Question about RoadPro RPSWR-3C SWR/Power Power Meter with Separate Meters - Clamshel
Instructions for roappro swr power meter 3c - RoadPro RPSWR-3C SWR/Power Power Meter with Separate Meters - Clamshel
2 Suggested Answers
drummer158
  • 104 Answers
SOURCE: AVAIR 601 instruction swr meter
the two you have pictured are close but no cigar.
Posted on Sep 30, 2012
May I obtain a copy of the operations manual of an SWR metern for a CB radio?
google the modle # and look for it example 21-345 swrmeter manual try rewording it .
Sep 20, 2014 | Radio Shack Archer Fs/swr Meter Cb Radio...
I need an instruction manual for a astaic PDC2 meter
contact Astatic at this address:
Technical Support
800-542-6263
techsupport@roadprobrands.com
8am-4:30pm EST, Monday-Friday
Aug 27, 2013 | Astatic PDC2 SWR/ RF Field Strength Meter
Rpswr 3 c
most meters have 10w capable diodes.. also have seen a few were the switches will not make a good connection. can you give more details on power you was using or anything else?
Apr 28, 2013 | RoadPro RPSWR-3C Swr Meter - 10w-100w -...
Roadpro rpswr
What was the radio that you keyed?
Full use instructions for ASTATIC PDC2 SWR & Power test meter
Contact Astatic at this address or email:
Technical Support
800-542-6263
Dec 14, 2012 | Astatic Pdc2 Swr/rf/field Test Meter
Sep 21, 2012 | RoadPro SWR/Power Meter with Combined...
No instructions were included in package.
swr meter operation as follows go to channel 1 flip the switch on the swr to cal key the mic adjust the needle on the swr meter to the dash mark at the far right of the meter use the dial on the meter to adjust then unkey your mic and flip your switch to swr re key the mic you should not be higher than 1.5 on any channel repeat the proccess on 20 and chan 40 if the swr is higher on 40 than 1 lower the antenna or trim it but only 1/4 inch at a time.
Mar 24, 2011 | Astatic (PDC7) CB Radio
I don't understand how to adjust the SWR or how the built in meter works for my DX949.
Here is a basic instruction on how to adjust the SWR. When you adjust the SWR, you are not changing anything on the radio. You are actually tuning the antenna for best SWR. The lower the better. SWR stands for "Standing Wave Ratio" Or in layman's terms, SWR is energy that is reflected back into the radio. The higher your SWR reading, the more RF energy that is not leaving the antenna, and getting reflected back into the radio. This can cause damage to the transmit section of the radio. The length of the antenna is what will change this. The length of the antenna must match the length of the radio wave. The following instruction will explain how to take an SWR reading, and how to use that reading to ascertain weather the antenna is too long or too short.
Here is a quick explanation of the meter. There are 3 settings for the meter. SWR, MOD, and PWR. When you are not keying the radio the meter will show you your receive signal. How strong some ones signal is. When you have the switch on MOD and key, when you talk it shows you modulation. How much audio you are putting through the radio. When its on power, and you key the radio, it shows you your dead key wattage.
Tuning your antenna:
It is important to tune your CB radio antenna to the proper length. The length must exactly match the wavelength of the frequency you transmit on. Or be really really close.
All Cb antenna's have a way to adjust the length of the antenna. If it's a mag mount, the metal whip can be slid in and out of a metal collar. Usually a set screw. If its a fiberglass whip, the way to tune it is on top. It either has a small metal rod with a set screw to adjust the length, or it threads in and out to adjust length.
Either type you have it will need to be adjusted for proper length. Here is how to tune the antenna to lowest SWR.
Some radios have a built in SWR meter. Some do not. If yours doesn't have an SWR meter, then you have to use an external SWR meter. Radio shack carries one, and you can find them cheap on ebay.
If you have a built in SWR meter or external, the procedure is the same:
1. Turn the radio to CH 20.(This is the center of the band.)
2. Switch the meter switch to SWR
3. Key the radio. (Important. Do not talk while keying the radio.)
Where the meter falls after that point is you SWR reading. If its above 3, that is real bad. 2 is not gonna kill your radio but its not the greatest. 1.5 and under is a good place to be, but the lower the better.
If your SWR is high, Here is how to find out if your antenna is too long or too short.
1. Turn to CH 1
2. Repeat SWR procedure. You must calibrate every time you do it.
3. Remember the SWR reading.
4. Turn to CH 40.
5. Again repeat SWR procedure.
6. Compare the reading between CH 1 and CH 40.
Now if the SWR is higher on channel 1 then channel 40 your antenna is too short. You must make it longer.
If the SWR is longer on channel 40 then on channel 1, then the antenna is too long, you need to make it shorter.
Make height adjustments about an eight inch at a time, and take reading each time.
once the SWR is significantly lower and the reading on channel 1 and 40 are about the same, you a about matched. At this point turn the radio to the center of the band, channel 20 and take an SWR reading.
You should now have a low SWR reading, 1.5 or under. If you are 1.5 or under, you are good to go.
If you cannot get the SWR to an appropriate level, there may be an antenna problem.
Nov 16, 2010 | Galaxy Radios DX-949 40-Channels Base CB...
Need instructions on how to swr my cobra 29 ltd bluetooth
You insert an SWR meter in the antenna line, usually one end goes into the Antenna OUT socket, and the Antenna plugs into the SWR meter, you then tune you antenna coupler, inductor, & final PA, in the final stage, until you achieve a 1:1 SWR reading, this is however quite hard to achieve, so simply tune for the closest 1:1 SWR that you can achieve.
Feb 22, 2010 | Cobra 29 LTD CB Radio
Instructions for a swr meter/cb radio
An SWR meter is used to see how well your antenna is matched to your transmitter output, just like using the correct speakers with an amplifier.
There are usually two readings. FORWARD and REFLECT
or FWD and REFL
Firstly, make sure the antenna selector is in the correct position and set for the antenna you are using.
Next, switch your meter to FWD (FORWARD). Switch your transmitter to low power and press the microphone key.
Next, adjust the CAL knob for the maximum power reading, but not so far that the meter exceeds maximum!
Keep the microphone key pressed and switch to REFL (REFLECT). If your antenna is matched, the meter should now give a low reading. If the reading is very high, you must match your antenna by making adjustments or by using a matching unit.
A poor match will mean a poor signal. A very poor match can damage your transmitter and cause interference.
When you have a good FORWARD reading and a low REFLECT reading, your system will be reasonably matched and you can then use higher power. Remember that you will need to reduce the CAL knob to a lower setting when running high power.
Mar 05, 2008 | Computers & Internet
RoadPro RPSWR-3C SWR/Power Power Meter with Separate Meters - Clamshel Logo
181 people viewed this question
Top RoadPro Radio Communications Experts
ka4iup
ka4iup
dkmun
Level 1 Expert
Are you a RoadPro Radio Communication Expert? Answer questions, earn points and help others
