Question about Dell Vostro 420 Desktop Computer
I cannot get the Dell Vostro 420 to detect my powered usb hub
I have tried several powered hubs. The unit will not recognize any of them.
  • David Beckles Dec 17, 2012
    Thanks for the suggestions, but none of them work. The problem is this: All the USB ports on the machine work fine, with any other USB device that I plug in to them - hard frives, memory sticks, mice, keyboards, barcode readers, etc. The only device that is not recognised is a USB hub - any USB hub, powered or unpowered, of any of the numerous makes that I have tried. So I am still open to suggestions. Again, thanks a lot to everyone.
  • David Beckles Oct 12, 2013
    Thanks, but your suggestion is not really relevant. Pen drives work fine; the problem is that USB hubs, powered or unpowered, do not work when plugged into the machine.
    Sergeant:
  • 252 Answers
Connect the pen drive to the USB . Is it working ?
Posted on Oct 12, 2013
3 Suggested Answers
mikegbali
  • 324 Answers
SOURCE: Dell Vostro 420 will not boot
If it is booting up to the second window, you might have to re-install your windows
Posted on Sep 16, 2009
kamsford_99m
  • 5 Answers
SOURCE: All 6 usb hubs on dell dimension E51 desktop stopped working
this problem is computer hardware matter.clean first the motherboard using paint brush.. clean the RAM using eraser. remove all wiring on the board and return it again. after that turn on the pc... if stil have problem.buy a P/S 2 keyboard so that you can go to the bios setup
Posted on Nov 26, 2009
File transfer cable doe not recognize computer when connected to usb hub
Some USB hubs are "powered", some are not. If you have several different things plugged into the hub, you most likely need a powered hub, one that plugs into the wall for power. USB devices need power supplied over the USB cable, and one computer socket can't always supply enough power for several devices.
Oct 14, 2015 | Audio Players & Recorders
My computer won't recognize the external thru my usb hub
Hi friend, As you have mentioned that the hard drive is not getting detected through the USB hub, I would like you to please check that if any other flash drive is working from that hub or try to connect the USB hard drive to other USB ports on the hub
Dec 07, 2010 | Hitachi Computers & Internet
I have a model m01517 5 port usb hub. It has 2 usb cables to the computer, do I use the blue or black connector? I can only get one port to recognize a device plugged in the other four seem to be dead,...
Not sure I understand this hub either. Looks like only one port is a USB 2.0 port, but here is a snippet from the manual......
This iConcepts USB Hub provides the electronic interface between USB devices and the host, It allows up to five USB devices or Hubs to connect an upstream USB Hub or Host port.
Features
• One USB 2.0 port
• 4 Port USB 1.1 and support high speed (480 mbps) and 4 port full speed (12 mbps) operations.
• The USB 2.0 port can operate both USB 2.0 & 1.1 Devices
• USB 2.0 port supports self powered mode and bus - powered mode, indicated by a powered LED .
• Over current detection and protection
Manual is provided here: http://www.sakar.com/p-1124.aspx?categoryid=182
Sep 09, 2010 | Sakar (M01517) 5-Port USB Hub
I have the dell vostro 420 not booting
check the manual for the led indication.. may be there is an issue with some hardwaree which is not properly installed, if the pc is under warrenty call for help if you are not good at hardware i suggest you to approach the local hardware engineer befor you try to fix it yourself.
May 27, 2010 | Dell Vostro 420 Desktop Computer
Sep 16, 2009 | Dell Vostro 420 Desktop Computer
USB Hubs won't install
Please install the usb hub power surge patch from www.dell.com/support
Aug 24, 2009 | Microsoft WINDOWS XP PROFESSIONAL SP3...
ESHUSB-4P hub problem
Your hub ma have been a older version of USB and the new computer has the USB ver2. in this case the hub is not talking to the computer. the computer USB is not backward compatible and will to detect the hub. you will need a new hub.
Aug 20, 2008 | Encore ENU-4USB 4-Port External Mini USB...
XP will not recignize my ZR200 as a valid input device
On your computer, go to <start><my computer>. Right click on My computer and select "properties". Select "hardware" and then "device manager". On the drop down menu, select the hub in question and be sure it is not "disabled". Also be sure that the power options on this hub "never expire", as Windows default sets a given time for this....accordianman
May 18, 2008 | Canon ZR200 Mini DV Digital Camcorder
Open Questions:
Fixed amber light - start,shut down itself and restart itself Hello, Yesterday morning, I have installed a second screen linked to my graphic card. I tried to install a 3rd screen on the VGA motherboard, and it didn&#39;t work so I take it off. I could work on the computer with the 2 screens all day long. I left my office and the screensaver started. When I came back, I couldn&#39;t started my computer and my screen didn&#39;t light on after moving the mouse or writting on the keyboard. Then, I shut down my computer to restart it. Here is the problem. 1) The power light was fix and amber, the ventilation works. 2) 2-3 seconds later, it shuts down itself for few seconds 3) And it restarts itself. However, I still have the fix amber light and the screen is not activated. I checked the wall plug, I reduced the number of device on the trailling socket. I removed and reinstalled from the motherboard the RAM memory card and my graphic card. I tried with only one screen. But I still have the same problem. Do you have any ideas about what the problem could be: - Is the motherboard over? - Is the graphic card over? - Is the power bloc over? How could I evaluate which component is not working correctly? Thanks for your precious help. My configuration : - Intel Core 2 Quad Q8200(2,33GHz,1333MHz,4Mo) - Windows Vista - Cordon d&#39;alimentation : Europ&#233;en 2M - Carte graphique : 256Mo DDR2 ATI Radeon HD 3650 (pleine hauteur,sortie DVI/HDMI/DisplayPort,Double affichage)
Mar 01, 2017 | Dell Vostro 420 Desktop Computer
Dell Vostro 420 Desktop Computer   Logo
65 people viewed this question
Alun Cox
