What is the size of the screw for control panel for me to be able to find the right screw driver
  • joecoolvette
    joecoolvette Nov 03, 2012
    A) Control Panel on what? B) Philips head screw, Torx screw, Machine Screw?
  • 3,799 Answers
The right size screw driver is the one that fits without being sloppy or too big!
Posted on Nov 03, 2012
What size of screw driver takes out the screw on a 2001 gmc jimmy steering panel? I was told it uses an inverted torque screw?? I need to replace the ignition lock
Are you talking about a security bit? On different makes and models, lock cylinder, I've seen the screw that has a raised point in the center, you use a security bit, the auto stores sells them, different sizes. I've had the auto stores let me try different bit sizes, right off the shelf, till I found the right size.
I can't see anything from here, don't know if that is the tool you need?
May 24, 2016 | GMC Cars & Trucks
How do I install GM P/N 15098965?
Carefully pry the front plastic panel from the dash using a medium size flat screw driver and your fingers - this is a fairly large panel with cutouts for the instrument panel and dash controls, and is held to the dash by internal clips which can some effort to release. Start at the bottom and work your way around and be very careful - these panels can be fragile. Once pulled clear of the dash, you will see two screws holding the control - to replace the control, remove these and gently pull the control forward to get at the wiring and temperature control connections.
Dec 10, 2014 | 2003 Chevrolet S-10
Mouse not working model 26-141
Make sure the batteries are inserted correctly and have charge if applicable usually located on the underside of the mouse there might be small plastic sticker with a phillips head screw under it rub your fingernail over the top to see if it has a screw or make sure the usb device is properly inserted for wireless or ps2 is inserted correctly I have found that the best way to adjust your mouse settings is to create a control panel in your bottom toolbar scroll to the bottom of your screen right click you will see an array of options select the toolbar option then select desktop then you will see the desktop in the bottom toolbar select the 2 >>arrow heads then all control panel items then select mouse this is in WINDOWS 7 in XP you will have to select the new toolbar option once you have that a browse option select my computer then control panel then a control panel option will be in the bottom toolbar Click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver Click on >> control panel all control panel items mouse you should see 4 tabs buttons pointers pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have the options update driver rollback driver or uninstall in xp. In windows 7 click start control panel hardware and sound mouse you will see the same tabs and options as with xp
Feb 09, 2013 | Computers & Internet
Stop mouse blinking when start open windows and over screen color resolution and size
make sure the mouse Ps 2 or the usb plug has a good seating if applicable or if its batteries that are good
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver
click on >> control panel all control panel items mouse you should see 4 tabs buttons pointers pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have the options update driver rollback driver or uninstall in xp
in windows 7 click start control panel hardware and sound mouse you will see the same tabs and options as with xp
Click start control panel administration tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
You might need to upgrade your graphics card drivers
you might have to remove your graphics card to make sure the socket is clean
restart your computer the reinstall it this should activate found new hardware wizard
if your computer came with a mother board disk the drivers could be on it
click start control panel display desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps
Jul 20, 2012 | Computers & Internet
Have a power but no display even the video card is good
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers also
If your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools computer management device manager scoll to ports(com&lpt)right click to scan for hardware changes or scroll to monitors + to expand plug and play monitor right click where you have options to update driver,disable.uninstall,scan for hardware changes or select properties where in the general you have the option to troubleshoot also in the driver tab you have the same options as when you first right click on monitor
also
click start control panel,display,desktop you can select a different desktop from the drop down list also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
hope this helps
don
Feb 14, 2011 | Computers & Internet
When I turn the heat on the drivers side only kicks out cold air while the passenger side kicks out hot air...
The blend door is not working right or the in car air temperature sensor is faulty.
Removal & Installation Air Inlet Door Vacuum Motor To Remove:
  1. Remove the instrument panel.
  2. Remove the air inlet door motor mounting screws. CAUTION
    Do not attempt to bend any part of the air inlet duct door lever.
  3. Rotate and remove the air inlet door vacuum control motor.
To Install:
  1. Rotate and install the air inlet door vacuum control motor.
  2. Install and tighten the mounting screws.
  3. Install the instrument panel.
Defroster Door Vacuum Motor To Remove:
  1. Remove the passenger air bag module from the instrument panel.
  2. Disconnect the vacuum line and remove the mounting screws. CAUTION
    Do not attempt to bend any part of the defroster airflow mode door lever.
  3. Rotate and remove the vacuum control motor from the defrost door lever.
To Install:
  1. Rotate and install the vacuum control motor on the defrost door lever.
  3. Connect the vacuum line to the vacuum control motor.
  4. Install the passenger's air bag module.
Floor Console Register Duct Vacuum Motor To Remove:
  1. Remove the floor console.
  2. Remove the right-side instrument panel insulator.
  3. Working from the passenger's footwell, disconnect the vacuum hose.
  4. Remove the screws and the floor console register duct vacuum control motor. CAUTION
    Do not attempt to bend any part of the floor console register duct door lever.
  5. Rotate and remove the vacuum control motor from the floor console register duct door.
To Install:
  1. Rotate and install the vacuum control motor on the floor console register duct door.
  3. Connect the vacuum hose to the floor console register duct vacuum control motor.
  4. Install the insulator under the dash.
  5. Install the floor console.
Panel/Floor Door Vacuum Motor To Remove:
  1. Working through the driver footwell, remove the two screws and the shield. CAUTION
    Do not attempt to bend any part of the airflow mode door lever.
  2. Label and disconnect the two vacuum hoses.
  3. Remove the mounting screw.
  4. Lift, rotate and remove the panel/floor door vacuum control motor from the door lever.
To Install:
  1. Install the panel/floor door vacuum control motor on the door lever.
  2. Install and tighten the mounting screw.
  3. Connect the vacuum hoses in their original positions.
  4. Install the shield on the vacuum motor.
Auxiliary Air Distribution Blend Door Actuator To Remove:
  1. Remove the right rear quarter trim panel access panel. Auxiliary climate control housing removal and installation ford-10-00-4589.gif
  2. Remove the auxiliary air distribution blend door actuator screws.
  3. Disconnect the auxiliary air distribution blend door actuator connector.
To Install:
  1. Connect the auxiliary air distribution blend door actuator connector.
  2. Install the auxiliary air distribution blend door actuator screws.
  3. Install the right rear quarter trim panel access panel.
Auxiliary Temperature Blend Door Actuator To Remove:
  1. Remove the right rear quarter trim panel. Auxiliary climate control housing removal and installation ford-10-00-4589.gif
  2. Disconnect the temperature auxiliary temperature blend door actuator connector.
  3. Remove the temperature auxiliary temperature blend door actuator screws.
  4. Remove the temperature auxiliary temperature blend door actuator.
To Install:
  1. Install the temperature auxiliary temperature blend door actuator.
  2. Install the temperature auxiliary temperature blend door actuator screws.
  3. Connect the temperature auxiliary temperature blend door actuator connector.
  4. Install the right rear quarter trim panel.
--- In-Car Temperature Sensor Removal & Installation To Remove:
  1. Remove the instrument cluster finish panel.
  2. Disconnect the in-vehicle temperature sensor connector.
  3. Disconnect the in-vehicle temperature sensor aspirator tube.
  4. Remove the in-vehicle temperature sensor screws.
  5. Remove the in-vehicle temperature sensor.
To Install:
  1. Install the in-vehicle temperature sensor.
  2. Install the in-vehicle temperature sensor screws.
  3. Connect the in-vehicle temperature sensor aspirator tube.
  4. Connect the in-vehicle temperature sensor connector.
  5. Install the instrument cluster finish panel.
Oct 07, 2010 | 2004 Ford Freestar
I own a 1997 WW Jetaa and I just want to remove
Those are pop outs, you can either slide it in between the door and the panel with a screw driver and carefully pry, or you can go and by a door panel remover at a local auto parts store and do it with the tool.
May 30, 2010 | 1997 Volkswagen Jetta
Removal of drivers door panal. f 150 supercrew lariet 2001
Don't know what to do with the adhesive except to carefully remove with a long screwdriver, putty knife, etc. However, before you do that you should remove the screws in the door handle crevice. The two lower screws seem to come loose on their own so I replaced with one size larger stainless. The upper screws by the door handle are critical to remove the panel AND to secure it...
Feb 01, 2009 | 2001 Ford F150 Styleside SuperCrew
Error in A3 print
I had the same problem. Didn't find the answer. I removed the HP 1280 driver and installed HP 1220 Driver. It worked. It prints all the sizes perfectly. What is in name if we get the prints on A3 size. whether it is HP 1280 or HP 1220 :)
Ajay
Aug 30, 2008 | HP DeskJet 1280 InkJet Printer
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
