5 minutes.<br /><br />Step 1. Download and install Windows Password Recovery.<br /><br />Step 2. Burn a bootable Windows password reset CD/DVD/USB flash drive.<br /><br />Step 3. Insert the CD/DVD/USB flash drive in the locked computer and set BIOS of the computer to boot from CD/DVD/USB flash drive.<br /><br />Step 4: <a href="http://www.anypasswordrecovery.com/reset-windows-xp-password.html" style="font-weight: bold;">Reset Windows XP password</a> under Win PE with a few clicks.<br /><br />Of course, if you had created a password reset disk after creating a Windows password, you can easily use this disk to change the lost login password to a new one with ease. It will save you from a lot of troubles when forgot login password to your Windows XP computer.
on Apr 19, 2011 | Computers & Internet
Safe mode exit
Just reboot normally and do not select SafeMode. You need to configure the boot order in the BIOS to make Boot from CD-Drive the first option. save the changes and then exit the BIOS. Insert the installation disk and reboot.
Jan 25, 2014 | IBM Lenovo Thinkpad T43 Left And Right...
I switch on my pc (window xp) this evening, and my pc auto restart with blue screen pop out. its say some error with name 'fatal system error'. already clean disk, de-fragment in the safe mo
turn on computer,press F* repetedly until screen shows up wth options
safe mode
safe mode with networking etc...
in dat screen select option "most recent good configuration"
and enter..next window select windows xp and enter..thats it.
after u log in.clean whole system with good virus scanner for viruses,malware,trojans all
May 19, 2012 | Computers & Internet
Windows XP won't load in normal mode, only in safe.
have you tried another windows DVD/CD some time xp crash easily the better is windows 7 i recommend you
now you are in trouble just repair you win hope you are computer will be fine without any error'
Apr 11, 2012 | Computers & Internet
My monitor says out of range
You have set the resolution or refresh rate of your display adapter to a value which is too high than what is supported by your monitor.
In order to fix this, you have to do the following:
1. Reboot your computer & press F8 to boot into Safe Mode.
2. Once in Safe Mode, open Device Manager.
3. Remove the display adapter device driver form Device Manager.
4. Reboot your computer again. Windows will boot up normally & will detect the display adapter. It will prompt you for the device driver for the display adapter.
5. Use the CD that came with your display adapter to install the device driver. Once done, your problem is fixed.
Sep 01, 2011 | Insignia D300a PC Desktop
How do I turn off safe mode on Mozilla
Want to turn off Safe mode option on your Mozilla Firefox? Then follow this simple steps:
  1. Open Mozilla Firefox
  2. At the top of it (Firefox window), click on the Firefox button (in you have Windows Xp, click on File menu) and then click Exit.
  3. Start Firefox as you normally would.
  4. If Firefox keeps starting in Safe Mode see Firefox is stuck in Safe Mode.
If your Mozilla Browser is stuck on safe mode better to the steps here: Click here
May 16, 2011 | RCA VR702HF VCR
LAPTOP IS ON SAFE MODE AND I DO NOT KNOW HOW TO GET IT OFF SAFE M
when switching on your laptop please tap F8 key continuously and it should take you to the boot options
Sep 10, 2009 | HP Pavilion dv9000z Notebook
Cant acess safe mode in windows xp, just cycles startup screens
Here are some steps to use MSCONFIG to force your computer into SAFE MODE
  1. Click on Start and then Run.
  2. In the text box in the Run window, type msconfig and click OK. This will open the System Configuration Utility program.
    Note: Do not make changes in the System Configuration Utility other than those outlined here to avoid causing serious system issues. This utility controls a number of startup activities other than those involved with Safe Mode.
  3. Click on the BOOT.INI tab located at the top of the System Configuration Utility window.
  4. Check the checkbox next to /SAFEBOOT and click OK.
  5. You will then be prompted to either Restart, which will restart the PC immediately, or Exit Without Restart, which will close the window and allow you to restart the PC manually.
  6. After the restart, the PC will automatically boot into Windows XP Safe Mode.
    Note: Windows XP will continue to boot into Safe Mode until the System Configuration Utility is configured to again boot normally.
  7. When your work in Safe Mode is complete, click on Start and then Run. Type msconfig in the text box and click OK.
    This will again open the System Configuration Utility program.
  8. Choose the Normal Startup radio button and click OK.
  9. You will then be prompted to either Restart, which will restart the PC immediately, or Exit Without Restart, which will close the window and allow you to restart the PC manually.
  10. After the restart, the PC will boot into Windows XP normally and will continue to do so.
    These instructions were written by About.com
    http://pcsupport.about.com/od/tipstricks/ht/smsysconfig.htm
May 24, 2009 | Microsoft Windows XP Media Center Edition...
I install brico pack(themes or xp) after some days i download servicepack 3 from internet and istall that to my pc. install sucessfully, but after restart windows diint get in i just see black screen ony.....
Follow the steps given below to resolve the issue.
1. F8 at system startup.
2. Boot to safe mode with command prompt.
3. Perform a system restore.
For instructions on how to perform a system restore from Safe Mode with Command Prompt use the link given below: http://support.microsoft.com/default.aspx?scid=kb;en-us;304449
If this fails do a system restore from Recovery console.
Jan 22, 2009 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
