Question about BenQ PB6110 Multimedia Projector
Power supply busted.
Power supply of Benq PB 6110 was damage, because of high power in the grid. I am very much glad if you can send me the circuit diagram of unit PB 6110.
THANK YOU SO MUCH!
    Scholar:
  • 100 Answers
I did some search for service manual, which will most probably have al circuit diagrams and maintenance information for the BENQ PB 6110 Air Conditioner and found it on this site for $24.90. i used their search and went all the way to check that its available for imediate download, but didnt download it :) here's the link for the site:
https://www.2instructions.com
Posted on Jan 04, 2009
  • BenQ Master
  • 19,396 Answers
The spare circuit diagram is not available, and since Benq is out of market, the service manual will aso be difficult to find.
Check all capacitors, looking for a bulged one, that is the most common cause for faults on PSU unit.
It made a loud popping noise and stopped working. No standby lights. no fan, I am assuming it is a power supply problem. No burnt out components visible.
YES , IT LOOKS WITH PWER SUPPLY .please send youe email we can send you. our email .mrtelcoms@gmail.com or how to upload on this site .
mahesh
Mar 27, 2016 | BenQ MP770 DLP Projector
My CDJ 850 won't turn on.
If the standby light blink then it indicates a fault relevant to the processor.If the set is fully dead then the SMPS power supply can be faulty.
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Since there is a possible short or leak in the circuit the output driver section can take in huge current to trip the SMPS or from advice from the micro processor. Remove the power plugs and make sure that high voltage sections are discharged of the potential stored in capacitors. Look for visible signs of leak or of busted capacitors. Look for bulged capacitors or damaged components- burnt or busted. Use a multimeter to check the continuity or shorting in components, if so detach from circuit and test . If the voltage builds up and the set power ON and then shuts up then the suspected section must be checked in detail.
The processor must have the +5 voltage to the function properly , the +B and secondary voltages also must be checked to infer the fault. Trace with caution and in running through the signal path , circuit trail.
Jul 12, 2011 | Pioneer CDJ-850 CD PLAYER
Hello, I have a 28" BenQ
Good day!
The problem of your TV is in the back light.
Follow this procedure of troubleshooting to your problem.
  1. Open the back cover,remove all screws at the back.
  2. Plug-in the power cord then power it ON.
  3. Check the input supply of the inverter board.It should have 24vdc.
  4. Then if you have input voltage of the inverter board.Check the output of the inverter board it should have 500vdc so be careful its high voltage.
  5. When your inverter had a output of 500vdc.It could be the cold cathode lamp is busted replace it.
  6. If the inverter board have no output of 500vdc but it have a input of 24vdc.Replace the inverter board.
Try to order here:http://www.electronica-usa.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=EU&Product_Code=INV01001&Category_Code=
Thank you and good luck.
Apr 21, 2011 | BenQ DV3070 30 in. LCD HDTV
BenQ 8700 Won't Power On
As far as the projector goes, the ac power supply is fused with probably no more than a 7 amp fuse, that would blow before your breaker would if the problem were in the projector. The only thing that could case the breaker to trip would be a defective AC outlet socket or your cord for the projector is bad. I have seen cases where cat's have chewed though the cord and shorted it out and triped a breaker, outside of that if the projector is bad now then your thought of sending to the manufacturer is the best one.
Jun 07, 2009 | Televison & Video
No Picture
Ok. It still might be the bulb, if not make sure it is plugged in to a working outlet. Also, if that doesn't work unplug, wait 1 hour, push the power button (with it unplugged) then plug it back in. If nothing fixes your problem, it is the power supply.
May 24, 2009 | BenQ PB6100 Multimedia Projector
On screen resolution issues
Bought a new XGA projector.../
It appears from researching that the native res for the Benq is too low 800x600 so I will never get a good picture even though most of the images I install are at least 10meg originals. Also the new projector will work in a bright room the Benq will not.
May 07, 2009 | BenQ PB6110 Multimedia Projector
Screen resolution on powerpoint cannot be locked at high res. Changes when connected to my projector. Monitor screen res. also changes everytime the projector is plugged in, In power point display (2nd...
I just checked the specs on your Benq PB 6110, which has a native resolution of 800X600 and will simulate 1280X1024. When you connect it to your computer, the computer goes to 800X600, right? That is the resolution of the BenQ. How high a resolution do you want? THe highest I have seen in projectors is 1024X760, which is not that much higher. Projectors seem to lag behind monitors and Plasma/LCD/LED TVs for resolution. They must have a very small market share therefore low developement.
May 07, 2009 | Microsoft Office PowerPoint Home and...
BenQ 6110
Hi there
If your S-Video connction id fuzzy - try another S-Video cable and if the problem stil occurs you will have to replace the Mainboard
Mar 17, 2008 | BenQ PB6110 Multimedia Projector
BENQ FP731s Monitor Problem white blank screen
You have a serious problem. ie. only the back light is working in your monitor. You might need to replace the TFT associate components.
May 06, 2007 | BenQ FP731 17" LCD Monitor
No power
You could have a bad high voltage transformer or problem with the power supply. If the set is over 6 years old, It would probably be better to replace it.
Jan 13, 2007 | Sharp 32F540 32" TV
BenQ PB6110 Multimedia Projector Logo
129 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
