Question about Mackie HD1531 3-Way 15" HD Powered PA Cabinet
Mackie hd1531 thermal light and signal light flash
3 Suggested Answers
  • 5603 Answers
SOURCE: heiio,sir my mackie hd1531 is power supply is
You can try this site:
http://elektrotanya.com/mackie_sr1530_active_speaker.rar/download.html
This MAY be very close to your system... there are several parts to the schematic in this compressed file...
OFTEN companies do NOT re-engineer things so one has to use intution as to what the model number thisng might be listed...
You often find modules are identical between units even though the model is labelled differentely.
Posted on Nov 15, 2010
  • 5603 Answers
SOURCE: where can i get a new bass speaker for my mackie
Consider having it reconed... usually costs half of new speaker. Search google for "speaker repair" such as
http://www.reconingspeakers.com/speaker-repair/repair-services/?gclid=CNjQmrqT96kCFRJ6gwodVlDddw
Posted on Jul 10, 2011
The OL and THERMAL LEDs turn on quickly after an even very low level signal input.
These subs are renowned for problems. The PSU and the output stages as well as the main driver are all weak and there are a number of companies that will upgrade them and sort out other issues such as vibrations. Assuming it is out of warranty and you really want to use this you would be best going to a specialist repairer to get it sorted not Mackie.
Jun 21, 2015 | Mackie SRM 1801
My Mackie HD1531 has a high pitched whistling sound, all other speakers work fine with the same power connection and desk connection. It whistles regardless of whether it has a sound input or not.
Sounds like a problem with the horn amp in that cabinet. This is not a user fixable problem and needs to go to the shop. Here is a link to the Mackie support page where you can find a link to the repair shop list.
Mackie Tech Support
Feb 19, 2015 | Mackie HD1531 3-Way 15" HD Powered PA...
Why do leds flash randomly on faulty mackie dfx-6 ?
Genuine and consistent random flashing is normally a cable fault if is the main VU graph but there are other symptoms as well. If is the O/l (Clip) or Solo Leds on a channel strip have you checked for earth loops etc? Does it do it all the time or only when there's a signal? Which Leds are flashing and is there anything else that is not behaving correctly? It would seem if you can get a repair shop to have a look this would be your best bet.
Jul 27, 2014 | Mackie 1604 Vlz3 16 Channel Mixer
My HD1531 powers up (LED is on), fan does not come on and there is no sound. I switched the power section with the other one that is working and is worked. This sucks when your playing live music and you...
The fact that it failed suggests that there was either a manufacturing problem, or that you smoiked it. In most cases that I have seen, a defective component inside caused the problem. While this is rare, it does happen. Return the unit for warranty repair. These units are very rugged and I would not typically expect failure at this early stage. Anything you do to this will void the warranty, so please just return it for repair/replacement.
Dan
Jan 10, 2011 | Mackie HD1531 3-Way 15" HD Powered PA...
I have a Mackie d8b, not getting any signal no matter what we try.
This is vague,,, there are so many outputs, knobs, LED's that I suspect you have not tried the right combination. I have no idea what your signal sources are... mics... tape... etc.
To start, turn the trim control of one channel that you have a signal source connected. Set all the EQ controls and the pan CONTROLS TO 12 O'CLOCK.
Check that you can trigger the clip light with high level of input. Press the solo button for that channel and using a set of headphones listen for any signal... turn the headphone level up and the slider for that channel...
First do your basic checks,,, try EACH mute button and see the LED light... try each solo button and see that each will light AND also that ANY solo light will cause the RUDE solo light to come on...
Dec 09, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
Con 1-4-- -31v
Can you please further explain what your problem is? I can guess, but I'd rather not. I suspect that the internal amp is faulty. If you can describe the exact problem, I shoul dbe able to propose a few solutions.
Thanks,
Dan
Nov 29, 2010 | Mackie HD1531 3-Way 15" HD Powered PA...
Heiio,sir my mackie hd1531 is power supply is dammege plese send this service diagram. i hope you help thanks
Nov 15, 2010 | Mackie HD1531 3-Way 15" HD Powered PA...
Mackie HD1531 3-Way 15" HD Powered PA Cabinet Logo
82 people viewed this question
Top Mackie Music Experts
Michial Gueffroy
Matthew Spark
Matthew Spark
Vito Vacirca Jr.
Are you a Mackie Music Expert? Answer questions, earn points and help others
