Humitifier leaks water out front when in use from vents
  • 70 Answers
Is this a stand alone humidifier if so is the plug in the drain where you can hook up alternate garden hose drain or is the tray seated properly
Posted on Jan 04, 2009
Water coming out of the back of the dryer
When a dryer usually produces visable water from any part of it's self, the suggestion would be a completely restricted vent line. Such restrictions could be from nests from animals, excess lint, a dip in the vent hose causing lint and water to collect. Since the dryer is leaking water, it is heating and therefore creting steam in an effort to dry the cloths, with a clogged vent the steam has no where to escape to and thus condenses within the dryer and leaks out. The vent needs to be checked by a wualified vent servicing company from the back of the dryer to the point of exit of the home. Pleazer Appliance...
Jan 13, 2015 | Maytag Neptune MAH5500B Front Load Washer
Water leak in left front windscreen of 2001 model statesman
it is probably coming in through the firewall some where after being splashed up by the wheels check behind and above the left front wheel for holes
Apr 08, 2013 | Cars & Trucks
Leaks water on rinse cycle thru upper vent
Are you referring to the vent on the back of the machine? If your leaking water, you need to replace or install some new mushroom valves. These mushroom valves, go in both bellows on the top of the machine. One bellow goes from the dispenser box, to the tub. This is where the water goes into the tub, to fill. The other bellow, is attached to the top of the tub, to vent. These both have or are suppose to have mushroom valves in them. If they do not, you're machine will leak water out the back of the vent.
Mar 28, 2010 | LG WM2233H Front Load Stacked Washer /...
LG Dishwasher LDS5811bb. Water is leaking out
The dishwasher may not be levle side to side and front to back.
Se the installation instructions or go www.lgusa.com
they may have the instructions on line.
This will cause leakage at the door.
If the leak is @ the bottom left it may be from the drying vent assembly.
The vent would need to be replaced with an updated vent assy.
Jan 16, 2010 | LG Dishwashers
My dryer is leaking water from the bottom of dryer
Check the vent coming out of the back of the dryer. Somewhere in the vent there is a blockage. If you clear the blockage you may solve the problem.
Jan 07, 2010 | Abbaka White Knight 44AW Electric Dryer
Water leaks into the vehicle on the front,
It could be a plain old fashioned leak around the windscreen - difficult to find but try sitting in the car while somebody plays a water hose over the windscreen.
It could also be a blocked drain in the ventilation system - fresh air is normally drawn in to a car via vents at the bottom of the windscreen. These vents normally lead to a "box" like structure where any water that enters the vents drops to the bottom and then drains away via a short hose that runs to somewhere underneath the car.
If the drain outlet or hose gets blocked (by leaves for example), it can cause the box to fill with water to the point where it can leak out in to the passenger area.
Hope this helps you find the problem.
Nov 16, 2009 | 1999 Ford Taurus
Leaking water from ptc ac unit in front .vents all open
make sure unit is has slight fall toward outside.
Jun 15, 2009 | APC Heating & Cooling
Water leaks out front
I had exactly the same problem with my Kenmore Ultrawash. I thought the leaking might be coming from the seals around the door, but found that it was leaking from the top as described. I removed the air vent cover on the inside of the door and found that it and the vent area had a great deal of what appeared to be dissolved paper. At first I thought perhaps this was somehow remenents of some kind of air filter, but after reading the post here, came to conclude this was foreign matter. I believe what happended is we at some time washed jars or something with lables on it and this stuff accummulated inside the air vent area. I think in a normal case, when the washer is running, water is mostly stopped from going into the air vent area by the hatched cover, but inevitably some water would get thru. This would be ok normally, because the water would just hit the vent area and probably just fall back into the washer. With all the debris stuck in the vent area and on the cover, I suspect the water was not able to exit the vent area or was hitting the debris and causing the water to jet out the opening to the front - hence the water coming out the vent and pouring down the front. Once I cleaned out the vent area and the cover from the debris, I replaced the cover and ran the washer with no water leaking anymore.
I'm so glad you posted your finding - it gave something to look into, and turned out to be the same source of the problem. You saved me a service call.
May 22, 2009 | Kenmore 24 in. 15252 / 15254 / 15259...
Hm495tg
possibly calcium or other deposits from the type of water you are using in the unit..........
Feb 03, 2008 | Holmes Products Holmes 3 Gallon Cool Mist...
Door leak
Br, couple of things you can look for here. Check the vent, you can just pop this out. Sometimes there is a buildup of gunk which will hold water during wash and leak down between the door. There is a seal there, part number 974782. Another thing is to check the upper spray arm for cracks or splitting. This can send a direct flow of water into the vent. There is also a seal at the bottom of the upper spray arm, part number 3376846. I was fooled by a leak like this once, it turned out to be a clogged vent...Catriver..post back.
Sep 30, 2006 | KitchenAid 24 in. KUDS25 Built-in...
Heating & Cooling Logo
70 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
