Question about Baby Gear
How do i unlock the front swivel wheels on my Chicco stroller??
I do not know the model of my stroller (it is 2nd hand) but i know it is pretty old. There is a tab for unlocking the front wheels but I cannot push it up or down. They must unlock right?? Help!
OK I solved it myself! I took a hammer to those front tabs and,low and behold, they did push down to unlock the wheels. A little muscle was all it took. Thanks anyway....
Posted on Jan 05, 2009
When in 'swivel' mode front wheel turns wildly making it difficult to control and even stops the buggy when the wheel 'stick' at right angles to the buggy
In normal use, the front wheel needs to swivel freely - then this stroller's drive is easy and manageable with one hand (we know from extensive use with 2 kids and shopping on board).
The front wheel normally can not collide with the car. If the wheel assembly / lock is not correctly inserted, it can lock / unlock uncontrolled: try to disengage and mount the front wheel unit again.
Unsufficient tire pressure can also detoriate the drive.
Dec 20, 2015 | Regal Lager Phil & Teds Sport Buggy Double...
Chicco liteway
Hi Bendixen
We would recommend you contact Chicco for assistance. Chicco UK Contact Us Contact us
Jan 24, 2014 | Chicco Winter London Astral Stroller
Chicco 3WD Tech rear wheel needed
Try jogging stroller its easy to Swiveling front wheel & maneuverability. Locks forward for increased stability when jogging or if the terrain turns tough.
Mar 06, 2013 | Chicco 3WD Tech - Canarie Stroller
Sticking front wheel on bugaboo frog won't swivel properly
There should be a master degree on the subject of using and folding strollers...
I do not know this stroller, but the try the link below.
On right hand top of the page you will find LIVE HELP... They should be able to help you solve this..
http://www.bugaboostrollers.com/home.jsp
Good luck! :)
Cathy
Oct 21, 2009 | Bugaboo Frog Stroller
Front swivel wheels fall off
I found your fee for 1 solution to be too high. I emailed the evenflo company and they helped me solve the problem.
Thanx for checking.
Aug 26, 2009 | Evenflo Baby Gear
Phil and teds sport stroller
melt some candle wax into the hole and put a drawing pin in it so its level and it spins easily without getting stuck
Jan 07, 2009 | Regal Lager Phil & Teds Sport Buggy Single...
Baby trend expedition double jogging stroller
No but if you just sort of push on one side of the handle bar it will pull it to turn without lifting the front.
Aug 25, 2008 | Baby Trend Expedition Double Jogger
hi we had the same problem with our p&t sports buggy, brand new out of the box the front wheel kept locking, driving me mad! we contacted our supplier, kiddicare.com, who were extremely helpful and sent out a "front wheel swivel/fixed catch (screw fixing)" - it has WORKED WONDERS! the buggy is now smooth and easy to handle. you have to remove the old catch pin which can be a bit of a fiddle (when we got the old pin out it was a rivet fixing and very rusty) but only took us 10 minutes. highly recommended if you can get hold of one of these new screw fix pins, which have obviously been brought out to fix a common fault which p&t can't be bothered to recall lots of buggies and fix themselves...... ;)
Aug 01, 2008 | Phil & Teds E3 Jogger
Quinny 3 wheel
From the associated pictures, it appears the front wheel does NOT swivel. Generally jogger strollers do not have a front swivaling wheel because it may cause the stroller to flip while jogging. Jeep makes a stroller that has a front swival with a locking device on the front wheel, they also have these with a built in speaker system to attach mp3, cd players to. Sorry I couldnt be of more help. If you wantn to email me an actual photo of your stroller I will take a closer look and determine if it can swival. Just let me know on here.
Jan 24, 2008 | Quinny Freestyle 3 XL Dusk Jogger
Baby Gear Logo
583 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
