Question about Vacuums
The mop makes steam, but when it builds up, it makes the mop head explode off.
There is white crusty looking material inside the mop head and on the end where the steam comes from the housing of the steam maker, but it feels like fabric. Is there supposed to be fabric there, or is this all mineral build-up that I should try to dissolve or break off
  • Cheryl Nov 12, 2012
    I actually soaked both parts - the end of the main unit and the top of the mop head - in vinegar overnight and poked an opened paperclip into both areas until they seemed to be clear. The build up of steam still pushed the mop head off. I went to Lowe's and looked at a display model and pulled the head off of the body, and I noticed that there is a tab on the main body of the steaming unit that the mop head clicks on to. That tab is no longer on my mop and I wonder if it broke off somehow when the steam built up. I actually tried to duck tape the mop head to the main body, but now the steam won't build up at all. I don't know if there is a safety mechanism or not that stops the water from heating when things aren't right, but I think I have to give up on it. I loved my steam mop and will probably get another one and always use distilled water in it.
    Top Expert:
  • Vacuums Master
  • 14,553 Answers
If it pops the head off or loose time to get it looked at or replaced, do not use it this way.
Posted on Nov 03, 2012
5 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: the mop itself makes steam
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Posted on Oct 29, 2010
SOURCE: My steam mop S3501 seems to be clogged because of
I'm having the same problem. Do you think soaking the head in CLR and then maybe cleaning with pipe cleaners would work?
Posted on Feb 23, 2011
heatman101
  • 43501 Answers
SOURCE: Shark Steam Mop: Won't steam
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
heatman101
Posted on Mar 05, 2011
heatman101
  • 43501 Answers
SOURCE: steam stopped coming out thru
heatman101
Posted on Aug 13, 2011
Head pops off when steam builds up on my Shark mop
Has head been replaced recently?
1. Make certain head is fully latched into place with attached rod / rods.
2. Do you have a picture of connection of head assembly?
3. Not to worry, this sounds as easy fix versus replacement.
Let us know if above resolves or requires further assistance.
Best of luck to ya!
Apr 09, 2014 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Tip
Shark steam mop not producing steam
It is a design flaw having a check valve orifice built into the steam generator.<br />The plastic sleeve gets hot and get hard and shrinks enough to cause blockage at the inlet to steam generator.<br />Also a lot of sediment builds up inside steam generator from impurities in the water which eventually causes a problem and block at the mop head.<br />solution would be to move the check valve from the steam generator to the pump discharge line where it is cooler. and use only distilled water. they should also use a stainless heater element instead of pot metal as it corrodes.<br />
on Apr 24, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My grey & purple steam mop is getting very little steam at the head. is there a way to clean it without damaging the product? or is there another solution for low steam?
Mixing white vinegar with water about a cup of vinegar and a cup of water ratio and let it steam through the mop. This is also good for steam irons and other appliances such as coffee/tea makers. The acetic acid in the vinegar will dissolve the calcium build up that blocks the steam ports and will not hurt plastic or floors. If you object to the vinegar smell, then mix a little lemon juice with the last cup of water and this rids you of the vinegar smell. I use the white vinegar to mop the wooden floors in the house.
Apr 17, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Hi, My Shark Pocket Mop steamer isn't getting steam to the head, and when I removed the head I found that there is calcium build up on the opening of the body. What is the best waytto remove it? gnc
heatman101
Jan 17, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I have one of the purple one and it is not pumping up very much anymore and making much steam. It's almost like a seal is blown. Can it be fixed or is it trash?
**** builds up inside and cuts the steam, no way to clean it...
heatman101
Sep 22, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark Steam Mop - Gray/ Purple Vacuum: I left water in the steam mop and now the steam is...
heatman101
k
May 17, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Steam Tek mop doesnt steam anymore
We had a similar experience. I opened the head to look if the steam line was clogged. There was no sign of dirt or calcium build up, so I opened up the body. Found that one of the heater wires had come loose. The connector, which is crimped to the wire, was charred. Could be a potential fire hazard!
I notice that a similar product marketed under the Thane brand has been recalled for wiring issues.
We will try to return this mop for a refund.
Jul 29, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Vacuums Logo
90 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
