Question about Compaq (283983-001) Motherboard
No sound,usb or ethernet ormedia card
E machine i have lost everything tried sys. restore still nothing
  • 585 Answers
This unfortunately sounds like a hardware problem on the motherboard itself. This may be especially true if the sound, ethernet, etc. no longer even show up in the windows device manager. You might try rebooting the computer, entering the setup BIOS page, selecting the "setup defaults", typically F7, or F9, or other, there should be a "menu", save and exit. If that clears up the problem, great. If not, you might try a PCI ethernet card, sound card, and USB, to have those things back. Otherwise I am afraid you may be up for a replacement motherboard or another computer. If replacing the motherboard, try to find an exact replacement so windows doesn't have to be re-installed.
I also highly recommend backing up any files you want to keep before taking any of the steps previously mentioned.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Posted on Jan 04, 2009
Lan terminal not working
first check for all the drivers in the device manager.... if every thing is perfect in driver side, then check if the ethernet/ lan is enabled....
then check is the light in the ethernet adapter is lit, when you plug any ethenet cable in it... still if it is not working, then finally try to update the latest driver for the ethernet controller.... if nothing works, then buy an pci ethernet card and use it..... you can also buy external cards like usb to ethernet converter... even belkin manufactures usb to ethernet controller....
May 09, 2010 | ASUS P4P800 SE (890552603657) Motherboard
BSOD at start of Windows XP Setup
try F8 to got to the startup menu, and choose last known good configuration, use a ps2 keyboard or an adaptor and nothing that needs the USB.SYS Driver to function, and you should be able to reinstall Windows, if last known good configuration doesn't work, i hope this helps, please give good rating
Apr 30, 2009 | Computers & Internet
NetGear Wireless Router and connecting using a USB Modem
I think you're saying that you want to set up a Netgear from a wirless port. Is that the ONLY computer you have?
It's not IMPOSSIBLE, but it is improbable. By default, the Netgear has the address 192.168.1.1. If nothing else on your network has that address, it might be possible to plug in the Netgear, set the IP address of your computer to 192.168.1.2-254, and link to 192.168.1.1.
I didn't say easy, just possible. Easy would be to use a computer with a wired ethernet port or grab a friend with a laptop with a wired port. It's a 15-minute job.
Carl
Apr 10, 2009 | NetGear WGR614 Wireless Router
Ethernet adaptor and Local Area Connection 2 cable unplugged
Is that an external usb nic card? you can just directly connect it to the usb port.
Sep 07, 2008 | Dell Inspiron 1150 Notebook
Creepy 'USB' issues...
check you USB wire end, if that center piece ( that white piece inside the connection) is missing that the problem. that white piece separates electrical connection, it it not there it causes a shorts curcuit and the pc shuts down
Aug 02, 2008 | Compaq Evo D510 Minitower (Open Box)...
Blue screen of death
Not exactly sure, but it seems that you should uninstall and reinstall you sound drivers. They may have become corrupt or it may point to hardware failure.
Jul 16, 2008 | Computers & Internet
Reinstall nic1394.sys drivers
put in the cd containing the drivers and install it
May 11, 2008 | Microsoft Windows XP Media Center Edition...
Ethernet and usb not working
use your recovery disk tHAT CAME WITH YOUR COMPUTER TO RESTORE THOSE DRIVERS BUT BACKUP ALL IMPORTANT DOCUMENTS & PRINTER DRIVERS fIRST.
Jan 17, 2008 | Itronix GoBook IX250 Notebook
Compaq (283983-001) Motherboard Logo
42 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
