Question about Car Audio & Video
Amp board is missing switches - Car Audio & Video
    Master:
  • 444 Answers
Just get a different amp, It will cost you more to repair it then to get a decent used amp.
Posted on Nov 03, 2012
My(38ycc030340)carrier heat Pump ac unit blows 5 amp fuse on board in handler in attic when switch stat to heat.
Miss wired or shorted low voltage wiring. Have you changed stat? Animal chewed wires at foundation wall or in attic?
Oct 10, 2016 | Carrier Heating & Cooling
How intelligent is Pioneer's vsx amp/rec "power off" protecting mode? Hi, I would like to have an answer to the foregoing title in order to find out if it's worth repairing my Pioneer...
When you remove boards, you may be breaking a circuit somewhere that is causing the shutdown. Pioneer uses rear panel jacks for ground points a lot, and if even one of these screws is out it can cause it to shut down.
Sep 26, 2013 | Audio Players & Recorders
I have a model T-10 endurance treadmill when it starts to run about 10 seconds it will stop and code E-1
Unplug unit and remove motor shroud ,check upper & lower wire for solid connections , check condition of magnet on front roller to see if missing or still in place if not replace the roller. Next to the front roller, their is a speed sensor ( reed switch ) unplug the leads going to the the lower board use a multi meter to check continuity of the switch by inserting the leads into the connector and manually rotating the front roller back and forth opening and closing the reed switch if not operating properly then replace the switch.
If the above procedure did not resolve problem and still ERROR 1 then check the Motor Control Board LEDs 6 & 7 If LED 6 isn't on, change a new upper console if on then motor control board needs to be replaced if LED 7 is not on ( that a mouth full )
If LED 7 on - current overload circuit meaning too much friction between belt and deck you will need to apply good quality silicon lubricant that may be purchase @ gympart.com part# TM001
If then if the overload problem, still exists and lubrication did not the help then the belt and deck are worn and need to be replaced. Very seldom do we need to replace the Drive Motor problem is around 8% failure rate. You will get plenty warning if the motor goes out.
May 12, 2010 | Endurance T10HRC Light Treadmill
Picture and sound are splotchy-meaning the picture and sound are missing on different parts of the screen and these missing parts are moving around the screen.Also the sound comes and goes
Hi my name is Roety,
I can help you with your issue ,
If this is an LCD sounds like a bad main board.
Plasma try adjusting the two controls on the Ysus board
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Oct 31, 2009 | Samsung Televison & Video
Document roller up & down
On the Canon copy machines when this happens, normally it is a bad wiring harness....sounds like your switch is good, but the signal for 'roller down' is not reaching the main board, thus it repeatedly cycles up and down. Try continuity test on the wiring harness from switch connector end to main board connector end...it's a pain to do this, however, when you find the open wire connection, it's worth it.
Oct 28, 2009 | Canon Office Equipment & Supplies
I have just replaced my HVAC Control board &
Once you have installed the jumper, you will need to kill power to the furnace for about a minute to reset the board. Make sure the the jumper is making good contact. Sometimes they appear to be plugged in but still are not making contact.
Oct 04, 2009 | Heating & Cooling
Brake lights not working even though the brake peddle is pushed down The switch still goes in and out. Fuse box has some fuses missing. The fuse box does not have a desription on every plug of what it is...
Here are the numbers on your fuseblock and fuses coresponding to the number that is on your fuse block.
1-20 amp (yellow)
Hazard flasher
2-10 amp (red)
back up lights, A/C clutch cycling Switch
3-30 amp (green)
Power windows
4-30 amp (yellow)
A/C or heater blower motor
5-20 amp (yellow)
Panel Lights, Side marker lights, Park, Taillights, Clock & radio display Intensity, License & panel lights.
#6-10 amp (red)
Stoplight, buzzers, Anti-lock brake module
#7-15 amp (lt. Blue)
Tachometer, horn & Relay
#8-8 amp (yellow)
Power Door locks
#9-10 amp (red)
Radio
#10-10 amp (red)
Rear Wheel Anti-lock module, Turn Signals
#11-20 amp (Yellow)
Windshield wiper & washers
#12-15 amp ( LT. Blue)
Cigarette Lighter
#13-5 amp (tan)
Speed Control, warning buzzers, gauges, indicator lights
#14-5 amp (tan)
Time/delay relay & under-hood light, dome light, power mirrors, readio & clock Memory, Interior lights, reading lights
#15-blank
Not used
#16-4 amp (pink)
Radio Lights & overdrive switch light 1989-91, Cluster lights, Cigarette Lighter light & as tray light, Cluster lights, A/C & heater controls.
#17-relay
Hazard Flasher warning
#18-relay
Relay
#19-Circuit breaker
#20-relay
Turn signal Flasher
#21-buzzer
Warning
#22-Relay
Horn
Aug 04, 2009 | 1991 Dodge Dakota
Fuse missing
I would start with a 1.5 AMP fuse (175 watts / 12 VDC = 1.6 amp)
Make sure the fuse is rated for at least 120 VAC. Hope this helps!..Gary
Mar 10, 2009 | Dell 175 Watt Power Inverter Car Adapter...
Battery recharged fully. still won't working at all.. hmmm canon powershot SD630
Check the small back switch under the battery door. If it is missing, your camera will not power on. If it is missing, dig out the small spring inside the switch housing. If the switch is missing, the spring is making an unwanted connection. If the switch is there, then you have a bad circuit board. It will need a replacement board.
Nov 11, 2008 | Cameras
Car Audio & Video Logo
16 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
