Singer 4423 Sewing Machine Logo
Posted on Nov 02, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Needle wont move on its own
Motor runs but needle doesnt move
sylviaivie
Level 3:
  • Singer Master 1,564 Answers
  • Posted on Nov 03, 2012
sylviaivie
Singer Master
Level 3:
Answers
1564
Questions
Helped
425782
Points
3583
First check to see if the machine is in bobbin winding mode. If you are sure it is not in winding mode.... check your motor belt. It's probably worn out or mis-adjusted.
Pfaff 1222 E Makes a whirring noise, wheel won't turn
How long has it been since it's had a thorough cleaning & oiling (including the internal moving parts)? Resist trying to run the machine if the only thing running is the motor. You could burn up the motor or possibly break a gear.
The following method has helped me rescue some frozen older Berninas (which your model seems to resemble). This method worked on all of them except one that also needed a cracked gear replaced.
Wheel on right side that controls the needle up and down is very tight...
It was working now it seems to be frozen the needle part wont move
Hi i have a 13400 kenmore sewing matching and the needle wont move what can i do?
How long has it been since you've had a thorough cleaning & oiling done on your machine? Most likely, the old oil has solidified and has stuck the parts together. Resist the temptation to run the motor when the machine will not operate or you may damage the motor.
Will not zigzag or decorative stitches New to these newer plastic style...
Model 2142. Motor runs but why doesn't belt move for regular sewing?
Make sure the bobbin winder has not been activated. When the bobbin winder is activated, the needle bar is deactivated. The belt could also be stretched, damaged, or broken.
If it is a mechanical machine, how long has it been since a thorough cleaning and oiling?
Motor revs but needle doesnt move,on singer simple
For first clue is the "motor revs" your motor belt is either too loose, too worn or broken.
2helpful
Needle wont move up and down.
Check the settings for bobbin winding to be sure they are not activated.
Needle stays stuck whilst motor runs. Elna sewing machine
Its a lovely swiss made machine, this is an electronic motor so the needle pressure should remain constant no matter what speed you sew at. The needle staying down and the squealing sounds more like drive issues inside or possibly gunk buildup.
If it was my machine, I would take it to a qualified Elna technician and ask for him to look at it. These machines are small and well made so well worth spending the money to give it a service and get it back to 1000% IMHO.
1helpful
Husqvarna Viking Model 150 sewing machine does not work
Make sure the bobbin winder isnt engaged this can cause the clutch to engage and the motor will run but the machine wont sew
1helpful
2answers
The needle wont move at all?
Hello we had the same problem with our sewing machine. After playing with it we found there is a bobbin winding assembly lever that moves back and forth. By moving it the needle moved. This helped us. Hope it helps you. [email protected] if you have questions.
Top Singer Sewing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
