Question about Sony 1/3" Ccd Color Video Camera Ssc-c104 Hyper Had
How do i connect the power to camera
I dont know how to hook up power to the cameras
Does anyone know what to do with white wire on the back of boss audio system 7948B? it says camera 12v
IF you are not using the dedicated power connection for the camera, just tape it off and tuck it out of the way. As for the camera not working, have you confirmed that it is getting power through the backup light tap?
Dec 01, 2014 | Boss Audio Systems BV 7948B - DVD receiver...
Lorex video camera not working
First make sure all connections (Both at the cameras and the DVR are connected properly, hand tight.
Next I would make sure they system is up and running.
To ,narrow down the problem take 1 of the malfunctioning cameras and hook it up to where a working camera is hooked up (I would strongly recommend putting a label on each Camera (Working and not working)with masking tape and a black marker, same for the cables at the back of your dvr. i;e. Camera 1, Camera 2, Camera 3...ETC) And as for the cameras write known working on a piece of masking tape attached to each and if possible the cable it's hooked up to (just like you did earlier, camera 1 -4)
Now, with everything running, disconnect one of the no working cameras and walk over to one of the working cameras. IF there all the same cameras just unplug at the camera and leave everything esle as is. Now unhook the working camera, set aside, and plug in the non working camera. If this does not fix it, I would look at both working and non working cameras and make sure any switches that may be behind a panel are EXACTLY the same.(dont change the working cameras settings, just non working) If you have to change the non working cameras buttons try it again. Repeat with second non working camera. If the cameras still do not work then they are faulty. If they did work with or without making any changes to the non working camera then your cable ends and/or cable is bad)
IF none of this helps, try going to the back of the DVR and switching 1 known working cameras cable with a non working cameras cable. IF this fixes it then you unit is bad, if not, then camera and/ or cable is bad as discussed earlier. This should narrow down your problem and put you on a path to getting the system working, not that you know for sure where the problem is.
Feb 03, 2014 | Computers & Internet
Gv 800 power surge in my building. no video signal. tried connecting 2 brand new cameras that have their own power source and still no video. also uninstalled the drivers and reinstalled them. could t
I have the same problem with at least 6 GV800s that are clone...I dont know if the originals will have the same problem. The problems occured after thunderstikes. All went DEAD and send them to China for repair. I have a few cameras connected to this card using shielded cable...and some others using UTP cable using video balloons. The UTP is not shielded and I start suspecting the damage is from these cameras.
Aug 18, 2012 | Geovision GV-800-16 Video Capture
Installed reverse camera to Eonon E1025 unit. Power for the camera was taken from the reverse lights (positive and negative). Video wire from camera was taken back to the E1025 unit. I expected the orange...
i had the same problem with my talon today, all you need to do is get another wire , connect one end to the 12v(red)backup tail light wire and connect the other end to ur dvd player and put it one the wire that is to be connected to the 12v for the revarse camera the wire should be orange but urs might be a different color.
Nov 28, 2010 | XO Vision XOD1735 Car DVD Player
I've hooked up the back up camera to the cameras input and connected the power wire to the back up lights. I'm getting power, but I don't see an option for the camera in the menu nor does the camera come...
i don't know exactly what system you are using
from what you stated your saying the monitor is powering up when put car into reverse
but the camera is not coming on
what this tells me is either the camera it self not getting power or ground
u hooked up the video wire between monitor
the camera needs to get power some how it might be the wire that hooks into monitor but i don't think so usually that just the video wire (but depends on system)
i assuming there is one or two more wires on the camera itself that needs hooked up
a power wire
and a ground wire if there no ground wire then frame where camera is mounted to on car needs to be cleaned of all rust and paint
I assumed allot if this don't help you at all please let me Make and Model # of your camera system and i try and help you more
Nov 16, 2010 | Car Audio & Video
Help me with back up camera for xo vision xod1740bt
I am just giving a suggestion. I too need to know how to wire this. From what you posted it sounds like you hooked the wire to a constant +12v that is always on. Forgive me if I am wrong. Anyway, Did you connect this wire to rear reverse light power. I think from what you say it is supposed to be connected to the positive side of that light. If this solves your problem can you PLEASE let me know the full details of everything else you hooked up on the circuit to make the backup work. For instance what is the label of the orange wire. TIA.
Jan 13, 2009 | XO Vision XOD1735 Car DVD Player
Dont know how to upload pics to computer
after connecting your camera, power it up. the computer will then prompt new hardware found and is ready to use. in most cases, the camera will be treated as another disk in your computer (like usb disk). go to my computer and check if there is a removable devices listed. open that drive then you may start to copy and paste it on any folder of your computer.
the camera should also come with a cd, which you may install in your computer.
Oct 31, 2008 | HP Photosmart M425 Digital Camera
Uploading pictures
Mass storage is easier, in my opinion. In that mode, when you hook the camera up to the computer, it will show up as a device in My Computer. Then you can just access your pictures there.
Jul 11, 2008 | Sony Cyber-Shot DSC-S500 Digital Camera
Jensen uv8 help
The green with white is for the back up camera option, if you dont have a camera dont hook it up. If you use th remote when in the dvd mode press setup on the remote, then enter 5 4 3 2 1 0 (with the numbered keys) then holding 0 for 4 seconds, this will take you into a screen where you can shut off the parking brake overide. Now you dont have to hook up the pink wire.
Nov 25, 2007 | Jensen VM9510 Car DVD Player
Sony 1/3" Ccd Color Video Camera Ssc-c104 Hyper Had Logo
27 people viewed this question
Top Sony Home Security Experts
JonSnell Electronic
JonSnell Electronic
Are you a Sony Home Security Expert? Answer questions, earn points and help others
