Question about Kenmore 24872 Top Load Washer
Kenmore Waher spin cycle out of balance
Kenmore top loading washing machine (Model # 110-28912791), goes out of balance during the spin cycle - even when run on empty. It appears to be in proper balance at all other times. The legs are level. While in the spin cycle, the tub seems to be off balance, shifting towards the back side of the washing machine (when viewed straight on), thus causing it to be off balance. Help...please...
  • 10 more comments
  • Anonymous Mar 13, 2014
    it appears that the load is out of balance but it is not.
    when in spin cycle tub spins out of balance hits interior side of machine
  • Anonymous Mar 15, 2014
    Machine moves during spin cycle
  • Anonymous Mar 16, 2014
    no matter load size when machine goes to spin the tub bangs around like it would if out of balance
  • Anonymous Mar 21, 2014
    During high speed spin, even when empty, the washer shakes violently. I checked the 4 suspension absorbers and they seem fine(. All 4 have some free slack between tension on both ends?) the 2 springs on top are fine too. With back panel off the rear bearing seems fine( no grinding at all) and balanced. Looking from front and spinning (empty) it seems out of balance. Finding chew up plastic in washer n further investigation shows a small groove worn in plastic at front of washer. To me it seems as if inner tub isn't balanced in outer tub?
  • Anonymous Mar 22, 2014
    Kenmore 110
  • Anonymous Mar 30, 2014
    machine is level. spins unbalanced, what can be the cause
    machine is level but spins unbalanced. what can be causing this
    machine is level but spin cycle is unbalanced even on an empty load
    how do you level the machine
  • Anonymous Mar 31, 2014
    tub out off balance majorly
  • Harper Campbell
    Harper Campbell Oct 17, 2017
    You might want to make sure that you are not overloading it when it comes to putting your clothes in. When it came to our's doing the same thing, we noticed that this was a huge help. But if nothing else seems to work then you might want to consider hiring a professional to come look at it.http://www.americanapplianceinc.com/part...
    Problem Solver:
  • 11 Answers
Sounds like your front to back spring is pulling to tight, sometimes you need to replace it and sometimes you can take it off and stretch it. hope this helps
Posted on May 20, 2007
Why does it always become unbalanced in spin cycle?
how confident are you to get inside it? Check the balance springs and shock absorbers.
Normally it is two simple things.
First the machine must be level front to back and left to right. Also all 4 feet must be in equal contact with the floor.
Make sure you load the washer evenly with clothes. Mix large and small items so when the spin starts the clothes even out. Never wash just one large item that is very absorbent, like one bathrobe or one blanket..
Dec 26, 2015 | Washing Machines
Spins out of balance even emty
http://www.askmehelpdesk.com/plumbing/whirlpool-out-balance-spin-cycle-18991.html
http://fixitnow.com/sbrvrs/washers.htm
http://www.repairclinic.com/Washing-Machine-Troubleshooting
This model of washer does not have an out of balance cut off switch. If the load is not balanced properly the tub could hit the cabinet sides. If the unit spins evenly while empty & out of balance while loaded, I recommend checking & balancing the load. If the basket spins out of balance while empty, I recommend having the suspension springs & balance ring checked. Be sure not to wash light fabric with heavy fabric clothes. Also ensure that the adjustable feet are level, that's most important.
Aug 01, 2010 | Kenmore 24032\24036 Top Load Washer
Makes a loud banging noise as if the load is underbalanced even through the load is balanced.
HI There
Try this even tho you said it's balanced. Sometimes it looks like but a slight unbalanced can cause this problem.
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Let me know how this goes and thank you for writing to fix ya.
Best Regards Richard
Jan 07, 2010 | Kenmore Washing Machines
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Spin cycle goes out of balance even when empty.
The stem is bent or fractured or the bearing is shot. This is a rebuild job for a techo.
Oct 20, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Washer making noise during the spin cycle
Hi!!! it looks like your motor coupler is failing..Good luck..
Jan 03, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore mdl 10022622100 goes out of balance
to cause unit to go off balance taking in fact that you put clothes in washer even...check your counter balance spring it hold the tub to base at rear of unit,,,and check your balance ring at the top of your wash basket its fill with water if cracked will cause this problem,,
Dec 24, 2008 | Kenmore 22422 Top Load Washer
Spin cycle noise problems
It is likely that you have an unbalanced load. Try spinning the machine with only water in it. If there are no noises now, you will need to re-distribute the load. We clothes are heavy!!
Jan 13, 2008 | Kenmore 24032\24036 Top Load Washer
Washing machine
check to make sure the machine is properly balanced. an off balance machine will vibrate causing that sound.
Aug 16, 2007 | Kenmore 9387x Top Load Stacked Washer /...
Kenmore 70 Series Washer
You probably have a bad lid switch.
May 21, 2007 | Kenmore 15864/15862 Top Load Washer
Kenmore 24872 Top Load Washer Logo
1,510 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
