Question about Vacuums
Should the roller brush on the kirby always be spinning?? just inherited a kirby 5, and the roller brush is not turning when the vacume is on. ??
  • immers
    immers Nov 03, 2012
    Thank you very very much, very helpful. francie
  • Les Dickinson
    Les Dickinson Nov 03, 2012
    glad to help anytime
  • Vacuums Master
  • 18,411 Answers
Yes it should alway be spinning when you switch on the machine, if it's not spinning i would sujest the belt as come off or broke this video will show and explane what you need to do to replace or put back on .
Posted on Nov 03, 2012
  • 7 Answers
SOURCE: I don't understand how to get the kirby belt on!
it's very easy: take off the nozzle, make sure the green arrows allign, then turn the knob anti clockwise untill the red arrows allign, make sure the belt is on the hook[ look at the back of the nozzle and loock in the hole to see if the belt on the hook. Now and only now you put the nozzle back onto the machine. the you turn the knob clockwise untill the green arrows allign...........
Posted on May 20, 2009
reddevil6
  • 1673 Answers
SOURCE: self propelled wind tunnel vacum will notpropell itself
Must be a Hoover, The flat belt may look ok but I am sure it has stretched to the point where under load it won't drive the wheels or the brush roll. Could also be a bad brush roll.
Posted on Feb 13, 2008
SOURCE: brush roller on windtunnel won't spin
It sounds like you need to replace the actuator arm or the cable to it. Look for Hoover part 43143046 for a start. I've got a similar problem.
Posted on Jun 04, 2009
SOURCE: Brush roller won't turn
On my Dyson, there is a brush reset button on the top right hand side (if you are looking at the front) that you can press to reset the brush. I was vacuuming and too lazy to move a toy and this worked for me once I freed the rope from the brush.
Posted on Mar 16, 2010
VacuumRepair
  • 438 Answers
SOURCE: How do you attach the belt for the roller-brush on
Greetings,
Please see the attached video on how to replace the belt on a Kirby Generation Vacuum Cleaner. This is an easy to follow step by step direction on the proper way to replace the belt, as well as do basic maintenance on your Kirby's roller brush which will prolong the life of your belt greatly if done regularly. I you find this video to be helpful, please be kind and rate it well by clicking the thumbs up icon below.
Feel free to request a repair clarification if you have any quesitons on how to replace the belt on your Kirby.
How to Replace the Belt on a Kirby Generation 3 (G3) Vacuum Cleaner:
Thanks for watching!
Chris J.
Posted on Mar 21, 2010
Should the green light be on while I am using my Kirby vaccum
If you mean the light on the top or side of the Power Nozzle, yes, it should be on for most uses. You can disengage the belt for other uses. The green light illuminates when the belt is turning the brush roll. So, you see, the green light functions to confirm to you that the brush roll is spinning. For carpet, you would want the brush roll spinning. When I vacuum my comforter or sofa, I don't have the belt engaged because I don't want the roller to grab up my fabric. For that use, the green light is not illuminated.
Oct 11, 2014 | Kirby Vacuums
Brush not spinning
1. Make sure the belt is in contact with the shaft. 2. Remove the roller and clean the brushes AND the area that seats into the vacuum. If there is too much hair, string, etc. the brush may not roll. chances are the belt is probably not making contact. If it was you would smell rubber burning if the brush wasn't turning.
Mar 03, 2013 | Kirby Vacuums
Hi, my kirby makes a very loud and rattly noise when im vacuming, and sometimes the roller brush stops working, please help thank you
replace fan,belt and either clean ends of rollerbrush of string, hair, floss, etc or buy a new rollerbrush
Dec 08, 2010 | Kirby G5 Bagged Upright Vacuum
Kirby g6 will not pic up dirt. Belt is on and bag
check for blockage or impeller if vacum makes loud noise the impeller is the part that gives it suction
Oct 15, 2009 | Kirby G6 Bagged Upright Vacuum
Roller brush will not move when vaccum is turned on
maybe the belt is broken. clean the unit and replace the belt.
May 23, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Generation 3
PUll the roller brush out and make sure it turns freely by hand. If not clean all hair and debris off the roller brush, you might also remove the end caps (one at a time) and clean the hair out from the bearings underneath the cap (in the shop I use WD-40 and a non-serated pairing-knife). Replace caps they only go one way. If you can not free up the brush you'll have to replace it.
If the brush spins freely probably just need a new belt they stretch out over time.
Jul 04, 2008 | Kirby Generation 3 Bagged Upright Vacuum
How do you use and what attachments for upholstery cleaning with the Heritage II
Generic problem for all Vacuums
How do you use and
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Kirby has a spin brush that is round on the newer Kirby’s and it works on the suction from the vacuum and it fits on the end of the vacuum hose but it does not fit into corners very well or your can take some Kirby shampoo in the spray water bottle and use a kitchen scrub brush for the corners. Other wise you can use the actually Kirby Shampooer of which is very hard and unfriendly; the spin brush would be my selection. You can check with your local vacuum cleaner dealer in your area and also in the yellow pages. Also you can call the Kirby factory to see if they can direct you. The Kirby factory is listed below:
http://kirby.com Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
Apr 18, 2008 | Vacuums
Are there hand tools you can use with Kirby shampooer?
I love my Kirby and shampooer, but I am wondering if there are any ways to clean stains in small/tight spaces (in corners, between furniture, etc)... my old carpet shampooer had a "hand tool" attachment with spinning brushes, but I don't see anything similar for Kirby... I imagine I could put a tiny bit of solution down and use the zip brush, but I'm wondering if anyone has a better idea...?
I believe that Kirby does make a spinning brush and If I remember it is a round brush that spins and probably will not get into square corners – suggest using a scrub brush with the Kirby Shampoo for corners and steps for areas that you cannot get into – use an old spray bottle to wet down the area that you are cleaning and use the scrub brush and if you do find the Kirby spinning brush that will do the large areas. Feel free to contact the Kirby factory phone number and website listed below:
http://kirby.com Contact Us By Phone
United States and Canada: 1-800-494-8586
Between the hours of 8 a.m. – 5 p.m. (EST)
Monday - Friday
Apr 16, 2008 | Kirby Ultimate G Bagged Upright Vacuum
My kirby has no suction
Even if you have a new belt, do everything this guide tells you to do. The seller may have the power nozzle assembled improperly. If the brushroll is in wrong or the base plate is not on correctly, it may cause these symptoms.
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Hope this helps,
Marci
Nov 10, 2007 | Kirby G6 Bagged Upright Vacuum
G5 does not suck:)
un-plugthe vacum andget a broom stick and slide it throuh the hose! it's clogged!and change the bag!
Jul 29, 2007 | Kirby G5 Bagged Upright Vacuum
Vacuums Logo
167 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
