Question about Leica IIIg 35mm SLR Camera
Leica III camera focusing problem
HI:I just recently bought an old leica III camera. Everything works OK but when focusing images I can see the double image and am able to put them together when focusing, but only in the horizontal direction, in the vertical direction both images are slighty separated. Is there any screw for aligning both images in the vertical direction? Thanks. AL
  • alvaro astorza May 19, 2007
    I really could reduce the misalignment, but still there is a bit of it. I guess there must be some vertical alignment screw below the upper cover of the camera. If so, how can I remove it, specially the speed dial? Thanks. AL
If you still have some vertical misalignment, then your original misalignment must have been pretty bad. For really bad misalignments, you have to get into the rangefinder unit itself and take off the left end coverpiece of the rangefinder unit in order to get at four screws that control the position of the 45 degree reflecting prism. The position of the reflecting surface of this prism controls the direction of the secondary image relative to the primary image, (the main image you see straight ahead in the viewfinder, the one not influenced by rangefinder focusing). Adjustment of any one of the four screws will move or tilt the secondary image in three possible ways, up or down, left or right, and back or forward. So, you need to know what your doing, and be able to pre-visualize what direction the image will move when a particular screw is either tightened, or loosened. It's not for the faint-at-heart, or non-mechanically inclined. Of course, you can only get at the rangefinder unit by removing the top chrome cover, which is a whole story of it's own.
Posted on May 21, 2007
Yes, if the vertical misalignment is small, say, about less than a tenth of the image size that is misaligned vertically, then try rotating the 'lens' that covers the front left (as viewed from front of camera body, in upright position) rangefinder window.That is, the front RF window near the slow speed setting dial. In order to do so, you will need to unscrew the decorative chrome bezel first. Unscrew in counterclockwise direction. Do not use pliers, etc. to remove bezel, or you will possibly distort and/or mar the chrome finish. Instead wrap bezel with two, or three layers of making tape, making certain masking tape is not contacting the body of the camera, but only the bezel. Usually, bezel can now be unscrewed by hand only; if not, use pliers gently with the masking tape acting to protect the bezel's finish. Once the bezel is off, the lens (it's actually a glass wedge prism) can be rotated using the prongs of a tweezer inserted in the two notches of the brass ring encompassing the 'lens', or glass wedge. First, rotate in both directions, cw and ccw, in small angles to determine which direction and how much wedge rotation is required to bring the two rangefinder images into coincidence vertically. Reassemle in the reverse order.
Posted on May 19, 2007
Auto Focus won't work
Another cause of auto focus failure is the circuit connecting the moving parts inside the lens. These "Flexi circuits" move with the lens components and wear out after a while. They are cheap enough to find on ebay and easy to replace.
Dec 06, 2013 | Canon EOS 450D Digital Camera
Recently I bought Leica D-Lux 5 Digital Camera on Creaiglist. It does not have stickers on the bottom of the camera and I don't know the serial number too. How can I get necessary stickers to stic
Each camera made has it's own serial number so the manufacture can track the item for warranty service, it is impossible to obtain stickers for that reason.
Jul 23, 2012 | Leica D-Lux 5 Digital Camera
Hello, I have recently bought a Leica Digilux 1 but I can't use it since it always marks "Memory Card Error". I have tried with three different memory cards and that sign keeps on appearing....
First make sure that any pics on the cards are safely downloaded to your computer. To get the cards to work in the Leica, you must format them in the camera. This will erase them and set them for the operating system of the camera.
Aug 17, 2011 | Leica Digilux 1 Digital Camera
My husband has a 35 mm Leica drp ernst leitz wetzlar with brown case and screw. The body, serial number 336781, is black and a silver colour (chrome I presume) with a screw in lense. The lense, serial...
Without more information or photos it's pretty much impossible to even guess. But, it could be anything between a Leica and a Leica III, produced anywhere between 1925 and 1954. Only features and model-specific numbers engraved on the camera would tell the full story - serial numbers don't give much information to anybody but the factory.
Jun 13, 2011 | Photography
Camera model from a SN?
This might help
http://www.cameraquest.com/ltmnum.htm
From the list, you can see it should be a 1935 Leica III (Out of a batch of 75)
Feb 01, 2010 | Photography
What is the solution
You are dealing with "depth of field", or simply put (?), the range from near to far of an image that appears in focus. To increase the depth of focus, the camera must be set to a smaller aperture (higher numbered). Using a wider angle lens helps also. Focusing on the mid-point (near to far range) will also increase the apparent focus range. This is one of the most complicated photographic issues, and much has been written about it. Google "depth of field" for about 4 million explanations.
May 26, 2009 | Nikon D60 Digital Camera
Button stuck, casuing unrepsonsiveness in all other buttons
Most buttons on a camera are a simple raised rubber pad over a printed circuit board. The button gets pressed, a concuctive material on the bottom of the rubber pad puts a short across a printed pad. If the camera senses a short across the down button, it will ignore all other buttons. You need to take the back off the camera and the rubber button pad will probably be right in the back, clean the contact with an alcohol Qtip and you should be OK.
Nov 23, 2008 | Leica D-lux 3 Digital Camera
Absolutely screwed up, recently purchased camera
try to shoot without a card. or better use a known good card. [:0)
Jan 10, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Problem with Leica microscope
if you check the operation for spliting to a photo tube. PG 49 you can see the procedure for using a camera (there is a control pin on the side of the scope (shown on pg 49) which you have to operate to switch to the camera output... you should then be able to take your photos :) http://www.vashaw.com/assets/84/84original.pdf
Sep 11, 2007 | Leica ZOOM2000 Binocular Microscope
Leica IIIg 35mm SLR Camera Logo
282 people viewed this question
Top Leica Photography Experts
Tony
Wayne Tolonen
TC CAMERA REPAIR.Com...
Are you a Leica Photography Expert? Answer questions, earn points and help others
