Question about Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1
Oil leaking into air filter - Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1
  • 4 Answers
You are getting what is called blow by. Which happens when there is to much oil in crankcase or an oil ring is bad in engine
Posted on Nov 02, 2012
Testimonial: "I generally have to keep the oil level low on this engine to prevent the leakage . The engine is on a Simplicity mower, and I have been told not to mow with the nose of the mower pointing down a hill. Thanks for your response must be an o ring. Hard to fix?"
  • Robert Richey Nov 03, 2012
    not hard but it is what would be considered an overhaul. Would need to tear down engine and re-ring pistons
Oil leaking into carb
Oil in the air filter is usually caused by blowby which is oil blowing past the cylinder rings, or a PCV valve that is not working correctly. The crankcase has too much pressure and oil is escaping out to the air filter where the crankcase is supposed to get fresh air from.
If the PCV valve and hose are ok, you may need another engine at some point. The rings and-or cylinders may have excessive wear.
May 14, 2013 | Isuzu Trooper Cars & Trucks
1989 Lincoln Town car leaks oil into the air intake.
Check the pcv valve it may be sticking and sucking oil into air filter housing.
Oct 02, 2012 | 1989 Lincoln Town Car
Oil leaking from air filter
Hi Anonymous, oil leaking from your air cleaner is caused by oil carryover from the engine. For what ever reason the breather system is not seperating enough oil mist and air from the piston downstroke. There are cheap and quick easy fixes and there are more exspensive ones. Start by trying the following:
1. Run your oil level half way between the add and full mark when hot.
2. Run oil breather lines from head into a TEE fitting below carb/induction module then a single line into a mini filter under frame.
3. Purchase Arlen Ness Super Sucker.
4. Replace umbrella valves and realign oil pump
5. Upgrade oil pump and cam plate
Good luck and have nice day.
Jul 27, 2012 | 2003 Harley Davidson FXSTD Softail Deuce
Oil leak
How long is a piece of string ? without a good look under the bonnet i couldnt say but make sure the engine breather is clean and not clogged as this would cause a build up of back pressure which will cause the oil top leak from everywhere possible
Feb 08, 2012 | 1988 Chrysler LeBaron
Why is my car leaking oil
its common for some automakers to leak oil, run badly, break often, & otherwise be a plain hassle............I would suggest reading consumer reports before buying new or used cars.
Jan 23, 2012 | 1996 Volkswagen Jetta
My audi has a oil leak of some sort which is leaking into the air filter unit and has soaked my air filter, the oil leak is coming form aline that runs along the top and side if the air intake unit. why...
follow the line backwards down to the block and clean the breather(if fitted) this is not an oil leak, the pipe is there to **** up the engine pressure when decelerating.........the air filter should be changed every 20 thousand miles/2 years.....
Sep 14, 2010 | 2002 Audi A4
Hello, I have a 1993 yamaha xv535, and i have 2 problems: oil on the air filter and the second problem is speed, she only do 120 km/h.
motor sounds tired as oil in air filter can mean worn rings and leaking compression into crancases and then forcing oil into air filter.comp or leak test will give answer
Aug 11, 2010 | 1988 Yamaha XV 535 Virago DX
1998 Ford Windstar 3.8L ScanTool says that Bank 1 is lean
if your getting oil in the air filter area, you have a leaking intake gasket or a leaking head gasket, run a compression test on it,
if the compression is where it should be on all cylinders then its a leaking intake gasket!!!
Mar 04, 2010 | 1998 Ford Windstar
Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1 Logo
699 people viewed this question
Top Briggs & Stratton Tools & Hardware - Others Experts
Randy Schumann
Randy Schumann
Bill Boyd
Daryl Gleaton
Are you a Briggs & Stratton Tool and Hardware - Other Expert? Answer questions, earn points and help others
