Question about Admiral AW22 Top Load Washer
Cycle knob loose - Admiral AW22 Top Load Washer
    Top Expert:
  • Admiral Master
  • 9,472 Answers
Here is the new knob you can order.
Posted on Nov 03, 2012
How do you dry clothes in this machine please
A fairly common problem! The official instructions are
Before using your dryer, wipe the dryer drum with a damp cloth to
remove dust from storing and shipping.
1. Load clothes loosely into the dryer and close the door. Do not
pack the dryer. Allow space for clothes to tumble freely.
2. Turn the Cycle Control knob to the recommended cycle for the type of load being dried. Use the Energy Preferred Automatic Setting (,) to dry most heavyweight and medium weight loads. See "Drying, Cycle, and Temperature Tips."
3. Select a temperature setting on models with a Temp/Fabric selector. The cycle descriptions include temperature setting suggestions.
4. Push the START button.
Stopping and Restarting
You can stop your dryer any time during a cycle.
To stop your dryer
Open the dryer door or turn the Cycle Control knob to OFE
NOTE: The Cycle Control knob should point to an Off area when
the dryer is not in use.
To restart your dryer
1. Close the door.
2. Select a new cycle and temperature (if desired).
3. Press START
Extracted from
http://www.manualslib.com/manual/511763/Whirlpool-Lte5243dq.html?page=10#manual
Nov 14, 2015 | Whirlpool AWZ410 Front Load Washer/Dryer
How to remove knob of Frigidaire Gallery Washer
Thank you for posting the make and model. You'd be surprised.
Before you do anything, unplug the machine from the wall. Better safe than sorry.
From the photographs of the machine I can find online, the knob appears to pull directly off, straight back. Pull evenly, and gently, from opposite sides (think 9 o'clock and 3 o'clock) as you slide the plastic knob off.
Before installing the knob on the new timer/cycle switch, smear a minute amount of Vaseline type jel to the shaft to facilitate easy insertion of the knob. As explicit as that sounds, the mechanics are the same and work well in both circumstances, as necessary.
There may be a set screw which holds the knob on the timer/cycle switch shaft. Carefully check the part of the knob that attaches to the shaft of the timer/cycle switch. If there is a set screw, loosen it, BUT, do not remove it, as you will probably lose it. After it is loose, remove the knob as described above.
Since you want to pull the knob in order to remove the timer/cycle switch, I assume you have already determined the problem is with the timer/cycle switch. Was that readily apparent? You are sure?
Please, before you start replacing electrical parts, remember that most parts supply houses do not take electrical parts in return. They assume, (sometimes not incorrectly) that you have fried the part they sold you because it does not now function properly, because the problem is somewhere else. Be careful here.
It is amazing how much value they place on small electrical components you think might cost just a few dollars.
They do cost just a few dollars, but it's because they have the proprietary color, fit and finish that quadruples the price.
Good luck.
Aug 19, 2014 | Frigidaire Washing Machines
The dryer heats up and spins without issues. The problem seems to be in the dry cycle selection knob, it used to be a bit stiff when turning it to different cycles. Now, it seems very loose and it only...
Try pulling out the knob and turning the post wth your fingers. You will have to caibrate it yourself. If this does not work, You will have to rplace the control board behind the knob.
Sep 19, 2013 | Dryers
I have a Whirlpool electric dryer, it is a Duet with a model # of: GEW9250PW1. When I try to select the the "normal" setting on the automatic side, it lights up the delicate light and has the...
Is the selector knob loose on the stem? Look on the knob to see if there is a set screw of some sort that you can tighten to set it where it belongs, it just seems it's loose and isn't pointing to where it should. Let me know if this works or not,
Please rate and comment, Thank you,
Joe
Sep 01, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Model: 110.29822800 Cycle Control knob seems loose. When turn knob clockwise and pull knob, it seems like out of position. For example, I set at Normal, rinse and pull knob. It rinse a minute or two and...
Could be one of two things. The knob or the timer. Both knobs and the timer through sears parts direct are under 100 probably with shipping. If the knob that you pull out and push in does not feel sloppy when you turn it then i would guess timer is faulty.
Feb 27, 2011 | Kenmore 24032\24036 Top Load Washer
Kenmore Washer, Loose Timer Knob
There should be a spring clip that holds the timer knob on. It or the timer knob may need replaced. Here is a picture of the timer knob and the spring clip. Sure hope this helps and best wishes.
Jul 23, 2009 | GE WBSR3140DW Top Load Washer
The cycle knob is loose
Should still be under warranty .  Call for service.  There should be no charge.
May 29, 2009 | GE WBSR3140DW Top Load Washer
Dryer won't run unless I put pressure on the cycle control knob after pressing Start
sounds like you need to replace your timer, or either unplug the machine, an open the head panel an see if any wires are loose in there, changing the timer is an easy job, you should have no problems doing it ......good luck!
May 27, 2009 | Whirlpool LGR8648 Gas Dryer
Wash cycle knob turns without controlling wash cycle
it's possible go to www.repairclinic.com and enter the numbers you have posted and it will show you what they are. I have the same problem. What I did was not pretty but it works for now. I broke a piece off of your part#387997 and simply turn my dial that way and then pull the center out to start the wash. Considering a new timer is close to $100+ and it works fine this way , well you know...
Apr 06, 2009 | Washing Machines
Admiral AW22 Top Load Washer Logo
22 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
