Question about Haier Washing Machines
Detergent still in drawer after wash finish
The detergent is still in drawer once cycle finished
    Top Expert:
  • Haier Master
  • 9,472 Answers
You need to clean the line out.
Posted on Nov 03, 2012
SOURCE: Detergent & Conditioner Drawer
Perhaps it needs to be thoroughly cleaned out first - sometimes the gloopy mess collects and blocks the outlet hole.
Posted on Feb 10, 2008
MNTECH
  • 1543 Answers
SOURCE: Detergent dispenser drawer stuck
You may have to remove the washer top (three phillips screws at the back, then push top back about two inches and lift it off) then drill a hole in the top of the plastic dispenser to allow you to use an object like a screwdriver to maneuver the offending part around so it will drop down and allow you to open the dispenser drawer. Use foil tape to seal hole if you don't want to buy a new dispenser. Clean out blue plastic dispenser parts so detergent will siphon out completely. Pushing down on the center tab at the back of the dispenser should allow you to take the dispenser drawer the remainder of the way out. In the future, make sure you do not use over 1 tablespoon of HE soap (and 1 teaspoon of fabric softner) max per load. Even less if you have 2x or more detergent.
Posted on Oct 11, 2008
barkencoa
  • 3463 Answers
SOURCE: the fabric softener drawer is
Remove drawer and thoroughly clean, you must have a blockage in it for the water to remain.
Make sure that you clean every piece of it, taking all the components out.
Please leave feedback.
Posted on Dec 01, 2008
SOURCE: detergent drawer does not empty detergent
hi! remove your powder draw, it should just pull out with a wiggle,give it a good clean in hot water, before you put it back give the draw hola a god clean with a bottle brush and hot water! good luck
Posted on Dec 20, 2008
  • 130 Answers
SOURCE: GE Profile washing machine not finishing cycles
the OL error is for over load.that is when you over load the clothes in the washing machine. If your washer doesn't spin or agitate on either the delicate or regular cycle, check these:
Selector switch
Clutch assembly
Drive motor
Selector switch If your washer has a selector switch on the control panel, make sure the button for your selection is pressed all the way in, or set properly.
Clutch assembly Many GE®/Hotpoint® washers use a clutch and an automatic shift lever. This assembly is quite complicated. If there's a problem with it, you probably should contact a qualified appliance repair technician.
Drive motor Many washing machines have multiple-speed drive motors. Though it's uncommon, the drive motor may work fine on one speed but not on another. If the drive motor has failed on one speed, you need to replace the entire motor.
Posted on May 07, 2009
Control lock light is on , toke door lock off once cleaned it put it back on and it worked now its on aagain and washer wont work
1 close washer door and dispenser drawer
2 select Clean washer cycle
3 Press start/ pause
The basket will rotate,then the door will unlock,lock again,then the cycle will continue
Water should come in and run a short sensing cycle about 3 minutes
4 This will determine item in the washer
a if no items are detected it will move to step 5
b if item are detected wash any control lock light will stay on door will unlock open and remove any garments
If b pessnpower to cancel f code then repeat 1,2,3
Once cycle begins allow it to finish
5 after cycle is complete leave the door a jar to allow for venting and drying of interior
Only use HE high efficiency detergent
Jul 05, 2015 | Whirlpool GHW9100L Front Load Washer
Won't finish the wash cycle
Initially we 1)used less detergent and make sure its marked 'he' . extra soap suds initiates error codes. 2) ran white vinegar with no detergent to clear suds 3) opened, checked and cleared trap.
Everything worked for a time but codes would return or like you would not finish wash cycle until water line in back of machine was made rigid so there was no chance of water or sud backup. So far so good. Good luck.
May 27, 2014 | Bosch Nexxt 300 Series WFMC2201UC
Maytag 1200 AAW front loading washing machine
What do you mean additive? There are 3 compartments, one for bleach, one for detergent and one for the softener. Which one is it?
Jan 17, 2014 | Washing Machines
Bendix WFF 2001. Ihave a mould problem on the ruber inside the doo
Hello, water tends to sit in the rubber after a cycle, once you have finished, ensure you dry this area using a towel and leave the door and detergent drawer open to allow the unit to dry. Due to the unit getting warm within the cycle and then cool slowly it is a breeding ground for mould, especially in cold damp environments like a garage or utility room.
Good luck
Aug 05, 2011 | Tricity Bendix Washing Machines
Siemens E1244 Washing Machine Detergent Drawer is still full of water, once the wash has finished its cycle. Machine is only 4 Years old. I have already cleaned out the drawer, cleaned the filter on the...
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 15, 2011 | Siemens Washing Machines
Fabric conditioner section in draw always full with water after cycle has finished
Detergent drawer is clogged with soap. to remove look for small plastic clip on the inside above the detergent drawer which needs to be released. Remove detergent drawer unit and wash thoroughly under running water, or bucket. Replace and problem should be solved until it gets clogged again.
Jan 15, 2011 | Bosch Classixx WFC 2465 Front Load Washer
Detergent drawer filled with water
remove the drawer and clean the siphon it sounds as if it is blocked up either with powder or concentrated fabric softener. this should fill up with water and then empty itself due to gravity. the siphon should look like an upside down cup on a cylinder.
Jul 23, 2009 | Kenmore Elite 45986 Front Load Washer
Oct 30, 2007 | Neff W4380X1 Front Load Washer
Leaking water
Possible your detergent drawer is clogged with old dry detergent. Pull out the drawer and clean with tooth brush. Things shd be fine. Also use only detergent for 'front loading machines'.
Oct 07, 2007 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
59 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
